won't restart
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 06-22-2009, 03:35 PM   #1
won't restart
s10 dies and won't restart sometimes for hours. anyone have this problem before if so some fix's please
Old 06-27-2009, 12:54 PM   #2
Re: won't restart
i had the same problem a few weeks ago. is it missing any? mine was missing really bad and it ended up being the ignition module under the distributor cap. but i think mine is still missing a little.
Old 06-27-2009, 10:38 PM   #3
83S154x4's Avatar
Re: won't restart
there are way too many possibilities to list. You're gonna have to explain that further. does it get gas? does it have spark? is it when it's cold or hot? Mornings? Wet outside? does it crank? Battery voltage good? DO YOU HAVE GAS?
Old 06-27-2009, 11:37 PM   #4
Re: won't restart
yeah when mine did it. it wasn't getting spark. cause the ignition moduel was bad and for the same reason it wasnt getting gas. i guess cause the ignition module wasn't sending a signal to the computer to tell it to turn the injectors on.
Old 06-27-2009, 11:42 PM   #5
Local Tech
ls1s10onair's Avatar
Re: won't restart
better question..... does it crank, or no? if not, maybe the starter is heating up, and drawing too much amperage.... or you have a problem like the ones stated above
Old 06-27-2009, 11:52 PM   #6
Rebel_US's Avatar
Re: won't restart
not enough given information to even begin to start on this one.
Try reading this forum as your answer is probablly already here
Old 06-28-2009, 02:52 AM   #7
Ticket Magnet
Rhotpursuit's Avatar
Re: won't restart
There is enough info...been there done that, got the shirt...ignition module and or pick-up coil (not ignition coil).
Old 06-28-2009, 03:04 AM   #8
Certified Auto HVAC Tech
layinlow88's Avatar
Re: won't restart
Gonna have to say yes....also got the tshirt...these are known for going bad on these trucks....and whats even better..its a cheap and easy fix
Old 06-29-2009, 01:08 AM   #9
Rebel_US's Avatar
Re: won't restart
not enough poon tain or beer.....
aliens infected your intake and decided to cut ya out - oh damn, I was supposed to put gas in it.
it's broked I dont work - I dunno what wrong whit it.
Old 06-29-2009, 12:13 PM   #10
Re: won't restart
Quote: Originally Posted by Rebel_US
aliens infected your intake and decided to cut ya out .
PROBABLY
Page generated in 0.57313 seconds with 31 queries
[Output: 68.08 Kb. compressed to 63.65 Kb. by saving 4.43 Kb. (6.51%)]
