problem after headers!!
Well i bought the truck then brought it straight home and started tearing it apart and working on it, I got a set of of headers and put on it, and never hooked the smog pump back up, i just pluged the hole on the passenger side header where the smog pump was suppose to hook in. Well i took it and had new exhaust from headers back NO cat into a spintec pro street muffler. But now it wants to surg at an idle like when u come to a stop sign or something it will almost die but never does! Could this have something to do with not having alot of backpressure? ive did a complete tune up plugs,wires,cap,rotor,coil, pcv valve oil change, seafoam thru the intake off brake booster, and recently some lucas in the gas and still does it! i just wondering if any of u guys have had this problem or maybe knows what it could be.. Thanks
Re: problem after headers!!
Replaced my headers as well and eliminated the smog pump by plugging the hole. The only difference between yours and mine is that I have a catalytic converter on mine. So its possible back pressure may be the issue in that case.
GRM Challenge Truck
sounds like a vacuum leak. check for that first.
also, did you disconnect the wiring to the smog pump? lastl, pull, clean, and adjust the iac. michael |
banned
did you touch the throttle control module at all?
Not shure i follow u there? and no i didnt unplug the pump? |
banned
its not a pump. The TCM is connected to the TBI
its called a smog pump!! lol
banned
sorry. I had the wrong term. Its called a TPS (throttle positioning sensor). Depending what year blazer you have, you might have an adjustable TPS. Did you happen to bump it, or remove it during your tune up?
its a 91 S-10 no blazer here
banned
well same engine. you still havent answered my quesiton though. Im just trying to help you out.
I had the problem before the tune up. I dont recall messing with it!
maybe a picture of one so i know what im looking for? i feel stupid asking that cause im really not that illerate! lol
Subsonic Kustomz
i highly doubt that its because of the back pressure i have headers, no cat, and glass packed thrush's and i run fine
Ok ill try to rule that out! |
check engine light on??
nop
banned
Yea ill look later but i dont think i have an adjustable one..
OK!! yes i do have the same tps as u posted in the link above. But i dont see how i could have messed any thing up, or messed with adjustment any
banned
I would get out the old dmm and make sure it is still adjusted correctly. It makes a world of difference if the voltage is off.
GRM Challenge Truck
hiw about checking the timing? fuel filter? michael |
Yes i put a new fuel filter and fuel pump on it in the begining. It really sounds like a vaccum problem but i can find it anywhere. Ive even takin the egr off and cleaned the ports. It does it the most when u just push in the clutch instead of down shiffing coming to a stop it will bog down and cut out and miss then pick back up rpm. If u dont shift and gradually bring down the rpms it wont do it near as bad? im going to get into it again tomorrow since i got the day off and see if i can figure it out! Any more suggestions will help. Thanks guys!! |
Ok guys thanks for the help! I think i got it fixed, it was what i thought all along but counldnt find.. Just a small vaccum line pulled off! It hasnt done it since.
