1997 Blazer - Hard Start & Rough Idle - S-10 Forum
post #1 of 3 Old 11-10-2005, 10:42 PM Thread Starter
User is: tlksanchez is offline
Hello All,
This is my first time to this site and hope I can get some help for my Blazer. Problem: At startup I have to crank it 2 or 3 times before it starts, and after it starts it idles a bit rough. I have change spark plugs, wires, distributor cap, rotor, gas filter, coil, air filter, ran seafoam to clean the injectors, and nothing seems to fix my problem. I have noticed that once it turns over and I shut it off and restart it right away it will crank right up, time and time again, but once it sits for about 5 minutes it will give me trouble again.
Truck has been running like this for about a month, any ideas??
Thanks!
post #2 of 3 Old 11-11-2005, 12:41 AM
User is: drdd is offline
Re: 1997 Blazer - Hard Start & Rough Idle
I'd start with the cheap stuff ...
I'd start by cleaning the IAC ...
then ...
clean MAF
clean TB butterfly
replace PCV valve
have you ever replaced the ignition switch? it's not a matter of if ... it's a matter of when ...
what brand plugs are you using?
Originally Posted by tlksanchez
Hello All,
Thanks!
drdd is offline
post #3 of 3 Old 11-14-2005, 12:05 PM Thread Starter
I've cleaned out MAF, TB Butterfly, replaced PCV valve, replaced Ignition Control Module, MAP sensor.
I know this is probably an ignorant question bu what does IAC stand for? and where would I find the Fuel Pressure Regulator?
