2000 4.3 rough idle & hesitation - S-10 Forum
post #1 of 17 Old 05-27-2010, 01:42 PM Thread Starter
Never-Ending Project
Matt 4.3 TBI's Avatar
User is: Matt 4.3 TBI is offline
Send a message via AIM to Matt 4.3 TBI
This is a problem with my 2000 Blazer ZR2:
This just cropped up this morning while leaving for work - the idle is very rough and sits about 500 rpm with the AC off. Acceleration is sluggish, pushing on the pedal gives no immediate response. The engine didn't try to stall or feel like it bogged down when I hit the gas, it just doesn't seem to react without a delay. Fuel level is between 1/4 and 1/2 tank. I had to sit at a railroad crossing for a few minutes, the idle felt rougher than my 91 with its Edelbrock cam. I ended up taking it back to the house and driving the Malibu instead. These things always seem to happen when you're already running late!
I'm going to pick up some fuel treatment tonight and try to get it to the gas station to top off the tank - maybe it's bad gas. The past time I drove it was on Sunday and it ran normally - mix of city and highway on that trip. I'm not sure what's changed since then.
So, what should I look at next if the issue doesn't clear up? I'm feeling rusty on my diagnostics lately. Plugs are about two years old, air filter around last October, replaced the charcoal canister and both valves last winter. Alternator was tested earlier this year when I replaced the battery.
91 S-10 Blazer Sport 4WD 4.3 TBI 265 CID (4.020); 200cfm LB4 heads; Edelbrock intake, cam, headers; K&N; MSD 6AL, coil; Custom chip; high-volume oil + fuel pumps; ASP pulleys; TB spacer
HASTE Gallery
MCT Gallery
post #2 of 17 Old 05-27-2010, 02:58 PM
Sometimes I'm mean...alot
RaginInferno's Avatar
User is: RaginInferno is offline
Re: 2000 4.3 rough idle & hesitation
The normal suspects, vacuum leaks, fuel filter, fuel pressure, cap, wires, rotor, etc.
Originally Posted by Bentenn14 View Post
If I had to guess, It's gonna be one of those things that seems like a longshot that's gonna be the problem. I've almost exhausted the short-shots.
Jim
'00 Blazer 4dr 4wd, '00 S10 RCSB,'99 Blazer 2dr 4wd, '97 Southwind 35W, '03 2500HD,'02 Yukon, '00 Harley, '06 GSXR, '00 250EX, '10 RZR
post #3 of 17 Old 05-27-2010, 06:45 PM
Bill Wheats's Avatar
User is: Bill Wheats is offline
Make sure that a plug wire hasn't worked loose.
What does the exhuast look, smell, and sound like when it is having these issues?
I'd highly recommend connecting a vacuum gauge and running some simple tests before making expensive gusses.
Also, pull the dip stick and run the oil between your fingers. How does it feel? How does it smell?
When it's acting up; pull the oil cap. How does it sound? Place your hand over the hole. What do you feel?
Is you PCV valve plugged? is it still working? Smell funny?
Good luck.
Some people are like slinkies - not really good for much.
But they bring a smile to your face when pushed down the stairs.
post #4 of 17 Old 05-27-2010, 10:35 PM Thread Starter
Good luck.
It definitely sounds and feels like a misfire. Took it down the highway to the gas station and back. When cruising it is resistant to acceleration until it downshifts. Still accelerates well under hard throttle. Doesn't sputter and try to stall when snapping the gas open from a stop or letting off the gas quick from full throttle.
Plug wires appear to be in place properly. I attached my timing light to each wire as well - each one caused the light to blink in about the same pattern. So, distributor and cap/rotor appear to be good. Very quick strobe when the light is attached to the coil wire.
Exhaust has a strong gas smell - normally no odor at all, like smelling a running hair dryer. Tailpipe shakes noticeably, distinct 'chugging' sound as it idles. Engine visibly shakes under the hood.
Vacuum read 18 in/Hg but I could only find ported vacuum so it didn't act right when I tried snapping the throttle.
PCV valve rattles. You can feel the stopper snap back and forth by covering and opening the hole with your finger while the engine is running.
Oil is relatively fresh, only about 300 miles since the last change. Light amber color, no visible chunks and doesn't feel gritty. Didn't feel any pressure coming from the PCV valve port in the DS valve cover.
Still no MIL codes.
HASTE Gallery
MCT Gallery
post #5 of 17 Old 05-28-2010, 09:22 AM Thread Starter
A code finally-
P0155: O2 sensor heater circut malfunction (bank 2 sensor 1).
So which O2 is this one? Passenger side before the cat?
