2001 No power under acceleration - S-10 Forum
post #1 of 19 Old 02-27-2010, 09:06 AM Thread Starter
KentuckyMinis.com
Slammed83Mazda's Avatar
User is: Slammed83Mazda is offline
Send a message via AIM to Slammed83Mazda
I been posting in a similar thread, but figured I'd give my brief rundown on my problems here.
2001 2 door blazer
96,xxx miles
new fuel pump at 89,xxx
About 3 weeks ago I seafoamed my blazer. Ok a week after that, I noticed jumpy rpms around 65mph. So I think nothing of it. About a week goes by and it gets worse, it gets so bad I pretty much started shifting with the gas. It was normally bad around 2k RPMS, then it just went downhill. Everytime I would try to lean into it nothing, it would fall on its face. When I could mash the gas it would get around 3k-4k(if I was lucky) and then slowly climb back down. So now here I am with a blazer that can't even be driven.
It's been throwing a SES code, p0101. So MAF okay, thats a $150 gamble, no. I took the one off my in laws 2003 blazer and still got the same exact results. Even replaced the TPS sensor and same stuff. Unplugged the o2 sensor and it ran worse. Unplugged the EGR valve and it ran a little better.
So now I'm stuck, I got a gut feeling it's the spider assembly. But I'm so sick of throwing money at this thing I'm considering trading it in and cutting my loses, which are at around $2,000 total.
Nick
| D.I.P. Fred "Pinky" Browne '80-'06 | D.I.P. Ed Boley '80-'07 |
http://www.KentuckyMinis.com Get with it, or get ran over.
http://www.facebook.com/dwp101 Quality coverage, Quality images.
post #2 of 19 Old 02-27-2010, 11:18 AM
goin broke but n style
S15vortecpwr's Avatar
Re: 2001 No power under acceleration
does eng temp have aanythign to do with it. Does it run better when cold than warm? If it does i would have to venture to say you may have a clogged cat. Remove the y-pipe and see if it revs faster, if it does than replace the cat. Just my .02 I have seen clogged cats give MAF codes.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #3 of 19 Old 02-28-2010, 02:46 AM Thread Starter
KentuckyMinis.com
Nope, no matter what temp it is it still does it. I crawled under it and see were it was bolted up by the muffler. So I just remove it from there or what?
Nick
post #4 of 19 Old 02-28-2010, 03:01 AM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
id say kick the cat a couple times to hear if anything is moving..?
when you seafoamed it, did you run it through the brake booster?
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #5 of 19 Old 02-28-2010, 04:53 AM
you need to disconnect it b4 the cats. if the eng revs and idles better and your issues go away, you more than likely have a clogged cat.
post #6 of 19 Old 02-28-2010, 10:28 AM
2001 S-10 Crew Cab
HenryJ's Avatar
User is: HenryJ is offline
Pulling the forward O2 sensors can also offer enough relief to see if it runs better too.
A plugged pre-cat is very common. Mine did it too.
If It was mine I would bring out the reciprocal saw and cut the pipe just in front of the precat. I have a feeling you will find a mess. Unbolt it from the cat at the flange and make sure the cat still looks good. Then take a bar and bust the guts out of the precat. Clean it all out good , grab a new gasket and bolt it back in place.
You can then get a stainless steel band clamp to repair the cut you made and get yourself to the muffler shop for a weld job.
The precat is just a smaller cat designed to heat up faster and get a head start on the conversion process. It was a nice idea, but it just didn't work out. They tend to plug way too easy and go rapidly down hill from there.
You can run with out it and not set any lights. Be prepared for it to be just a little louder. Not much though.
You should know that technically it is altering emissions parts, therefore not legal. You will pass the visual inspection, but if inspected internally, you would fail the test.
Speed is just a matter of money...How fast do YOU want to go? -ThunderII
HenryJ is offline
post #7 of 19 Old 02-28-2010, 10:53 AM
NO REGRETS
purplepassion's Avatar
User is: purplepassion is offline
Send a message via AIM to purplepassion
no emissions here in KY
nick, i still have my stock y-pipe if the pre cats end up having something to do with it
*NR* Alvey
2002 Blazer - SFBD on 20s
post #8 of 19 Old 02-28-2010, 11:37 AM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
cut your losses.
you guys need to also remember there is no such thing as a "fix in a bottle". you can actually do more harm dumping so much crap into your tank or in the intake. it's best to do it in small amount over a longer period.
or just take care of it throughout it's life instead of waiting for something to go wrong.
