Truck wont start back up after getting warm - S-10 Forum
post #1 of 25 Old 05-13-2010, 03:25 PM Thread Starter
Jayrod864x4's Avatar
User is: Jayrod864x4 is offline
Question Truck wont start back up after getting warm
So heres the lowdown 2.8 4x4 4 speed If the truck gets up to operating temp and i shut it off and try to start it it will turn over but not run. I have spark and it looks like i have fuel the tbi is wet after trying ( hard to do with only me working on it) any Ideas im baffled
post #2 of 25 Old 05-13-2010, 04:15 PM
1989redneks10's Avatar
User is: 1989redneks10 is offline
Re: Truck wont start back up after getting warm
My truck did the same thing, come to find out the coil was getting hot and breaking down. Sounds weird, but that is what it was. I got a new coil from oreilly auto and it's just fine now. Hope that helps ya out.
89 Shortbed 2.8 5 speed
post #3 of 25 Old 05-14-2010, 01:40 AM
Budget Ballin FTS!
BrandonR's Avatar
User is: BrandonR is offline
Same problem here..... and the bad thing is that after about a year your gonna have to get another one.. so keep the reciept.
2001 4 door blazer All brand new suspension, bagged
BrandonR is offline
post #4 of 25 Old 05-14-2010, 02:20 AM
i saw what you did there!
fast68chevy's Avatar
egr or module
one or the other probably
although a dying module usually causes the engine to stall when hot and running., and no re start of course.
if its the module then use lots of dielectric grease when installing the new one
post #5 of 25 Old 05-14-2010, 12:17 PM Thread Starter
Thanks for the advice gonna try the coil, its never stalled as long as its kept running it will go for hrs, if that dont work i will be back.
post #6 of 25 Old 05-25-2010, 09:30 PM Thread Starter
Still F-ing doing it left me sitting any other ideas??
post #7 of 25 Old 05-26-2010, 11:16 PM
User is: crash55 is offline
have someone watch when you turn it over is the crank turning ? mine had a bad ring gear on the fly wheel that only did it when warm. had to push & dump the clutch till I fixed it
crash55 is offline
post #8 of 25 Old 05-27-2010, 06:07 AM
User is: secondgencamaro is offline
Ignition control module.
'76 Camaro 400ci - TH-350 - 3.08:1 - 3,760lbs w/o driver
'93 S-10 3.4L - std cab - short bed
post #9 of 25 Old 05-27-2010, 06:09 AM
post #10 of 25 Old 05-27-2010, 08:59 AM
Mr. SQ
bobditts's Avatar
User is: bobditts is offline
could be a whole number of things. Mine was doing the same thing, but thats becaues I forgot to plug the EGR solenoid back in when I reinstalled my engine.
bobditts is offline
post #11 of 25 Old 06-05-2010, 11:50 AM
have you found out what was wrong yet ?
crash55 is offline
post #12 of 25 Old 06-05-2010, 01:57 PM
joed's Avatar
User is: joed is offline
possible: coil overheating/due for replace, fuel filter or pump going,
1985 Black Chevy S-10 v6 2.8L 4x4
Rochester 2se carb
joed is offline
post #13 of 25 Old 06-05-2010, 04:10 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Check the ignition module and also the wires that go from the coil to the distributor for damage. Is it carbed or injected? My 01 acted similarly when the pump started to go. Good luck.
1984 xcab s-10 3.4L GM crate engine 87 S10 TBI swap w bored intake, Edelbrock headers. 3.42 locker rear end swap. Flowmaster, shift kit, e-fan.
EFI swap http://www.s10forum.com/forum/f106/c...e-help-513616/
My build thread (3.4L)http://www.s10forum.com/forum/f106/b...stions-427168/
I had to cut my nut in half .
post #14 of 25 Old 06-06-2010, 03:19 PM Thread Starter
replaced the ignition module and it still does it sorry for the lack of updates i work the graveyard shift the fuel pump works just not sure what the pressure is and its injected. O and i was driving down the highway today and it up and died no power its sitting in the driveway with a battery charger on it at the moment.... any other ideas??
post #15 of 25 Old 06-06-2010, 03:41 PM
joed's Avatar
You replaced the ignition module before checking things further? (not that it couldn't be the culprit of course)
driving and cutout again?
What does "Im gonna try the coil" in your response mean?
(did you buy a new coil? it's not mentioned), buy a new coil. first check coil to dizz wire, and fuel pump. btw: How are you verifying "the fuel pump works" again?
