2000 blazer wont start. Fuel pressure? - S-10 Forum
post #1 of 14 Old 12-07-2008, 09:06 PM Thread Starter
chucked's Avatar
User is: chucked is offline
Send a message via AIM to chucked
2000 blazer with 4.3 wont start. I checked fuel pressure, it was 50 psi. I checked the book and it said it needs to be 55-60, i think??? Now does it have to be 55-60 psi to run?
chucked is offline
post #2 of 14 Old 12-08-2008, 12:09 AM
bobfig's Avatar
User is: bobfig is offline
Re: 2000 blazer wont start. Fuel pressure?
Mine started to get less pressure when the pump was dieing. When you first turn the key pressure should spike to ~60psi, idel psi should be ~50-55. When was the last time the fuel filter was changed, and how fast dose the pressure drop after the ignition is turned off?
bobfig is offline
post #3 of 14 Old 12-08-2008, 09:40 AM
Registered (Ab) User
Yogi's Avatar
User is: Yogi is offline
AFAIK, it won't start at 50. More like 55 psi min. to start. Prolly a bad fuel pump but it could be the FPR (Fuel Pressure Regulator).
2008 Saturn Sky Red Line Roadster
2.0L LNF Turbocharged Motor
5 Speed Manual Trans.
Custom made Blazer CAI (Click Here)
Yogi is offline
post #4 of 14 Old 12-08-2008, 10:13 AM
bobfig's Avatar
To check if it could be a fuel pressure regulater take that top off the throdel body and see if you can see a puddel of gas in the back passinger side of the intake, youay be able to smell it also.
bobfig is offline
post #5 of 14 Old 12-08-2008, 11:31 AM Thread Starter
chucked's Avatar
All i wanted to kno if it would run on 50 psi, thanks for answering my question
chucked is offline
post #6 of 14 Old 12-08-2008, 12:33 PM
Yogi's Avatar
It will "run" at 52 psi, but that's at idle with 22 inches of vacuum. Start-up has almost zero vacuum and requires more pressure.
Yogi is offline
post #7 of 14 Old 12-08-2008, 12:36 PM
User is: MikeInCtown is offline
Direct from the GM maintenance manuals.
When you first turn the key, pressure should be between 60-65. it will go down a few PSI after the pump shuts off.
Wait 30 seconds and then turn key again to prime pump. Pressure should go to 60. After pump primes, it should stay above 56psi.
If it does not stay above 56psi, you have a problem and need to look further into the problem such as return lines, FPR, or injectors.
post #8 of 14 Old 12-08-2008, 12:52 PM
blanz's Avatar
User is: blanz is offline
2000 S-10 GM service manual calls out for 60-66 PSI. Higer or lower will throw CEL.
Look at changing your fuel filter located on the Drivers side frame rail and then re-check pressure.
- Friends don't let friends do repairs without a Service Manual...
blanz is offline
post #9 of 14 Old 12-08-2008, 05:29 PM Thread Starter
chucked's Avatar
fuel pressure when priming seems fine, for some reason i remember it being 50, but it is 60, drops to 45 while cranking. Got the wrong fuel filter, going to get the right one now.
chucked is offline
post #10 of 14 Old 12-08-2008, 05:57 PM Thread Starter
chucked's Avatar
I found the coil wire was wore through, replaced that, it will now start and run, but i must spray starting fluid in the tb to get it to start, but it will stay running. anyone?
chucked is offline
post #11 of 14 Old 12-08-2008, 09:20 PM Thread Starter
chucked's Avatar
it was the filter
chucked is offline
post #12 of 14 Old 12-08-2008, 09:26 PM Thread Starter
chucked's Avatar
also my fuel pressure tester gauge was bad, was showing higher then it really was, but pressure did come up with the new filter
chucked is offline
post #13 of 14 Old 12-09-2008, 06:59 AM
blanz's Avatar
it was the filter
Ain't life great! Glad you solved the problem.
blanz is offline
post #14 of 14 Old 12-09-2008, 12:01 PM
Yogi's Avatar
it was the filter
Congrats, man!!
Yogi is offline