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #9 of 19 Old 02-28-2010, 06:50 PM Thread Starter
KentuckyMinis.com
Originally Posted by serpentracer View Post
cut your losses.
Ya I'm realizing this now. Yes I did it through the brake booster. I'm going to end up trying to mess with the cats tomorrow and see what happens.
Brian I will give you a shout if it comes down to that. Thanks guys for your replies.
Nick
post #10 of 19 Old 02-28-2010, 07:33 PM
Busy dodging potholes
Jkelley01Xtreme's Avatar
User is: Jkelley01Xtreme is offline
Fuel filter?
post #11 of 19 Old 02-28-2010, 10:31 PM Thread Starter
KentuckyMinis.com
Originally Posted by Jkelley01Xtreme View Post
Fuel filter?
replaced it 5 days ago, old one was terrible. But yet.......no difference. I'm going to mess with the cats tomorrow.
Nick
post #12 of 19 Old 03-01-2010, 02:19 PM
Sometimes I'm mean...alot
RaginInferno's Avatar
User is: RaginInferno is offline
Cat(s) & Pre-Cats????
My S-10's only have a single Catalytic Convertor.
Originally Posted by Bentenn14 View Post
If I had to guess, It's gonna be one of those things that seems like a longshot that's gonna be the problem. I've almost exhausted the short-shots.
Jim
'00 Blazer 4dr 4wd, '00 S10 RCSB,'99 Blazer 2dr 4wd, '97 Southwind 35W, '03 2500HD,'02 Yukon, '00 Harley, '06 GSXR, '00 250EX, '10 RZR
post #13 of 19 Old 03-05-2010, 11:31 AM Thread Starter
KentuckyMinis.com
Well it turns out it was the cat coverter. Whew thank god this headache is finally over.
Nick
post #14 of 19 Old 03-05-2010, 12:05 PM
joyride's Avatar
haha, did you ever kick it like i told ya too?
but cool, nicejob, headache=gone. can't go wrong there!!
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #15 of 19 Old 03-05-2010, 12:09 PM Thread Starter
KentuckyMinis.com
Ya I smacked it with a hammer a couple times, and noticed it started getting better each time I hit and tried to give it gas. So I cut it off by the Y pipe about an hour ago and it runs just like normal, except loud as shit LOL. But I ordered the universal cat from jegs should be here monday.
Then it gets a BIG FOR SALE SIGN in the window, and poof be gone.
Nick
post #16 of 19 Old 03-05-2010, 12:10 PM
joyride's Avatar
hahaha, you're just gonna get rid of the dime? whatttttt?
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #17 of 19 Old 03-05-2010, 12:15 PM Thread Starter
KentuckyMinis.com
hahaha, you're just gonna get rid of the blazer? whatttttt?
Fixed, and hell yeah I'm getting rid of this thing. If you only knew how much I have replaced on this damn thing you would understand. Besides momma just bought a new car and I wanna pay hers off, I'll continue to rock a beater and save money until I can find something I like.
Nick
post #18 of 19 Old 03-05-2010, 12:17 PM
joyride's Avatar
well you got a plan, that works..and i hear ya, thats how it was on my 88 monte carlo ss! lol...we eventually found out it was a salvaged car pieced together with a really nice paintjob! lol so i understand!! hahaha
trade it in for a 10' camaro ss i went to the dealer last night and saw bumblebee and couldnt stop staring! haha
Brian
85 Monte Carlo SS
KCCO
joyride is offline
post #19 of 19 Old 03-05-2010, 12:31 PM
Sans S10
Fannatick's Avatar
User is: Fannatick is offline
Glad to hear you got it figured out, the cat would've been my guess, I had the same problem.
Originally Posted by JollyRojer
however had i jerked off first i woulda shown the bitch my heisman and been done.
1994 S10 Ext. Cab - 2.2 Auto, cherry red, manual everything - SOLD
2002 S10 Xtreme Ext. Cab - 4.3 - 5 spd - 2/3 drop, clear signals, Black with power windows/locks/mirrors - SOLD
