Ok I was driveing down the road and the truck just shut down cranks but don't start the fuel pump runs and all the fuses in the box's are good .
I was told that the computer dus a self check when you turn on the key and was asked if the check engine lite was on but is not on and it don't come on when you fist turn the key ????
You need two things, fuel and spark. Check fuel pressure. It must be 60-66 psi key on, engine off. Pressure must remain above 55 psi for 10 minutes.
Spark must be blue and jump 1/2 inch.
I'm betting its the coil or fuel pump. I have had a few coils and fuel pumps fail me and left me stranded in the 11 years of owning a S10.
Oh and not to mention an ignition switch that would randomly shut off my truck while driving. That was always exciting in traffic
If you do not have 12v at the pink wire to the coil then there is a fuse or wiring problem. Check the 15A ECM1 fuse, that is where the coil gets its power from.
Just for future reference. If the pump comes on it doesn't mean that its good. It may not be producing enough pressure for the injectors to spray.
In this case though it sounds like you have a wiring or blown fuse issue since the coil has no power to it.
