#101 |
Registered (Ab) User
Location: League City, TX (Houston) User is: OffLine ![]() |
Re: 1997 S-10 SS Vortec 4.3 Cranks, But No Start...
#102 |
That's the solution! |
#103 |
I understand what you are saying but you can't move the dizzy that much, if at all. Since they didn't pull the dizzy since it last ran right, then one of 2 things has happened (if the rotor is 40` off and they are on TDC);
The timing chain has slipped or the dizzy gears are wiped. If it was mine, I'd hand crack the engine backwards and measure any slop before the rotor moves. Then I'd crank it back to TDC and pull the Dizzy, hoping that it is just the dizzy gears. You can replace just the gear if every thing else is good. But then your back to how it happenend??? If it was the backfire then it probably slipped the timing chain. I was asking them to check for fuel injection first because it can be an added nightmare to have FI problems after replacing a timing chain???? So hey, if it's 40` off then something is broke! Last edited by Bill Wheats : 06-25-2008 at 04:12 PM. |
#104 |
Who says you can't move the "Dizzy" BODY? Show me where it says that? Irregardless of where that rotor drops into the motor, you CAN move the Dizzy BODY! to line things up!, it may not face directly forward, and not be pretty, but you can rotate it any way you want, as long as the rotor lines up with the #6 inside, and it doesn't bump into anything around outside it physically. Maybe they moved the Dizzy body already, when messing with things??? The original poster needs to do this now, and try it!
#105 |
I thought 96 through 99 they were locked????
I must be wrong??? |
#106 |
Is it getting fuel? If not The vin code Ws have a spider injection under the plastic intake may want to check in to that. And when i put my new motor in my 99 i had my timing just barely off and it would not fire.
#107 |
The dizzy housing cannot be moved. It bolts into one location and that's it! No adjustment! The only thing movable is the gear teeth, and only one particular tooth on the dizzy fits between 2 mating teeth on the camshaft. Anything else and the cam position sensor will throw a code.
#108 |
then my old school ways, are goin down the tubes! If so, then the rotor is in the wrong place in the O.P.'s Pic?,,,, and if the Dizzy hasn't been taken out, then,,, UHOH!!!,,, maybe serious work needed Or, if he gets lucky, the pin thru the Dizzy shaft sheared, not so bad!P.S. If all was well, all he'd hafta do, is pick up the Dizzy, set the rotor to where it belongs, then drop the Dizzy back into it's "particular spot!" and bolt it down, Wallah, Done! Last edited by MikDee : 06-25-2008 at 06:48 PM. |
#109 |
Most small blocks didn't have plastic manifolds either. I do believe it's been said before by there is a tab on the dist housing that fits into a slot in the manifold.
#110 |
Wire Splicin Fool :-)
Dont know if it has been asked have we tried turning the rotor by hand back and forth to see if there is any slop on that end?
#111 |
If he's lucky, they broke the gears in the dizzy when they were replacing the parts. But my best guess was that when they crossed some plug wires, they got unlucky and slammed a piston backwards and broke a tooth and the chain slipped when they tried to start it. Won't know until they pull the dizzy. I doubt they will crank the engine backwards to measure slopp. It's also possible that someone earlier reinstalled the dizzy wrong and just rotated the wires and got the spark to line up to the right cylinders. Kind of a hassle with that cap... |
#112 |
Was talking about grabbing the ROTOR bug in the dizzy and trying to rotate it back and forth to see if there is slop/ turnage.
#113 |
No. I was taking about cranking the engine backwards till the rotor starts moving the other way.
