Matt Smith
Peep this thread you power hungry 60*s
http://www.s10forum.com/forum/f42/he...-share-420915/ I told em to post here as if it fits the tight spaces of a Bird/Aro, its easy peasy for our trucks. |
Registered Neanderthal
Re: Peep this thread you power hungry 60*s
That's some awesome 60* power and torque!
330rwhp and 450rwtq @ 9psi, so figure about 400 hp and over 500 ftlbs @ the crank, when reace seson starts back up ill be looking to put down in the neighbor hood of 450+ rwhp and over 525ftlb at the tires once i increase the boost level when i dynoed the cat the first time with the issues i had i.e no ignition advance/timming locked to 8* btdc and it wouldnt rev up over 5,1-5,300 ( cam is a 268/272 grind that should make peak power above 6k) i joked around saying i was going to pull the motor and buy a v6 blazer to drop it in to use it for tree stump pulling ![]() |
Matt Smith
OK some will ask, but he had first posted it in the off topic section, why I made this thread. But the mods deemed it fit for the real board n moved it here, so this thread is sort of useless now.
