oil pressure sensor/sending unit going bad
is this a common thing on the 2.8's for these to go bad? it still shows oil pressure about where i think it would be but i noticed a bad oil leak last week and tracked it down to be leaking out of the center on the sending unit mounted right to the side of the oil filter area.its a bad enough leak that it drips about every 10 seconds
Ticket Magnet
Re: oil pressure sensor/sending unit going bad
Define common...If it's a 2.8 it's getting pretty old and problems arise. Replace it and all will be right in the universe...
Honor, Grace, and Dignity
Its a piece of plastic that is close to 20 years old or older now that has pressure put through it everytime and all during engine operations. I would leak a little too at that age and mileage.
The casing is plastic. Do a search on here. The 4.3 and 2.8 are the same. Couple have a bit different plug in. Search key is your friend.
and im not a newbie to car forums i know about the search buttons, and i did try it though i probably must have missed an answer to this since you mentioned it sorry |
well, think of it this way: your working with alot lower pressures (50 tops?) than your bag system and dont have to deal with the 'hammer' affects of sudden pressure changes, well HOPFULLY dont have to !
And it's common for ALL parts to fail - why else would parts stores stock them? Your arguing about a couple of dollars worth of sensor. If it's broke replace it & move along in life. And I rather enjoy my 'tiny gutless 2.8' every time I pass a gas station, I would have especially after Katrina a few years back when I had to wait 2 hours to get gas for the car I had at the time and at 4 bucks a gallon. For a vehicle 23 years old, getting +30 MPG is rather sweet and I have enough left over after a fill up to get a 6 pack...causing the leaks mentioned in #3.... |
gas milage is nice, but the lack of power sucks. the 3.8 n/a motor 05 grand prix gets mid 30's on the mpg's regularly and it will put you back in your seat and will smoke the tires in first and 2nd gear. but in all honesty i didnt buy the blazer to go fast anyways, i bought it because its a 4wd and because these old blazers got a good reputation for being tough old beasts once you work out the bugs. someday this old blazer will likely see a 350 in it, but that not until the 2.8 either costs too much to keep going or dies on me(which might be a long time since it now runs perfect and even has 0 smoke on startup) |
Ticket Magnet
http://www.autozone.com/
search for OIL SWITCH dude - I see the switch alone for about 6 bucks...what did YOU buy ?? |
If you have the oil pressure gauge instead of the light then it is a comon problem for them to leak. I've put about 5 of them on my truck in the last 13 years. I found that the cheap ones will start leaking in a year or less. I buy the Borg Warner senders and they last a lot longer. They cost a little more, but it's worth it when you can just barely get to the thing to change it. I also have a 4X4, and it's not easy to get to it.
whoops - I just caught that, mine uses an IDIOT switch - yours might actually be a sending unit...my mistake.
rhot none of those listed in the link you put up looked to be the right one, the one i have is a 3 blade connector
gear head , yeah i have the guage on my dash not the idiot light. it probably would have helped if i mentioned i have a 88 blazer 4x4 and yes that is a major pita to swap out especially if the oil filter i just put on a month gets stuck on and i had to tear it up to even get it off! |
Should be part number PS252 and it has 3 prongs.
http://www.autozone.com/autozone/cat...uestid=2495152 |
New Kid On The Block
My oil switch went bad in my 91 s-10, replaced it, all was well afterwards. was a pretty cheap part aswell.
Just typed in 88 blazer 4x4 with 2.8 L and thats what it came up with. Call the store with the part number and see what they want for it. Then verify it fits that vehicle.
If you do it the other way around than it gives them the idea you dont know what you are talking about. Just say "Ok, and that fits an 88 blazer 4x4 with a 2.8?" Hope it helps. |
it probably didnt help when i was calling and asking for a sensor when it was technically a oil pressure switch. though that just proves that autozone and advanced are a bunch of idiots that know nothing about vehicles since the person i talked to at o-rieleys knew exactly what i was talking about with teh exact same description
