Rubber freeze plugs, good or not? - S-10 Forum
post #1 of 8 Old 03-26-2009, 02:50 AM Thread Starter
Awww..you ain't got shit!
jimmykicker's Avatar
Okay, I got a nice surprise from my 84 last night when I found one of the freeze plugs on the truck had bit the dust in the worst possible way. Tonight, I pulled the old rusty ones out, but I must say the one on the driver's side is really pissing me off getting it back in because the oil filter adapter is in the way (coming in from the wheel opening). I can't get the right angle because the motor is a vee, to get the plug started straight and now I am really frustrated. I got some of these rubber plugs. Anybody tried this? I don't want to get somewhere and that f**%ker blow out on me.
Either that or some advice on getting the steel ones back in. I got these from Advance. Are the dealer ones closer in size or any easier to get in? I already had one fail last year on the front of the motor, and it was pretty easy because it was a straight shot in. I used factory ones that time. Didn't seem this damn difficult. I'm not usually defeated by something as simple as this, so I'm more than a little ticked off. Thanks guys!!
1984 xcab s-10 3.4L GM crate engine 87 S10 TBI swap w bored intake, Edelbrock headers. 3.42 locker rear end swap. Flowmaster, shift kit, e-fan.
EFI swap http://www.s10forum.com/forum/f106/c...e-help-513616/
My build thread (3.4L)http://www.s10forum.com/forum/f106/b...stions-427168/
I had to cut my nut in half .
post #2 of 8 Old 03-26-2009, 03:32 AM
4x4 v6 blazer
neo71665's Avatar
User is: neo71665 is offline
Re: Rubber freeze plugs, good or not?
We ran one in a oldsmobile for about 5 years before the motor finally died and it lasted just fine.
As for replacing it with another one I'm sorry can't help ya. I've only done that with the engine on a stand.
87 blazer tahoe 2 door, 5.7, auto, sfa 4x4
91 noma reg cab, 3.4, 5speed, lowered
President of the Arkansas chapter Anti-bag Coalition
"Bags are for groceries"
Originally Posted by alarm_the_alarm View Post
Lift That Sh*t, Fat Girls Can't Jump
i just made love to your bowels......and then reported them.
neo71665 is offline
post #3 of 8 Old 03-26-2009, 03:33 AM Thread Starter
Just for sh$ts and giggles, I checked the outside diameter of the new plugs versus the old one. Granted, the old ones are distorted, but they measure about 33mm and the Dorman replacement ones are 34mm. According to the package 34.22mm. I think the factory plugs are actually somewhere around 33mm. Believe me, I think that 1mm makes a difference. I think it might be enough to be causing me all of this strife. What do you think? I'm going to the dealer tomorrow and buy some of their overpriced plugs, and I guess we'll see.
-james
post #4 of 8 Old 03-26-2009, 06:14 AM
paxter's Avatar
User is: paxter is offline
Can't you take off the oil filter adapter? You'll need a new gasket for it, but it's only 1 bolt and then you get straight on to the freeze plug.
paxter is offline
post #5 of 8 Old 03-26-2009, 06:24 AM
UN-BANNED B!TCHES!!!!!
NotaDime's Avatar
User is: NotaDime is offline
i use the brass plugs, they "bite" into the block as they go in creating a good seal.
also get a big socket the will fit inside of the plug with minimal play inside of it and tap the socket in and this will "press" the plug in evenly........
WTB cowl hood near valdosta GA NOW...
Seems like there are still a few people (Imperial, NotaDime, etc...) here that still have working brains.
Originally Posted by The Master View Post
BTW last post evar on this site. cheers and.....fock off.
Originally Posted by v8lonoma View Post
everything notadime said +1.
NotaDime is offline
post #6 of 8 Old 03-26-2009, 03:34 PM Thread Starter
Exclamation Re: Rubber freeze plugs, good or not?
I thought about that, but I'm not sure how much it will help. Besides, you have to jack the motor up and remove the engine mount bracket to remove the bolt in the center. Also, I have found that thing to be hard to seal, and I don't really want to fool with it.
I think those dillholes at Advance gave me the wrong plugs. Granted he gave me what the computer said, they still are about a mm too big.
Thanks for your input!
post #7 of 8 Old 03-26-2009, 11:28 PM
adamwilkes20's Avatar
User is: adamwilkes20 is offline
Dont ever trust guys at Advance or Autozone....I wanted to get my VSS the other day and the guys insisted that it went into the bellhousing...I just walked out.
post #8 of 8 Old 03-27-2009, 04:26 AM Thread Starter
I know better than that for sure, but for some reason, I didn't check them which was against my better judgment. I bought some today from the Pontiac dealer because the Chevy stealership didn't have any, and they are about a half mm smaller. Got one in on the driver's side in about 10 minutes with much less effort than the ones from advance. I have one of the rubber ones on the passenger side that I sure as hell don't trust, so I'm going to try to get the other one in there too. Thanks guys!!
-j
