What can i exspect
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 11-02-2009, 05:04 PM   #1
What can i exspect
I have a 93 2.8 s10 and i have a spectre tbi plunem with duel inlet that i was going to plumb a dual cold air intake with aluminum piping, then i ordered a jet chip 6 pack performance module and i have flowmasters already. Will there be noticable performance gain?
If so how much horsepower gain approxametly?
Old 11-03-2009, 12:29 AM   #2
first car and proud
93v6banger's Avatar
Re: What can i exspect
sorry i can't answer your question, but where did you get the plenum for the 2.8 from?
Old 11-11-2009, 04:23 AM   #3
To be honest, probably not. I also have a Flowmaster 40 series single inlet to dual outlet, and although it sounds pretty beefy, there is no noticable hp gain. The chip from what I've heard from other threads is a complete waste of money, the cold air intake may give you a couple ponies at best, and I never even knew they made a plenum for the 2.8 motors. Not trying to be a buzzkill, just telling you what i've heard. However, I came up with an idea for a dual air intake using the existing air cleaner, but again, mainly for show and not for go. Good luck to you!
Old 11-11-2009, 05:28 AM   #4
4x4 v6 blazer
neo71665's Avatar
I think he just means the TB hat and its neck is the same size as a normal 4 barrel carb or any other 2 bbl TB out there.
Page generated in 0.56504 seconds with 31 queries
[Output: 50.06 Kb. compressed to 47.74 Kb. by saving 2.32 Kb. (4.63%)]
