I may have locked up my engine - S-10 Forum
post #1 of 33 Old 10-07-2011, 06:09 PM Thread Starter
hyenad's Avatar
User is: hyenad is offline
Exclamation I may have locked up my engine
I think that I locked up my engine. It's a 1988 chevy s10 with a 2.8. I was driving to work and it just slowed to a crawl and wouldn't turn over. Is there a way to know for sure if its locked? Other than getting another engine are there any other ways to fix it? Thanks
hyenad is offline
post #2 of 33 Old 10-07-2011, 06:37 PM
User is: michanic220 is offline
Re: I may have locked up my engine
reach down and grab the harmonic balancer and try to turn it back and forth.. i did this with my old C10 strait 6 250.. but i was running it so hot it locked up.. let it cool down and it was fine.. does the starter on your engine engage?
post #3 of 33 Old 10-07-2011, 08:08 PM Thread Starter
hyenad's Avatar
yes but it doesn't turn it over.
hyenad is offline
post #4 of 33 Old 10-08-2011, 10:53 AM
roofless's Avatar
User is: roofless is offline
i dont know about turning the balancer with your hands. id use some tools and see what happpens. pull the plugs and try to turn it over also. it could be a million different things.
roofless is offline
post #5 of 33 Old 10-08-2011, 10:45 PM Thread Starter
hyenad's Avatar
I tried turning the harmonic balancer with a wrench nothing , it didn't move at all . I was hoping that it wasn't the engine but I think it is.
hyenad is offline
post #6 of 33 Old 10-09-2011, 02:04 AM
you should be able to rock it back and forth enough to tell if its locked or not. either way works though. does your temp gauge work? mine did and about the time the engine started dragging i was like wtf, looked at my gauge and it was buried past 250 degrees.
anyways, sorry bud.. this isnt looking promising. is it solid as a rock?
post #7 of 33 Old 10-09-2011, 08:08 PM Thread Starter
hyenad's Avatar
Yes I can't move it at all
hyenad is offline
post #8 of 33 Old 10-09-2011, 11:37 PM
man, thats not looking good. usually if the trans locked or something jammed, you could atleast turn it a little.. but since its solid in both directions.. it looks like your engine is seized. does your temp gauge work? if it heated up, and seized you could have scored a cylinder..
post #9 of 33 Old 10-10-2011, 06:57 AM Thread Starter
hyenad's Avatar
Yeah that's what I'm thinking. Thanks for all your help.
hyenad is offline
post #10 of 33 Old 10-11-2011, 06:38 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Is this an auto or standard? If it's a standard, you can try dragging it and letting the clutch out in 2nd or 3rd gear. Check your oil to make sure you have some left...
Sometimes (if you get lucky) you can break it free and it will keep running.
You can also pull the starter and use a pry bar to turn the engine by using the flywheel teeth and leverage.
Post the results...
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best)
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
post #11 of 33 Old 10-11-2011, 07:28 PM
i wasnt sure if the T5 would stand up to that or not. so i didnt post it. i used to do this after sinking trucks to get them started again. lol
post #12 of 33 Old 10-11-2011, 07:53 PM
Ol' Yaller's Avatar
User is: Ol' Yaller is offline
I tried this on a locked engine in my camaro and all it did was slip the clutch.
If you can't spin it with a wrench, it's probably locked.
'82 S10 - 500K and counting.
3.5" spindles, 2" coils, Bilsteins all around, 30x9.5x15.
"I vow to always have the courage to fix what isn't broken"
post #13 of 33 Old 10-11-2011, 07:57 PM
Registered Hoosier
Hoosier Rick's Avatar
Might try dropping off the belt, and checking for failed components I saw a locked up alternator keep a 2.8 from turning over.
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
post #14 of 33 Old 10-12-2011, 12:08 AM
Skutt's Avatar
User is: Skutt is offline
When it quite was it running hot, like 250 or hotter? Did you run it out of oil? With no obvious reason why it seized then I think there might be room for hope still.
Age and treachery win over youth and skill every time!
Skutt is offline
post #15 of 33 Old 10-12-2011, 02:37 AM
User is: Corsa is offline
Could be hydro-locked, A cylinder filled with coolant or gasoline. Had that happen to my Safari van when the Fuel Injection died. Pull the spark plugs..
Corsa is offline
post #16 of 33 Old 10-12-2011, 03:58 AM
hydrolock is crossed out because he said its locked in both directions.
im curious if it overheated..
post #17 of 33 Old 10-12-2011, 03:50 PM Thread Starter
hyenad's Avatar
No it didn't overheat and it had oil in it
hyenad is offline
post #18 of 33 Old 10-12-2011, 05:25 PM
User is: FaceLoran is offline
I didn't see anything mention if it was an automatic or manual. But for grins I'd throw it in neutral and see if it spins if you haven't already. I know someone mentioned that it should move a little bit but if something happened to the tranny it may not.