HASTE Gallery
MCT Gallery
post #6 of 17 Old 05-28-2010, 09:48 PM Thread Starter
Installed the new O2 and cleared the code. So far no difference. Still chugging and shaking at idle, exhaust smells like gas and bad hesitation when you hit the gas. Surging seems even more noticeable now when holding the throttle steady.
HASTE Gallery
MCT Gallery
post #7 of 17 Old 05-28-2010, 10:23 PM Thread Starter
A bit more info-
I don't feel comfortable trying to do a full ODBII drive cycle - I really don't want to take it on the highway to get it up to the required speeds. I started it up and let it idle in D with the AC and rear defroster on for over two minutes - I let it go until it reached operating temp. It was idling noticeably rough as expected. I then put it in P and gave part throttle to get the RPM's up to 3000 - no audible misfires, backfires or sputtering. I let off the throttle and then shifted back into D and let it idle. Now it was idling extremely rough, shaking the vehicle visibly. I let it keep idling like this (RPM's about 500). It sounded like it was straining to keep running. Sooty smoke was visible coming from the exhaust - along with the gas smell. Obviously there's a very rich condition going on here but I'm not sure what to check. No codes yet. I'll try this one more time once it cools off so it can do a full warmup cycle.
It still starts up with no trouble so it doesn't seem like the fuel pressure regulator is leaking. I haven't got any misfire codes so I don't think the poppets are sticking (but I don't really know all the symptoms).
Unfortunately I called the local shop to see if they could lend a hand - they have no one on staff to do diagnostics until after the holiday weekend.
As I mentioned, I have the MFI spider kit but I've been avoiding the chore of installing if until a problem arose with the CSFI injectors.
Any other investigation I can do to help narrow this down?
HASTE Gallery
MCT Gallery
post #8 of 17 Old 05-28-2010, 11:07 PM Thread Starter
I went back out and idled it in drive and park again to see how it acted.
It was running rough but staying steady as it did before - until I put it in neutral and brought the RPM's up to 2500. Once I let it back down to idle it started bucking and sputtering again - even worse in drive. I let it idle to see if it would actually stall - the computer actually idled it up to about 1500 without warning for about five seconds, then let it back down. It did this once more in the next five minutes.
It was nearly stalling when I shut it off and it exhibited another strange symptom I thought I imagined the last time - dieseling. It sputtered and ran a few more seconds after I turned the key to the off position.
HASTE Gallery
MCT Gallery
post #9 of 17 Old 05-29-2010, 12:13 AM Thread Starter
Additional:
After this it's hard to restart - like when I had a leaking fuel pressure regulator. I'm starting to wonder if the injectors, lines or poppets are leaking fuel inside the plenum
HASTE Gallery
MCT Gallery
post #10 of 17 Old 05-29-2010, 01:01 AM
I hate to say it but you need to go back to the drawing board and redo your basic troubleshooting.
There is a reason why I recommended doing what I posted. The solution is simple.
And stop replacing O2 sensors until the engine is fixed. Then you can replace them at will.
post #11 of 17 Old 05-29-2010, 01:17 AM
Going up ^
01S10's Avatar
User is: 01S10 is offline
You and I may have the same problem with our trucks. What that is however, idk.
Been trying to figure it out for months haha
2001 BLACK 2wd S-10 Ext Cab LS. 4.3 V6
01S10 is offline
post #12 of 17 Old 05-29-2010, 01:40 AM
You should start a new thread.
post #13 of 17 Old 05-29-2010, 02:45 PM
Going up ^
01S10's Avatar
I already did... but I don't want to spam this guys thread with posts. Just sayin im interested to see how he fixes his problem.
01S10 is offline
post #14 of 17 Old 05-29-2010, 03:38 PM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
im interested as well. unfortunately.
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #15 of 17 Old 06-13-2014, 01:26 AM
User is: Nathan S. is offline
How was this problem fixed? I've got a 2003 s10 Xtreme that is having the same problem. the only codes it has pulled up was for a mass air flow sensor and the drivers side pre cat o2 sensor.
post #16 of 17 Old 06-13-2014, 01:51 AM
AWD V8's Avatar
User is: AWD V8 is offline
With these symptoms, I'd guess fuel pressure was low.
If you truck is sluggish and unresponsive, check fuel pressures.
AWD V8 is offline
post #17 of 17 Old 06-13-2014, 09:04 AM Thread Starter
The problem was a combination of leaking injector poppets and a faulty PCM. The truck has been running perfectly for the past four years since I installed the MPFI injectors and had the PCM replaced.
HASTE Gallery
MCT Gallery
