01 4.3L HT6 Compressor Clutch Replacement: HELP!
Old 11-10-2009, 07:57 PM   #1
Hey guys, I have a 2001 Jimmy with the 4.3L and the A/C clutch bearing is squealing like a stuck pig. Has anyone here changed one of these out? I'm trying to find out the best way to swap just the bearing in the clutch, I can't afford buying a whole clutch right now. The Haynes manual is completely useless: it doesn't even have a section on A/C clutch removal, just the whole compressor.
My questions are these:
1.) I know there is a special threading tool for removing the clutch, but what about the bearing? The shaft looks too small to get a 2 or 3-jaw puller in there. Any ideas?
2.) I have been told that there is a seal on the back of the clutch behind the bearing that must be removed first. I heard it is real easy to break this seal. Is this true?
3.) Nobody lists this seal so I can't have a replacement handy while I am tearing this thing apart. Anyone have a number?
