Oil Pressure Sending Unit - S-10 Forum
post #1 of 9 Old 01-13-2010, 03:15 PM Thread Starter
User is: missile150 is offline
Can anyone tell me what a 1986 S10 4x4 pickup with a 2.8l TBI engine has for an oil sending unit? My pressure is way over 80 when the truck is on, and goes all the way off when the truck is off. I am not sure if it has one, two or three connections on the sender. I have seen them all at the parts warehouses, and they range in price drastically depending on how many connections they have. And from what I have read, it seams to be a pain in the neck to remove and replace. How true is that?
1986 Chevy S10 4x4 with 2.8l TBI engine -- and new to this mechanic stuff.
post #2 of 9 Old 01-13-2010, 03:42 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
Re: Oil Pressure Sending Unit
It should be on the drivers side near the oil filter. It kinda aims towards the left corner of the truck. You should be able to see it from the top. It's not hard to replace. If you can get a pair of pliers around it, great. If not, you will need the sending unit socket to remove it.
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #3 of 9 Old 01-13-2010, 04:00 PM Thread Starter
Thanks, but do you know what type of connections it needs without taking it off? One, two or three plugs on the connector?
post #4 of 9 Old 01-13-2010, 04:57 PM
Works too much!
laydout97's Avatar
No I don't. My truck has a 3 wire sensor but it is also a 93. If your truck has an oil light, it is a 1 or 2 wire. If it has the gauge, then it is a 3 wire.
post #5 of 9 Old 01-13-2010, 06:19 PM Thread Starter
Thanks. It has the gauge, thus a three wire. Figures it has to be the most expensive of them all.
post #6 of 9 Old 01-13-2010, 08:10 PM Thread Starter
It is needless to say but this truck was not very well taken care of. Anyway, I actually looked at the sending unit, and it only has two plugs for it. I also did not notice a light on the dash when I started the truck, so I assume I only need another two wire one. However, the wiring on the unit is not there. I found a hanging arness with bare ends hanging near it with about 4 wires in it. (I told you this truck was not taken care of.) So my next question is can I run a wire from the dash to the unit then back to the dash for the unit to work? I know that the fuel pump works because the truck runs, so I was just going to try and complete some sort of loop. Also, does the pressure gauge read high with voltage on one side or with no voltage, hence the sender is not even hooked up? Thanks.
post #7 of 9 Old 01-13-2010, 09:44 PM
Datchevy2.8's Avatar
User is: Datchevy2.8 is offline
If it was me I would go to junk yard and cut the section I need from a donor truck and splice it on your harness. As far as the gauge goes I believe that it works off resistance in the circuit, no resistance (open circuit) it reads high.
85 2.8 4x4 pick-up,Edelbrock intake,cam,headers and weber carb, 5 speed, 3.73 posi
85 2.8 4x4 Blazer Stock as GM built it
86 2.8 4x4 Blazer,2" rancho lift, 4:11 posi, daily beater
93 4.3 4X4 S10 Excab
post #8 of 9 Old 01-13-2010, 10:31 PM Thread Starter
Good idea. Then I just have to find out where the wiring goes into the harness. I hope it is those wires that are just hanging loose.
post #9 of 9 Old 01-13-2010, 11:34 PM
Works too much!
laydout97's Avatar
Your best bet would be to get an aftermarket gauge.
