Mr. Clean
Throttle Body Rebuild - Hints, Suggestions
I just got done cleaning out my TB and I'm about to replace it. I'm also about to clean and rebiuld the fuel pressure regulator and install some new fuel injectors. It seems easy enough, but I just wanted to make sure. If you guys have any hints are secrets or things that I should be sure and do during the rebuild, please let me know.
I have all new gaskets and i'm planning on throwing a little grease on the throttle spring and maybe just a little on the inside of the new TPS...would that hurt anything? I'll try to get a couple pics, but the funny thing is....there wasn't a single bit of carbon build up anywhere on the TB or inside the intake. I've got 220K on my truck, I guess Berrymans and Seafoam do alot of good through the gas tank. |
Re: Throttle Body Rebuild - Hints, Suggestions
It's pretty easy. I just rebuilt mine today in the Advance auto parts parking lot. Don't give the star bolts too much torque, but make sure they are nice and snug.
Also make sure the diaphragm gasket is evenly seated around the metal or it will leak. |
CHANGE YOUR EMAIL ADDRESS
The diaphragm and O rings require close scruity or they will cause problems.
Mr. Clean
The FPR diapragm was a huge pain, but we eventually got it. The stupid thing kept flipping up and kinking a little on one side. If anything goes wrong when I start her back up...my money is on that. Well, I just got done putting her all back together. She's basically been sitting since early January when the fuel pump went bad. She's got tons of new sensors, seals and other parts so hopefully she'll come through for me. I'm so freakin nervous so I'm going to eat lunch and say a little prayer before I put the battery back in and try to crank her up. Last edited by EYEROCK89 : 02-23-2008 at 05:19 PM. |
I bought 2 kits,one for a 2.8 a one for a 4.3,one kit had a pair of "dowels" to locate the fpd in place during assy; so I saved them for furtur use.
Mr. Clean
Hmm, I guess it would have been a good idea to have asked what the dowels were for. I never even touched them thinking they were part of the kit for a different TBI. Oh well, hopefully I did alright.
How much are you guys spending on the rebuild I just got price of $250 for a swap out threw guaranteed carbs?
Don't buy a rebuilt tbi,if you can do it with minimal skill if you take your time.
Mr. Clean
Yeah, the rebuld was actually pretty easy. Here's what I did:
-disassembled TB, FPR and fuel meter. -soaked overnight in Chemtool parts cleaner -Used Q-tips and compressed air to clean and dry all valleys, vacuum ports, etc -Used dremel polishing wheel on all gasket surfaces -Installed new gaskets, tighted bolts to spec -Used a little tranny fluid on the injector o-rings. -Lithium grease on throttle spring So far so good..no leaks. |
Lock and Low'd
I am wanting to rebuild mine, and have no Idea what I am doing with a TB. Can anyone show me a diagram of whats what on a TB. Also who makes a good TB rebuild kit?
Low and Slow Sono
You guys think a rebuild would solve my problem??? Mine basically floods out at low rpm's but its okay after it gets tached up.
Registered Neanderthal
I've gotten a couple of TB's out of the jy, trying to find an up grade for my 2.8 but the linkage isn't the same. what do I need?
hey, you think a TB rebuild would help mine? It runs fine until it hits about 3/4 throttle then it starts running like shit and then smooths back out.
