severe engine miss and lack of power
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 06-14-2009, 11:10 PM   #1
well i found out why my s10 ran so poorly and had a severe miss today,it had a burnt valve,at least i bent valve and an egr valve that was stuck open,i was suprised because it appears to have had the engine remanufactered,the pistons were stamped 10 over and it was painted gray under all the oil leaks ,well i'm not sure what route to go on this thing because the valve seat in the head is really bad, and i dont wanna spend a small fortune rebuilding this lil motor.
Old 06-15-2009, 10:49 PM   #2
Z28Camaro's Avatar
Re: severe engine miss and lack of power
Get another running one on craigslist or pop a 3.4 in it
Old 06-16-2009, 12:09 AM   #3
i found another 2.8 on craigslist ,just gotta find the time to pick it up
Old 06-16-2009, 12:18 AM   #4
Z28Camaro's Avatar
You may as well look for a 3.4 you'd be happy with the swap
Old 06-16-2009, 01:51 AM   #5
34blazer's Avatar
a simple vavle grind and a new valve should only set you back 150 bucks plus gaskets. if the engine seems to be new then why remove it? the head is induction hardened and it penetrates about .010-.015 into the head. the seat may look bad but maybe not bad enough to lap in a new valve. so maybe grab some lapping compound and a new valve and fix it on the cheap
Old 06-16-2009, 08:53 PM   #6
i pulled the valves out today at work on my lunch break,and the one valve guide is broken and 3 othersare just as bad,i guess i'm goin to the u pull it junkyard this weekend to find a set of heads,
Old 06-28-2009, 10:53 PM   #7
well i had to pick up a motor last weekend and i pulled the heads off checked the valves everything looked good i put in new valve seals, and put the motor back together this weekend ,this little motor runs pretty good .
Page generated in 0.82487 seconds with 31 queries
[Output: 58.32 Kb. compressed to 54.97 Kb. by saving 3.35 Kb. (5.74%)]
