ignition coil & plug wires
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 06-22-2009, 09:23 PM   #1
is it really worth the money to purchase 8mm wires dont think my coil has ever been replaced so was thinking bout msd or such same with wires what do ya guys recommend thanks just recently did plugs and wires cap rotor plugs and wires are autolites stock cap rotor
Old 06-22-2009, 09:31 PM   #2
Certified Auto HVAC Tech
layinlow88's Avatar
Re: ignition coil & plug wires
not really worth all that suff...if the coil fires fine then just let it be
just run some AC Delco wires and call it a day...it also wouldn't hurt to change out the cap and rotor if it's never been doin
Old 06-22-2009, 09:37 PM   #3
Keepin' it Gangsta!
Dr. Steve's Avatar
yep...
Old 06-22-2009, 09:52 PM   #4
yeah i did do cap and rotor also so if i were to do the msd coil with autolite wires for instance would not notice anything at all ?
Old 06-22-2009, 10:04 PM   #5
layinlow88's Avatar
most likely not.....especially on a bone stock engine...only way you'll notice the coil is if your orginal one isn't firing as it should
Old 06-22-2009, 10:10 PM   #6
thats what im saying dont think its firing like it should seems to crank more then should to start up so im kinda wondering if should just stay with stock or if i were to pay little more for msd would notice anything at all
Old 06-23-2009, 04:17 PM   #7
I just put in mallory pro silicone 8mm stainless steel core wire (ebay) and there was a noticable difference from the ac delco wire. This was after in installed NKG Iridium plugs, Edelbrock TES headers, Holley 502-3 TBI. The plan is to get a multi-spark CD ignition box but the heli core stainless steel wires have already made a noticable difference with better idle, response and mpg.
Page generated in 0.56644 seconds with 31 queries
[Output: 58.94 Kb. compressed to 55.59 Kb. by saving 3.36 Kb. (5.69%)]
