Whats the crank fuse do? - S-10 Forum
post #1 of 15 Old 02-06-2011, 05:44 PM Thread Starter
User is: umskittles is offline
Okay so I was checking for power on all fuses and everything checked out except the crank fuse :/ What does it do and do you know where the wires go and come from?
post #2 of 15 Old 02-06-2011, 07:10 PM
User is: The_Raven is offline
Re: Whats the crank fuse do?
It sends a crank signal to the ECM, while the key is in the start position.
'Bu: The daily driver
post #3 of 15 Old 02-08-2011, 02:07 PM Thread Starter
So if there is no power to the fuse it wont start?
post #4 of 15 Old 02-08-2011, 03:50 PM
S 10 NOOB
User is: ghost87 is offline
Send a message via AIM to ghost87 Send a message via MSN to ghost87 Send a message via Yahoo to ghost87 Send a message via Skype™ to ghost87
the motor cranks right? And it says a fuse amperage right? So put a fuse according to the amperage in there and see what happens. Thats all that I can really say.
Not only that you might have some electrical issues.
ghost87 is offline
post #5 of 15 Old 02-08-2011, 06:46 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
The CRANK fuse will only have power when the engine is cranking(start portion of ignition switch).
Power flows through the ignition switch in the start position, through the neutral switch(manual)to the starter and crank fuse then to the ECM from the crank fuse.
It is a 5A fuse in the fuse block.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #6 of 15 Old 02-08-2011, 07:37 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
Powers the solenoid on the starter when key is held to start. Fuse blown, no power to coil on starter solenoid.
lesterl is offline
post #7 of 15 Old 02-09-2011, 09:30 AM
Uhh, no.
It is simply a connection, split off from the starter wire from the ignition switch that connects to an ECM input. The truck will still crank without that fuse, just the ECM doesn't use the start tables when that is not enabled and may have difficulty starting.
post #8 of 15 Old 02-09-2011, 05:40 PM
lesterl's Avatar
Raven, my bad, I've been over my schematics so much I could have sworn I have seen that in the ign circuit feed, went and checked, the only thing I have is a schematic of it in the block but they dont show where it goes, Guess with a 3 amp fuse it wouldnt be a solenoid fuse anyway......
AFAIK, the ICM has built in start tables and when it detects the engine fire it hands over control of the ignition to the ECM..... AFAIK....... But I dont know about fuel control either.
lesterl is offline
post #9 of 15 Old 02-09-2011, 06:02 PM
The ICM doesn't have any "tables" built into it, though there is some measurable latency that varies with RPM an is different between different ICMs.
It is actually the ECM that sends a signal to the ICM for it to take over timing control, this is a 5V signal applied to bypass wire to allow the ESC signal to become active.
Some MS users have played with having the 5V signal active as soon as the key is turned on, to be able to adjust spark timing during cranking, with some success.
post #10 of 15 Old 02-09-2011, 07:14 PM
lesterl's Avatar
Cool....
lesterl is offline
post #11 of 15 Old 02-09-2011, 07:53 PM
jtcfanof3's Avatar
I will post a nice schematic from Mitchell in a bit.
post #12 of 15 Old 02-09-2011, 08:54 PM
lesterl's Avatar
Cool, mine suck.....
lesterl is offline
post #13 of 15 Old 02-09-2011, 09:03 PM
jtcfanof3's Avatar
This is the starting system diagram for an 1988 S10(random choice).
post #14 of 15 Old 05-18-2016, 11:56 AM
User is: pam11498 is offline
I have a chevy cavalier 2002. Upon backing into my driveway the engine shut off. The gear shift locked in park. When I tried to start the car nothing happened except the dash went dark. When I turned the key to just on, everything came on on the dash however when starting the engine never cranked. We looked at all the fuses, and saw where the crank fuse #360 was, however the car has new battery and was running fine before I got home. What does the crank fuse do and if it is not any good is that the reason the engine will not even crank? Just some low clicking but no crankingl
pam11498 is offline
post #15 of 15 Old 05-19-2016, 12:22 AM
You'll be better off getting information from a Cavalier forum than here, because the crank fuse in an S10 serves a different purpose than the crank fuse in a Cavalier.