Try all the things that were suggested as anything beyond that is probably going to require the motor being pulled to rebuild it if it indeed seized.
-Pull the plugs
-Take the belts off
-Transmission in Neutral
post #19 of 33 Old 10-12-2011, 09:13 PM
motor seizing that had oil and didn't over heat.. this sounds odd to me.. even if per-say the input shaft seized.. you would still have a little bit of rock to the engine. not to mention to try to start it you would have to press the clutch in.. which would bypass the standard regardless. and w/ a automatic the torque converter would slip. the only thing i could really assume is a mechanical failure.. like you folded a piston ring and scored a cylinder. not much else will really keep it from spinning inside the engine other then heat expansion.
post #20 of 33 Old 10-13-2011, 02:36 AM
I would've assumed you'd hear something break though. Last time I blew a motor it made alot of noise.
But stranger things have happened and if this happened on a freeway be distracted by dodging traffic I guess instead of troubleshooting what was going on.
Thinking your right michanic, something broke inside that's preventing it from spinning or like another poster said. One of the accessories has siezed and is preventing the motor from turning over. Though in that case I'd figure it would just slide through the belt
post #21 of 33 Old 10-13-2011, 03:29 PM
yeah, well a ring folding over would slow it to a nice quiet stealthy halt.
i had a CR250R 2 stroke, these are quit prone to folding rings if you don't maintain them due to the poor oiling system of a 2 stroke. it folder over when i was on the back wheel doing about 60.. it was like somebody turned the key off.
post #22 of 33 Old 10-13-2011, 04:51 PM
something else to think about, just because there was oil in the engine. doesnt mean it was pumping through the engine. do you have a oil pressure gauge on your truck? seems like it'd over heat a bit lacking oil though..
post #23 of 33 Old 10-14-2011, 10:21 AM
Awww..you ain't got shit!
jimmykicker's Avatar
...and knock!
1984 xcab s-10 3.4L GM crate engine 87 S10 TBI swap w bored intake, Edelbrock headers. 3.42 locker rear end swap. Flowmaster, shift kit, e-fan.
EFI swap http://www.s10forum.com/forum/f106/c...e-help-513616/
My build thread (3.4L)http://www.s10forum.com/forum/f106/b...stions-427168/
I had to cut my nut in half .
post #24 of 33 Old 10-14-2011, 03:54 PM
jman85's Avatar
User is: jman85 is offline
My buddy just had his do something similar on his 2.8l it was a seized up alternator.
1985 gmc s15 4x4 high sierra 5 speed 2.8l reg cab short box 3 inch body lift SOLD
1991 gmc jimmy 2 door 4.3l auto 4x4 lifted 2 inches on air SOLD
highly modded 97 dodge diesel 4wd 5 speed fully loaded making 450hp and 28mpg.
93 sle 4wd 4 door jimmy
jman85 is offline
post #25 of 33 Old 10-14-2011, 04:08 PM Thread Starter
hyenad's Avatar
I had a mechanic look at it and he said that I sprung a bearing. I said that I could fix the bearing but it would be better if i just changed out the motor.
hyenad is offline
post #26 of 33 Old 10-15-2011, 04:33 PM
if you spun a bearing 9x out of 10 your going to have to turn the crank or its just going to keep eating up bearings. then you should put in oversized bearings. while your in there its just easier to rebuild the engine then replace just the one bearing. do it right the first time. you can also look at the coloring of the bearing to see if they need to be changed. but there cheap enough i dont even think twice about changing them.
post #27 of 33 Old 10-17-2011, 02:42 AM
jman85's Avatar
Do I smell a 3.4l swap in the near future?
jman85 is offline
post #28 of 33 Old 10-17-2011, 10:38 AM Thread Starter
hyenad's Avatar
I already found another 2.8. Already started to remove the old engine
hyenad is offline
post #29 of 33 Old 10-17-2011, 11:03 AM
Ol' Yaller's Avatar
Thanks for posting back what you found
post #30 of 33 Old 10-19-2011, 04:09 AM Thread Starter
hyenad's Avatar
no problem. Thanks for all the help.
hyenad is offline
post #31 of 33 Old 10-22-2011, 06:41 AM
Power transmission,Transm
User is: chinabase is offline
good news for you
post #32 of 33 Old 10-22-2011, 11:05 PM
not really, that requires pulling the engine. probably having the crank turned. putting in new bearings, and like i said i'd rebuild it while im in there.
good news you got a new engine though.
post #33 of 33 Old 10-24-2011, 07:13 AM Thread Starter
hyenad's Avatar
Yeah I bought one about a year ago. Been trying to sell it. Started the install last week. I'll keep you posted.
hyenad is offline