If there isn't any slop and they pull the dizzy and the gear isn't shot, then they might not have a timing chain issue.... Of course I don't know what issues they had before they started giving it a tune up, or what history that dizzy has. |
#114 |
Well Hush my mouth! I never saw a Dizzy I could not turn in these Chevy motors
Man I'm gettin old! It seems they eliminated the "Dummy Factor" of putting the Dist. body, or rotor, in the wrong place! Not a bad thing, all you hafta do now is just make sure the rotor is dropped in to match the Dist. #6 Mark. That's Cool, But the fact that the rotor is way off in this case, means that if no one had the Dizzy out, either the shaft pin sheared, or a bit worse, the Dizzy gear is stripped, (I doubt the cam gear is damaged, they're pretty hard) or the timing chain slipped, or broke? I'd pull the Dizzy to check the shaft pin and gear?, if not that, I'd look inside with a bright light, to see what the cam gear looks like, then if not that, I'd assume there is something wrong at the camshaft chain, & gears, the next place to open up, & take a look! |
#115 |
The dizzy gears are made of nylon or plastic so that if something has to break it's the dizzy gear that is easier to replace.
As for it being off, I'm not sold on any of their tests yet. I really would not be surprised it the router is pointing to #3 because ther were on the exhust stroke instead of the compression stroke. Tuff troubleshooting over the net. It's easy to overlook what I might consider the obvious! I wish them the best, but the whole problem could have been that one of the sensor wires got nicked and popped a fuse after replacement. Or worse... |
#116 |
#117 |
Your right. I was just pointing out that I'm not taking anything for granted until the dizzy is pulled.
#118 |
#119 |
Could change the oil and see if there are any plastic pieces in the oil.
#120 |
Just mark the stupid thing good and pull it already!
#121 |
Bump
#122 |
Why? We'll never know until the OP comes back.
#123 |
Sorry for the delay in getting back here.. been super busy all week.
The distributor was pulled, and looks great, except for the broken ear. Next we are going to pull the timing cover, and check the timing gear/chain, I can only think now for the timing to be so far out of whack, that ot skipped a tooth or two, or the chain just stretched so much. Will let the thread know as it gets torn down to that point. I have heard the stock timing sprocket is plastic on these... |
#124 |
#125 |
All the fuses were checked as well, and found to be good. Not just visually checked either, we did a meter test on all of them. |
#126 |
I guess the pin through the Dizzy shaft is good? Did you try putting the Dizzy in with the rotor pointed at #6, and see what happens, if all seems ok?
I don't think the cam timing gear is plastic on these, (I could be wrong though?) as far as I know, Chevy went back to steel gears, back in the mid 80's because they had too many problems with the plastic gears (originally, it was made plastic for noise reduction )One more thing, If you take it apart to check, & fix it, make sure the engine is setup to fire Cyl. #1, instead of Cyl. #4, The crank timing marks will show TDC for either one, because the cam only turns 1/2 as much as the crank, so each revolution of the crank TDC will come up on #1, then #4, etc. Or on #4, then #1, etc. it can get confusing, but if you find it does not run, you can just take out the Dizzy, and give the rotor 1/2 a turn, & put it back in there, it will be right. |
#127 |
Mike I think he was talking about a plastic cam gear to dist gear, you never know tho, these do use metal gears and chain for camshaft to crank. The tensioner may have given way and let the chain slip, like I said earlier it is doing what my '87 grand am did when it jumped cam timing. New gears and chain/ damper it worked good for what it was.
#128 |
Thanks for making it back here. This thread has sparked my interest.
I'm glad that you rechecked the fuses. I hate to see someone pull their timing chain just to find that it was a fuse due to a wire getting pinched. Having No slop when you cranked it backwords is a good thing. You may not have to pull the timing chain. The broken gear might be the extent of the damage. Please keep us posted |
#129 |
He said broken "ear"??? Does that mean the part that you screw the Dist. cap onto, (the ear) or did he mean "broken gear"??? If it's a broken gear, Thats it! Fix that, and he's done, I'd think.
#130 |
Broken "Ear", part that the dist cap screws onto. |
#131 |
OK. I guess I missed that earlier. That would explain why the dizzy gear is trashed. I didn't see any damage to the rotor in that pic???
