Where the frick is the ignition coil???
I guess I can forget about finding the negative side of the ignition coil, if I cant even find the damn thing. Trying to hook up a tach since my gay factory one is fubar and reads 5000 rpm at 60 mph , and 2k at idle.
Its that little black cannister looking thing with the two plugs on it, right??? How am I supposed to know which is the negative side when theres 4 or more wires on it. Haynes manual helps 0%. I swear im just gonna light it on fire, not once has it helped the slightest bit, on any vehicles I have had! 87 s10...input is appriciated. thanks guys. |
Re: Where the frick is the ignition coil???
The haynes manual is good, I really don't understand why so many people have issues with the Haynes manuals, I use then frequently.
If you don't have a DMM, or know how to use one, or even how to identify an ignition coil, I suggest you either put the tools down, and do more learning about automobiles, and/or have someone else do this for you. |
It should be at the left rear of the intake. behind the Throttle body. You'll have to remove the breather to see it good. That's where it is on mine.
I have rebuilt my TH350 on my k5 with my uncle, helped with a clutch, put in my transmission, tcase, did half of a head gasket replacement, wire trailers at work... but I have never done anything with the ignition except wires and plugs, a friend did the distributor cap and rotor when I went for a drink so didnt see the insides of that, if thats it. I have complete dealer service manuals for our 98 K1500.. I wish I had some for the S10. Haynes isnt good for anything other than toilet paper, and even at that it is too dry. BerryB: Ill try again in the morning, its the one with the two plugs correct, not the dist cap? Where would the negative side/terminal be? Ill also consult my 98 service manuals and see if they help at all. Thanks. Last edited by Morgan89 : 09-07-2008 at 06:28 PM. |
life begins @ 20 psi
Yep, you are looking at the ignition coil. All you have to do is follow the wire that is in the center of the distributor cap to where it ends... With regards to hooking up an after market tachometer and tapping into the negative ignition signal, check out my post here.
it really is
heres some pics
![]() now its red ![]() in the first picture you can see the green wire on the right connected to a connector with a white wire, thats how my tach is hooked up. so the white is negative Last edited by dimerunner88 : 09-07-2008 at 10:44 PM. |
. Especially on stereo installs and trailers.Looks like you a coolant leak in that quick disconnect fitting on your manifold. The guy who designed that should be made to remove every one that breaks off when you mess with it . |
it really is
Thanks for the replies and pictures, im about to check out the thread.
I work at a Uhaul center and we use the scotchlocks on truck and customer trailer wiring, but not on the trailers. What about them do you not like? Im still kinda new to wiring, what would your prefered way be to do it? a butt connector with 1 into 2? I did my radio 1-2 connecting it to the ciggarette lighter, but used an inline fuse. I actually hooked up the power and the memory wire into it so the radio can be turned on at anytime. Got a 20a fuse in it, plus the cigg lighter fuse. Works great with a yellowtop at mud bogs and other events, with no worry of leaving the key in the ignition for somebody to drive of with. Edit- The thread link... You said the grey connector, while dimerunner has it hooked to black. Whats the difference? Also, where did the term "dime" come from when refering to s10s..? never heard that before here. Last edited by Morgan89 : 09-08-2008 at 08:47 PM. |
Scotch locks will actually cut the conductor (copper) strands and make the wire physically weaker.
The fact that the insulation is cut without being sealed will let moisture in, and cause the wire to corrode and lose connection. Under the hood is especially a poor place to use them, the only worse spot is under the vehicle where direct ater contact is imminant. I've repaired so many connections that used these, I have to wonder why they even make these. I'll say it again, if you can easily look under the hood of one of these trucks and in a matter of seconds be able to identify where the ignition coil is, then you should have somebody do it for you, or have somebody there WITH you while you're doing it, that knows what they are doing. |
paint color? ... Mud =D
i think he got a little confused because the ignition coil does not look like a regular ignition coil with the tall canister and the plastic top on it
it really is