Rochester 2se carb
joed is offline
post #16 of 25 Old 06-06-2010, 03:54 PM
Yep, I had a problem with my 01 with a check engine light that I couldn't get to go away because it was throwing a false code. Replaced the module after exhausting every other avenue. Unfortunately it didn't fix it. Truck runs fine...great even...the light can stay on with its BS code for the oxygen sensor that doesn't exist. Point is, it was a waste of money (although I have a spare). They can test those at Autozone or Advance.
I agree with Joed. It is VERY common for coils to cut out when they start to break down. They exhibit the same symptoms you are talking about. They're cheap, so I would go there if you haven't already. It's usually the easy stupid stuff on an issue like this. As tinkerers, we sometimes like to overcomplicate it.
post #17 of 25 Old 06-06-2010, 08:43 PM Thread Starter
i did replace the coil first. then the ignition module. and to test the fuel pump i jumpered the fuel pump relay and saw fuel in the throttle body. i will test the fuel pressure in the next couple days.
post #18 of 25 Old 07-06-2010, 02:26 PM
User is: DarkMatter is offline
I have a similar problem, but I don't believe it's the fuel or ignition. My 2.8 89 S-10 barely turns over when it gets to operating temp, yet I can jump start it in 2nd gear and it runs just fine. I have a feeling that the starter might be getting too hot from the exhaust, then taking a huge power draw to barley turn it over. I was thinking of building a heat shield for the starter. Any other ideas or related fixes?
Thanks in advance
Matt
post #19 of 25 Old 07-14-2010, 01:07 AM
daily dragger
1lowryd's Avatar
User is: 1lowryd is offline
i had a prob like that with an 94 s10.would start right up when cold.shut it off when it gets warm and it wont start just cranks.it was map sensor.replace it with a junk yard one and it been working great for 20000 miles.not sure if your has one but id look into it
LOW KEY, baltimore md.
1lowryd is offline
post #20 of 25 Old 07-21-2010, 09:01 PM
User is: wizdum is offline
Had a problem like this on my '87 s10. It turned out to be one of the three relays under the hood. I forget exactly what was causing it, but it was something along the lines of the oil thinning out when it warmed up was lowing the oil pressure and tripping some safety feature.
wizdum is offline
post #21 of 25 Old 07-22-2010, 07:40 AM
eyeswide99's Avatar
User is: eyeswide99 is offline
dude ig mod, regoop every tune up i have three s10 and ever f'in time the ig mod was the prob. careful with the wires they are exposed to too much heat this is the prob with the design it is a known prob amounst mechanics and i was told to maintain good gas miles to replace ever 30k
post #22 of 25 Old 07-22-2010, 09:09 AM
Mr. SQ
bobditts's Avatar
what is an ig mod?
bobditts is offline
post #23 of 25 Old 07-22-2010, 11:24 AM
Ford Diesel Tech
Curtis262's Avatar
User is: Curtis262 is offline
i just had mine doin that except when u shut it off it wouldnt turn over but as soon as i put a charger on the battery it started right up it was the starter solenoid when shut down it would get hot because of HEAT SOAK and not operate
91 S10 Forest green Metallic
saddle tan power interior conversion currently 3/3 dropped, 6k hid headlights and foglights, sittin on 17 inch eagle billetts.
http://www.s10forum.com/forum/f3/first-truck-424924/
The Club www.verticalobsessions.com
"Dont be racist, be like mario, hes an italian plumber created by japanese people who speaks english looks like a mexican, runs like a jamaican, jumps like a black man and grabs coins like a jew."
post #24 of 25 Old 07-22-2010, 07:13 PM
User is: onecrazyfoo4u is offline
I always heard that it was the temp sensor that goes to the computer. If it goes bad it then it still thinks it's doing a cold start and putting out too much gas, flooding the engine.
My truck also doesn't start when it's hot, I have to floor the gas to get it to start, then sit there for a minute burning off all the extra gas I flooded it with. I've got a new sensor, I'll let you know if it fixes it when I put it in this weekend hopefully.
post #25 of 25 Old 04-20-2013, 03:51 PM
70shorty's Avatar
User is: 70shorty is offline
Hey guy's,, I have 99 Blazer 4.3 with similar troubles, I replace the ign. module, coil, fuel pump module,still drive it for a hour or so,,, shut it off,, won't restart,,wtf.. let it sit for an hour it would start back up. ran fine for short trips but just not long, over an hour trips..could it be the spider?? or the pressure reg.??
70shorty is offline
