Timing Chain replacement
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 10-19-2009, 11:16 AM   #1
I changed my intake gaskets, and valve cover gaskets over the weekend. and while restabbing the dizzy we moved the crank back and forth to try and get it to drop, and we noticed the timing chain was loose. What all is needed to do in order to replaced the chain? Do I need to raise the motor? pull the motor? I was told I may also need to pull the front clip. is this true? thanks in advance for any help.
Page generated in 0.55818 seconds with 31 queries
[Output: 39.63 Kb. compressed to 38.37 Kb. by saving 1.26 Kb. (3.18%)]
