2001 S-10 4.3 Knock Sensor Location? - S-10 Forum
post #1 of 10 Old 10-15-2010, 10:16 AM Thread Starter
User is: Simple Man is offline
Where is the Knock Sensor on my 2001 Chevy S-10 4.3?
I am getting an intermitten, yet re-occurring P0327 Knock Sensor Low Input code, & would like to inspect the circuit wiring & sensor.
Any additional insight or input relating to this issue would also be appreciated. Thanks in advance for your reply.
post #2 of 10 Old 10-15-2010, 10:28 AM
i need a paint job
s106banger's Avatar
User is: s106banger is offline
Send a message via AIM to s106banger
Re: 2001 S-10 4.3 Knock Sensor Location?
back of the block behind the head on the drivers side.
1997 S10 266ci V6-turbo. 4l80e. 8.8. 23lbs.
10.93@122
526rwhp 531ftlbs on a mustang dyno @20lbs.
build thread-http://www.s10forum.com/forum/f11/no...r-more-481754/
2002 S10 2.2-DD 80% ZQ8 clone "TuTu Powa" w/efans. 98rwhp 111ftlbs!
post #3 of 10 Old 10-15-2010, 10:53 AM Thread Starter
How the heck do you get back in there?
I found a 2 wire connector from the harness hanging loose (1 Blue & 1 Gray wire) at the back of the engine, but still haven't seen the Knock Sensor or its' pigtail. I suspect I'm not plugged in.
Any other tips or tricks to finding or locating it?
post #4 of 10 Old 10-15-2010, 10:06 PM
i need a paint job
s106banger's Avatar
some small hands and a light.. theres no good way of getting to it, just start digging. ive ripped alot of my stuff out of my engine compartment so its not as bad for me.
10.93@122
post #5 of 10 Old 10-16-2010, 08:26 AM Thread Starter
Still didn't see it, but while I was poking around, I discovered my distibutor cap only had (1) screw in it & was loose. I installed a second screw to secure it & now I wonder if this could have been the problem in the first place.
post #6 of 10 Old 10-16-2010, 09:11 PM
i need a paint job
s106banger's Avatar
do you know what it looks like? yours is black, look one up on a parts website.
10.93@122
post #7 of 10 Old 10-16-2010, 09:42 PM
Tw34kd's Avatar
User is: Tw34kd is offline
Just took this of the one i pulled from my 4.3
02 Somoma : Most things shaved, v8 swap in progress.
97 Civic coupe : Black on black, turbo vitara build.
02 Pontiac grand prix GT : Daily driver.
Tw34kd is offline
post #8 of 10 Old 10-16-2010, 10:21 PM
i need a paint job
s106banger's Avatar
^that works too. these are 01+ 2 wire knock sensors too guys.
any 4.3 2000 and older will have a one wire knock sensor thats completely different looking.
10.93@122
post #9 of 10 Old 01-26-2012, 03:36 PM
get over it....
Bad-S10's Avatar
User is: Bad-S10 is offline
on a 2000 s10 v6 where would be?
by the the engine is a 99 from a blazer if that make any diff...
2003 blazer 4 door 4x4 black. lowered 3/3 c6 wheels, ZQ8 Box, K&N CAI, HP Trans.Cooler, PCMPowerTunes, Magnaflow with no cats..
2000 s10 ls, (SOLD) n Missed...
2008 Chevy Aveo ls....( SOLD )...
Brasilian by Birth , Bostonian by Choice
follow me on instagram: @ Bad_S10
Bad-S10 is offline
post #10 of 10 Old 01-26-2012, 05:14 PM
"factory freak"...
Crew Cab Sonoma's Avatar
same place as the 01-ups.
behind the driver side cylinder head.
VERY difficult to get at...
95 S-10 2.2. Soon to be DD
