1999 4.3 starts when key in on position - S-10 Forum
post #1 of 8 Old 01-06-2013, 12:02 AM Thread Starter
User is: nitrousbandit1 is offline
99 astro van. starts with key in on position. even before i get to the start point. replaced the ign switch. still did it. replaced the starter relay under the hood with an ac relay right next to it. still did it. replaced the starter. still did it. ive searched this site, google, the book. i also shifted the column real quick as the starter was engaging and it continued to crank. the van starts but you can hear the bendix starter still engaged in the flywheel. i dunno whats next. do you?
dave in chadds ford
post #2 of 8 Old 01-06-2013, 12:25 AM
Girl with wrenches
roademon's Avatar
User is: roademon is offline
Re: 1999 4.3 starts when key in on position
So in the on position it continues to crank even once started? I would say wiring at the ignition key cylinder is messed
-Heather
05' Blazer 2dr
97' S10 4.3 auto lowered 4/3*SOLD*
07' Suzuki GSX-R750
12' Dodge Ram 1500
roademon is offline
post #3 of 8 Old 01-06-2013, 12:37 AM
burned's Avatar
User is: burned is offline
Check the neutral safety switch and also check the wiring at the starter, may be grounding out.
2002 Dakota, QC 4x4, 4.7L HO Intake.
1997 S10 ZR2, Ext Cab, 5 Speed (SOLD)
How to test fuel pressure and leak down <---diagnostic help
burned is offline
post #4 of 8 Old 01-06-2013, 11:06 PM Thread Starter
i insert the key, turn it fwd, and before it gets to start position,it starts to crank. when the van does start and the key is left on the run position the starter gear stays in the flywheel and makes a horrible screech so i turn it off.
why or how would a neutral safety switch effect the ignition? and it is automatic trans
post #5 of 8 Old 01-07-2013, 01:15 AM
burned's Avatar
You sure you go that ignition switch in correctly?
Can you turn it backwards to "accy" ?
Well in your case its technically called a transmission range switch, same as a neutral switch.
To test the Park Neutral Switch, remove the starter enable relay located in the underhood fuse relay center and probe B6 cavity with a test lamp. Turn ignition to start and light should only be lit in P or N. Try moving the shift lever full range and between ranges and see if you can find a failure. Also the black wire 50 (NOT a ground) from Battery to Starter Solenoid must be connected and in good condition.
IGN-A 40A Fuse 6 is hot at all times and provides power to the ignition switch and the starter enable relay via the red wire 242 at cavity A6. When the ignition switch is in the START position, Yellow wire 5 powers CRANK Fuse 8 10A in the I/P Fuse Block and Purple wire 806 provides power to the Park/Neutral Position and Backup Lamp Switch. If the switch is in Park or Neutral, Yellow wire 1737 powers the Starter Enable Relay coil at cavity B6. Black wire 850 cavity A4 provides ground to the coil and terminates at Ground G104 which is located at the Right Side Front of Dash above Blower Motor. If everything works as it is designed, the coil closes the contact inside the starter enable relay and bridges power from Red wire 242 A6 to Purple wire 6 terminal B4 which is the starter request wire
burned is offline
post #6 of 8 Old 01-07-2013, 01:20 PM
General L33
Hotwire's Avatar
User is: Hotwire is offline
Send a message via AIM to Hotwire Send a message via Yahoo to Hotwire
Does this astro have any aftermarket equipment installed? Remote start, alarm system, etc?
Did you replace the ignition lock or the actual switch?
Hotwire is offline
post #7 of 8 Old 01-07-2013, 06:18 PM Thread Starter
no remote start no alarm. i replaced the wire part, the ign switch. goes does the column little 7 mm bolt.
the ign switch can only go in one way cause the bolts wont line up
post #8 of 8 Old 01-09-2013, 08:28 PM Thread Starter
it was the neutral safety switch.
