1996 S10 4.3L Cooling System Help! - S-10 Forum
post #1 of 13 Old 08-16-2010, 07:40 PM Thread Starter
Sgt. Stv-LoNowitz
stv-lo's Avatar
User is: stv-lo is offline
Send a message via AIM to stv-lo
I realize I posted this in the 4.3L section, but I'm hoping it will get some good traffic and advice in here. i need the truck for tomorrow and was going through roughly 1+ gallons a week.
Had a coolant leak from the front of the truck, saw a couple of cracks in the radiator so I went ahead and replaced the radiator and the upper and lower hoses. Now I have a leak from somewhere in the back of the block, it runs down the transmission. It's not a drip but a steady stream, someone help me quick. Any help PLEASE!
Stephen
stv-lo is offline
post #2 of 13 Old 08-16-2010, 07:46 PM
No More SS
SmokeeJay's Avatar
User is: SmokeeJay is offline
Re: 1996 S10 4.3L Cooling System Help!
Well, it sounds like an intake gasket to me.
Jason
Sold on 12/7/10 97 SS - 5/6 drop, 225/60/15's on swirlies, Shaved TailGate, Flowmaster, Kicker 10" Sold on 12/7/10
01 2dr Blazer - Daily Driver - 3/4 drop, 225/55/16's on 1st gen ZQ8's, Kenwood 200 watt amp/10" Sub
post #3 of 13 Old 08-16-2010, 07:47 PM
This is doo doo baby!
wildman ss's Avatar
intake gasket?
i believe coolant in the back is a symptom of that but I could be (and most likely) wrong
edit: damn you jason haha
Classy Chassy
wildman ss is offline
post #4 of 13 Old 08-16-2010, 07:54 PM Thread Starter
Sgt. Stv-LoNowitz
stv-lo's Avatar
Any clue on how much that runs?
Stephen
stv-lo is offline
post #5 of 13 Old 08-16-2010, 07:58 PM
SMURF
ridinlow's Avatar
User is: ridinlow is offline
I had the same problem a few months ago and it was the head gasket on mine. When i took the head off there wasn't nything left of my old gasket.
ridinlow is offline
post #6 of 13 Old 08-16-2010, 07:58 PM
wildman ss's Avatar
not off the top of my head
also check the heater core lines, I thought i needed a new intake gasket but I actually had a cut in the line going into the heater core and it blow out coolant under load.
Classy Chassy
post #7 of 13 Old 08-16-2010, 08:03 PM Thread Starter
Sgt. Stv-LoNowitz
stv-lo's Avatar
It leaks with just the truck running, no extra load needed, and the heater core was just replaced 2 winters ago, with new lines and everything so not that.
Stephen
stv-lo is offline
post #8 of 13 Old 08-16-2010, 08:52 PM
VA_ZR2's Avatar
User is: VA_ZR2 is offline
check your oil to see if theres coolant in your oilpan
if there is it's 99% likely your intake gasket, which is a $30 dollar fix (if you do it yourself)
VA_ZR2 is offline
post #9 of 13 Old 08-16-2010, 08:56 PM Thread Starter
Sgt. Stv-LoNowitz
stv-lo's Avatar
No coolant in the oil, just changed that last weekend (August 7) and it was clean as a whistle.
Stephen
stv-lo is offline
post #10 of 13 Old 08-16-2010, 10:17 PM
Black SS
97S10SS's Avatar
User is: 97S10SS is offline
Send a message via AIM to 97S10SS Send a message via Yahoo to 97S10SS
Its impossible to diagnose over the internet. You need a pressure tester and a good set of eyes. The replies give you a few places to start looking though.
Chris
1997 Chevy S10 SS: K&N Fipk, JBA Headers, SLP Y-Pipe, SLP 1.6's, Flowmaster, Hypertech, Line-X, 2/2 Beltech Drop. Stereo, Shaved tailgate handle, SS mirrors, 98SS front end, New style ZQ8's and 18inch BC Smoothie 2's, Zexel, 15.15 @ 88.53, 1/8th: 9.606 @ 70.3 http://www.cardomain.com/memberpage/243426/1, www.BassCat.com
97S10SS is offline
post #11 of 13 Old 08-16-2010, 10:20 PM
terrible. take a lap.
joyride's Avatar
User is: joyride is offline
Send a message via AIM to joyride
i would assume its most likely intake gaskets...ive done 3 now, my bros s10, mine, and my friends...and i guess my moms yukon if you wanna count a v8 vortec too...just take a day off and spend it replacing the gasket...
Brian
01 xtreme 4.3L 5spd 2/3 drop w/ SS front bumper|.030 over|270 comp cam|500 lift|dual valve springs|10:1 C/R|p&p heads w/ 3 angle valve job|w4me tune|shorty headers|2.25 y pipe|no cat|Spintech muffler|windage tray|LW flywheel|DF clutch|8mm wires|no ac|efan|walbro 255|MPFI upgrade|Comp Cam timing chain|ARP bolts/studs|totaled***
Now owner of a white 2002 Blazer Xtreme
http://www.youtube.com/watch?v=CO_A1IrbQNM
85 Monte Carlo SS
KCCO
joyride is offline
post #12 of 13 Old 08-17-2010, 10:26 AM
No More SS
SmokeeJay's Avatar
I didnt even think of heater lines/core, but all that is right there also.
Jason
post #13 of 13 Old 08-18-2010, 08:53 AM
minimum wagn' it to glory
DCsdime16's Avatar
User is: DCsdime16 is offline
autozone intake gasket- $24.99
