'01 4.3 into an '85 replacing 2.8: questions
I am looking at a very very clean, i believe a 2001 4.3 vortec engine for 500 bucks.
I've got a standard bellhousing 700r4 that I will need to rebuild and get a new converter for. As far as the engine, I'm not sure what all I am going to need for it and any help would GREATLY be appreciated as I am on a short time limit, BUT, I will in the mean time search for more answers. I will need an Edelbrock carb manifold, but which one? I will need a flywheel, I think? Will I need new exhaust from the manifold down the the cat? Will my hei distributor work? Any frame work for the motor mounts? |
goin broke but n style
Re: '01 4.3 into an '85 replacing 2.8: questions
nothing on/for your 2.8 will fit that 4.3.
you wont need a flywheel unless you go manual trans. if you go auto trans you need a flexplate. going to a bigger eng you will have to redo the exhaust. if go carb you will need a 500 cfm carb and NO bigger unless you want trouble. you will need a HEI dist for a 4.3 V6. according to edelbrock website it looks like a 2111 intake for a vortec 4.3 V6 is what needed. good luck with your swap. |
thanks for the reply. since i posted that, i've searched the forum and found that it's going to be a draw pretty much on either going with a 4.3 swap or dropping in a rebuilt 3.4.
i have a tranny that i could rebuild and use with the 4.3. i also have an extra 60* tranny also, which would need a rebuild. it's pretty much a toss up and i think i might stick with the 3.4 for ease of install. |
3.4 would be better since its a 60 degree eng.
going to a 4.3 IMO would be a waste. if you gonna go thru the trouble of swapping a 4.3 than go V8. same MPG and same headache of 4.3 swap, plus you get that V8 rumble. lol |
| Sponsored Links | |
Advertisement | |
