press ctrl F4
OkI got one for ya. I have a 1991 sonoma thats not getting any fuel to the throttle body, but I cant figure out why. When I unhook the fuel filter located on the right side of the block and just hold it up and crank it fuel flows great, but when I hook it to the aluminum pipe going to the throttle body no fuel comes out. And yes The aluminum pipe is clean as a whistle. I have no Idea but maybe that the pump cant push it up the line??? HELP...!!!
4x4 v6 blazer
Re: No fuel???
Fuel pressure is reading?
press ctrl F4
Re: No fuel???
Not sure what your saying? Do I need to get a fuel pressure gauge. and test it
the crush velvet man
Re: No fuel???
i have pretty much the same problem going now. changed the pump and have great gas flow to the tb, but the injectors arent firing
press ctrl F4
Re: No fuel???
Ok I'm on the same page you are now. I have fuel getting to the throttle body But I don't think it's getting into the TB. You seem to know more about it than me so when you figure your problem out please post how you fixed I am a newb when it comes to these. Thank you.
Re: No fuel???
im really leaning towards a wire or something going to my ecu. i have already replaced the ecu and it did nothing to cure it. if i start to wiggles all of the wires around, it will start. i just have not figured out exactly which wire it could be
press ctrl F4
Re: No fuel???
Ok I'll try that would me rebuilding do Nething?
GET LAYED!!
Re: No fuel???
let me ask you this....are you getting spark??
cuz i know when my igntion coil came unplugged....the TB would not flow gas |
press ctrl F4
Re: No fuel???
yes I am getting spark because when I spray either in It fires and runs for a lil while but dies cause of the lac of gas??
Re: No fuel???
try replacing the fuel pump. might just not pump enough fuel
GET LAYED!!
Re: No fuel???
gauge it first......pumps aren't cheap just to replace....altho ours is alot cheaper than anything else
press ctrl F4
Re: No fuel???
LOL like 46 but I unhooked the aluminum pipe from the TB and it flows great but when I hoook it up othing happens..
Re: No fuel???
i have put two pumps into mine. flows great, just sometime the tb isnt getting grounded for some reason and isnt letting the injectors pulse
press ctrl F4
Re: No fuel???
How can you tell if its not grounded?
Re: No fuel???
used a noid tester and also a test light to see that one side was hot but would not pulse the noid when trying to turn over
press ctrl F4
Re: No fuel???
OK I'll give it a shot Thanx for the help
.::Custom User Title::.
Re: No fuel???
im having the same problem. i got 12 volts to one wire on top of the injectors but not the other, is this a ground problem?
press ctrl F4
Re: No fuel???
I'm going to check mine out after I finish my interior tonight.
Re: No fuel???
i believe it is a ground problem. mine is sitting right now because its getting bagged. wont give it a try until prolly next week. but once i wiggle some wires on the computer it will run like a raped date
press ctrl F4
Re: No fuel???
LMOA......
Re: No fuel???
ive traced out every wire on mine and still cant get it to work. theres a little dribble of gas that comes out every now and then while cranking
press ctrl F4
Re: No fuel???
HMMM this is weird I am going to have to look at mine tommarow. When I had my hose unhooked from the TB it flowed very good so I think mines wiring. and yours sounds like its the fuel pump??? IDK
Re: No fuel???
i had another fuel pump laying around and i hooked it up and still nothing, unless that one is bad too... because i had it running one day, ran for bout 5 mins and i cut it off. i hooked all my lights back up and went back the next day, and nothing. could the fuel pump go out that fast?
#24 |
press ctrl F4
Re: No fuel???
A couple of ways you can find out is take the pipe that comes from the fuel filter off the TB and crank for about ten seconds, and if nothing comes out you could check and make sure the pipe is clean. but if fuel doesn't come out you might wanna get someone to crank it for you and lay underneath the truck and unhook the fuel line from the fuel filter hold it in the up position and see if it flows out pretty good and if it does. Than its prolly your fuel filter. or it could simply be a fuse> IDK
#25 |
Re: No fuel???
if you want to know if it is the pump, unhook the back side of the filter and just turn the truck on. the pump should try to prime itself and if it does it will spray fuel all over. mine has to be wiring because i too get really good flow to the tb
#26 |
press ctrl F4
Re: No fuel???
same here I'm about to go check mine out as I type...
#27 |
Re: No fuel???
im getting god pressure, im heading up now to work on it some more
#28 |
Re: No fuel???
*good*
#29 |
press ctrl F4
Re: No fuel???
did you get it figured out
#30 |
Wire Splicin Fool :-)
Re: No fuel???
You guys need to try the NOID lite, available for rent at alot of parts stores, it plugs into the injector plug (injector unplugged) it flashes as the injector should be firing, if light is flashing and injector does not spray fuel then you may have a bad injector, since you are getting fuel to the TB suspect the injector is not firing due to either a bad injector or bad drive to injector (could be a bad ground could be a break in the line to the injector, could be a bad injector fuse, you need to check all this since you have Fuel Pressure.)
#31 |
Re: No fuel???
i posted that i have used the noid tester, no pulse good fuel pressure. just been too busy baggin to try to start it again
#32 |
press ctrl F4
Re: No fuel???
OK I might try this this weekend
#33 |
Re: No fuel???
#34 |
Re: No fuel???
also check the 12v at the injector when cranking to make sure that there is not a bad connection associated with the B+ feed to the injectors (might read 12v no injector firing, but will drop to 5vdc because of a bad connection on fuse block or something when firing.) Can use a test light at injector also, red/white side light clip to ground, Blue/Green side light clip to B+
#35 |
Re: No fuel???
i just got done checking mine, i got power to the red and white wire and i hooked up the test light to the power and checked for ground and when cranking, nothing happens
