oil pan removal
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 06-19-2008, 02:46 PM   #1
*SMACK* that ass
blazed88's Avatar
blazed88 is an unknown quantity at this point
oil pan removal
i have a 88 2.8 2wd. does the motor have to come out for me to do the oil pan gasket? looking for info on how to replace the oil pan gasket
Old 06-19-2008, 07:51 PM   #2
34blazer's Avatar
34blazer is on a distinguished road
Re: oil pan removal
i thing i would be easier to pull the engine to replace the pan gasket. if you keep the engine in the truck youd have to unbolt the engine mounts and body mounts and jack the engine up about 10 inches.
Old 06-19-2008, 07:59 PM   #3
I'm slap happy, bitches!
Deeze49686's Avatar
Deeze49686 is on a distinguished road
Re: oil pan removal
not to mention scraping off all that freaking cork gasket.
a 2.8 2wd except for the drivers middle bell bolt is an easy motor to pull.
Old 06-20-2008, 11:47 AM   #4
magna1404 is on a distinguished road
Re: oil pan removal
Be sure to remove at least the distibutor cap first for the extra clearance or you will crush it.
Old 06-22-2008, 03:41 PM   #5
TCossuto is an unknown quantity at this point
Re: oil pan removal
Yea but would you rather scrape cork off a engine already jacked up off the frame, or do the following so that you can do it under a engine hoist (or stand if you want even more work):
-drain coolant
-discharge A/C
-Fck with damn Y pipe
-leak fuel & possibly break lines
-probably break old shit like coolant hoses, vac line, etc.
Shit the only benefit is you don't have to drain the oil.
And yes you can remove/install the pan on a 2wd... sometimes loosening body bolts is necessary but theres not many. Also remove distributer all the way and put rag down hole.
Old 06-22-2008, 10:28 PM   #6
*SMACK* that ass
blazed88's Avatar
Re: oil pan removal
well to hell with that lead im just take it somewhere. does anyone know of a ballpark figure that im looking at
Old 07-07-2008, 02:39 PM   #7
LoveDaChevy is on a distinguished road
Re: oil pan removal
-drain coolant
-discharge A/C
I Am Not Sure If I Broke Any Of Those Hoses, But I Know I Ended Up Replacing All My Fuel Lines After Completing This Job.
Old 07-07-2008, 07:30 PM   #8
Re: oil pan removal
oh, yeah you gotta disconnect and move those before jackin up the engine cause they're metal and break/bend. 16mm and 19mm for anyone wonderin.
Page generated in 0.10713 seconds with 12 queries
