Muffler vs. no muffler
I have no muffler on my 91 s10.(just a pipe in place of the muffler.)Originally I was going to have a Flowmaster Super 44 put on, but the guy at my local shop said it would be louder with no muffler. It's kind of loud but not that loud, and it sure sounds like a v6. Would the Super 44 make it louder or quieter? And as far as performance goes does the flowmaster offer better performance/mpg compared to having no muffler? It has a stock cat and I'm not messing with it at the moment.
Registered Neanderthal
Re: Muffler vs. no muffler
Any muffler will reduce the sound you are getting now vs no muffler at all. A flowmaster added may not impact performance at all vs no muffler with factory exhaust manifolds and converter. In other words, with those restrictions the flowmaster probably won't make a difference.
Subsonic Kustomz
put a glass pack on it i have a 2.8 with no converter and duals with thrush glass packs and the guy that did my tuck said "holy shit it sounds like a 350 with a mild cam"
King Turd Polisher
A muffler is a device installed upon an exhaust system to reduce the noise coming out of the tailpipe. If a muffler didn't "muffle" anything, then it wouldn't very well be a muffler, now, would it?
![]() That being said, there are mufflers which don't reduce the volume of an exhaust system AS MUCH as other brands and designs, but they ALL reduce the sound SOMEWHAT. Nothing is louder (or more obnoxious) than a motor without a muffler of any kind in place. If you exhaust doesn't seem that loud to you with no muffler in place, either your catalytic converter is doing an excellent job of deadening the sound (a cat does act as a kind of muffler, although that isn't its main job), or you may need to get your hearing checked. A 2.8 V6 with a Flowmaster 44 behind a stock cat will not be obnoxiously loud and certainly quieter than having no muffler at all, but me personally, I don't care for the sound of ANY Flowmaster behind anything with less than eight cylinders (and even then, I'm not crazy about Flows). Please, please don't go with glasspacks. They're cheap for a reason, and it's NOT simply because they sell a lot of them ... nor does the fact that lots of glasspacks get sold every year mean that they're "good." (No offense to anyone with glasspacks, but there are definitely better options out there.) Hop on YouTube and look for some exhaust sound clips - search for "2.8 exhaust" followed by "Flowmaster" or "Magnaflow" or whatever other brand(s) you want to hear - and then go with what sounds best to you. |
Doin' Work
Glasspacks are cheaper than other mufflers because there is not much to them. They are straight through with baffling and fiberglass insulation around the edges.They are very effective at reducing back pressure, but not very effective at muffling noise. Thus, they are louder than conventional mufflers.
They are cheaper to make, therefore cheaper to buy. I myself dont enjoy glasspacks unless they are on big engines... but Im kind of past the whole "loud just to be loud" thing. |
[quote=E.Morel;6552493]Glasspacks are cheaper than other mufflers because there is not much to them. They are straight through with baffling and fiberglass insulation around the edges.They are very effective at reducing back pressure, but not very effective at muffling noise. Thus, they are louder than conventional mufflers.
They are cheaper to make, therefore cheaper to buy. I myself dont enjoy glasspacks unless they are on big engines... but Im kind of past the whole "loud just to be loud" thing.[/quoteThere's not much to a flowmaster either ![]() |
King Turd Polisher
More welding involved in a Flowmaster than a glasspack. A glasspack is just a couple of rolled-up bits of sheetmetal (one being perforated) with some fiberglass packing sandwiched inbetween, and a bit of welding done down the middle seam and at the ends.
Plus, they're a bit more expensive because Flowmaster sponsors a lot of stuff and they've got a more popular name than, say, Thrush or Cherry Bomb. So, basically you're paying for a lot of their advertising costs, as well. ![]() |
Doin' Work
Word. Theres not MUCH to a flowmaster, but there is more than a glasspack. And like 89 said; flowmaster is like a household name for mufflers.
You mean like the name Kohler is to toilets?
Matt Smith
I can 2nd that, no one can tell my Firbird is a V6 by sound alone with no cat and a CherryBomb straight shot.
I wouldn't say it sounds the "best" but least it doens't scream V6 at any RPM like other mufflers. |
This is doo doo baby!
Certified Auto HVAC Tech
Magnaflow...nuff said....about one of a only a few i've had that i've actually liked for v6 trucks....def does NOT scream v6...i've have several different systems under the truck...and imo this is about as good as it gets
heres my set up....true dual in/single out ![]() |
King Turd Polisher
Just curious, why'd you go with the dual in/single out instead of a dual in/dual out (muffler with internal crossover) or two seperate mufflers with an H-pipe? Was it to keep the noise level down?
About the only mufflers I've heard worth a hoot on any V6 of any make have been straight-through mufflers such as Magnaflow, Hooker Maximum Flow, or Dynomax Ultra-Flow. Pypes Violators are straight-through (I have a set on my '89 Mustang) but they have almost ZERO sound deadening material inside of them, pretty much just a hollow case with a louvered tube running through it - damned loud on a V8, so probably they would sound obnoxious as hell behind a V6 or 4-banger. |
