hows my heads look?
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 09-01-2008, 01:45 PM   #201
s10 user & abuser
MRSHAGGWELL's Avatar
MRSHAGGWELL is on a distinguished road
Re: hows my heads look?
resurfacing of the flywheel doesn't cause chatter just half ass work
Old 09-01-2008, 01:57 PM   #202
paxter is on a distinguished road
Got it on the power. I've had mostly very good results with having flywheels resurfaced, but I did have one done that was not right and had to take it apart and redo it. The guy that cut it the second time said it was out .012". Not good and chattered badly. A reputable machine shop can do this with no ill effects and normally you only replace when the flywheel gets too thin or the heat cracks can't be removed.
Old 09-01-2008, 01:58 PM   #203
It will if it's not true.
Old 09-01-2008, 02:10 PM   #204
s10 user & abuser
well I have had my same flywheel for 5 years and turned 3 times, and neutrally balanced by myself. I personally havn't problems with it or any of the other 100+ clutches I have installed. circumstances like the one from above are rare but do happen.
Old 09-01-2008, 02:13 PM   #205
Agree, I only had it happen once, but took it to a different shop and it was out. Either the machine or the machinist, don't know which.
Old 09-01-2008, 03:35 PM   #206
The_Raven is an unknown quantity at this point
Actually resurfacing the flywheel DOES indeed move the clutch farther away from the clutch lever/arm. It moves the entire assembly towards the engine. It may only be a few thousanths, but it can in some cases make all the difference.
The recommended procedure when resurfacing a flywheel is to use a shim between the flywheen and crank equal to the amount shaved off the flywheel itself, to keep the geometry of the clutch release mechanism proper and within proper travel distances.
In older cars, there could have been so much difference between astock flywheel and re-srufaced flywheel that some times the clutch wouldn't disengage properly, causing the clutch to be essentially slipping and over heat the clutch on shifts, due to the friction. Most people wouldn't notice this in daily driving, but for those of us that drive spirited, we usually noticed in a hurry.
That being said, I don't recall ever using a shim, since I've only ever had to remove a couple thousanths at most when resurfacing the flywheel and it doesn't seem to have made for any poor drivability.
Old 09-01-2008, 04:13 PM   #207
pearl91chevy's Avatar
pearl91chevy is on a distinguished road
so depending on how much i have taken off, i should shim it for it to be correct?
Old 09-01-2008, 05:47 PM   #208
Never shimmed one and never had a problem. Either with a hydraulic clutch or mechanical. There is plenty of adjustment in either to make up for the material removed. In older cars (mechanical) you adjusted the threaded linkage to get the proper clearance.
Old 09-02-2008, 07:56 PM   #209
trying to find someone right now to get my valves cleaned up, forgot what is called though
Old 09-02-2008, 07:59 PM   #210
Lapping?
If that's the case, go buy a lapping tool, it looks like a stick with two suction cups on it, because well, that's pretty much what it is, and some lapping compound. It's pretty easy to do. You should have a guide in your Haynes manual.
Old 09-02-2008, 08:10 PM   #211
sweet!! alot better then spendin who knows gettin it done by a shop.. ill go check around at some parts stores to see if that got anything
Old 09-14-2008, 12:49 AM   #212
plans are figuring out the exhaust for tomorow.. and hopefully if a shop is open, get it mandrel bent..
Old 09-14-2008, 02:23 PM   #213
well didnt get much done due to my friend having to goto a football party.. but we did manage to get some pipe bent for the crossover pipe.. were running 2 1/4 for size..
Old 09-22-2008, 10:45 PM   #214
finally got the crossover pipe figured out cause i had time to lol.. pretty much a straight shot using a 90degree.. i just need the other side to bolt it together, only prob is i had to take off that brace underneith the tranny for it to clear.. but it should sit more then high enough so it wont drag.. also figured out a much better way to do the piping for the exaust side.. gonna be tricky but its possibly.. pretty much run it over the crossover pipe and between the valve cover and cab.. kinda hard to explain but it makes sense in my head..
Old 09-29-2008, 10:40 PM   #215
as of probly 15 min ago i finally finished plumbin the exhaust.. after many many trips to the exhaust shop for bends its done.. i just need the pipe welded since its all tached together.. but now motor can come out and be built up while truck gets paint!!!!
that crossover pipe will sit a few inches higher when done..
and for the muffler just gotta stick my turn down on the end.. and the muffler will also sit higher once the bracket is made to hold it..
Old 09-30-2008, 12:03 AM   #216
4x4 v6 blazer
neo71665's Avatar
neo71665 is on a distinguished road
Looks awful, you must pull it out and let me um dispose of it for you. Yeah, lol
Old 09-30-2008, 09:18 AM   #217
i dont get it lol
Old 09-30-2008, 10:50 PM   #218
my shop let me take the truck and cherry picker home today which means i got the motor out!! spent about 2 hours on it including making 2 trips to menards.. but acually went real smoothly.. even got the heads sittin back on the block again, but now the fun begins!!
Old 10-01-2008, 04:26 AM   #219
xtremebilly's Avatar
xtremebilly is an unknown quantity at this point
i dont get it lol
he wants to "recycle" your turbo set-up. haha.
Old 10-01-2008, 09:19 AM   #220
o i bet he does lol
Old 10-01-2008, 11:41 AM   #221
4x4 v6 blazer
neo71665's Avatar
o i bet he does lol
Looking great, keep it up.
Old 10-03-2008, 10:45 PM   #222
hey guys.. i need a lil help.. im about to put my heads back together on the truck and dont exactly rem how they go.. would anyone have a picture or the instructions on how the heads are re-assembled? and on another note ill have new pics up tomorow
Old 10-04-2008, 12:15 PM   #223
few more...
Old 10-05-2008, 12:09 PM   #224
sent ARP a message concerning bolt/studs for my motor but still nothing yet.. in the mean time, what should i do head gasket wise?? would i be alright with a normal fel-pro one?
Old 10-09-2008, 09:10 PM   #225
prodan's Avatar
prodan is on a distinguished road
heres my motor
im going to re paint the valve covers and surface rusted stuff stuff stuff theis wenter u otta mount ur alt like i did mine
Old 10-09-2008, 11:37 PM   #226
ehh im mounting mine were the smog pump used to be.. im gonna be needing room up there for the intercooler piping.. thanks though
Old 10-10-2008, 03:08 AM   #227
34blazer's Avatar
34blazer is on a distinguished road
wheres the belt tensioner?
Old 10-10-2008, 09:10 AM   #228
The alternator is the tensioner on the above pictured engine.
Using a spring loaded tensioner is definatly a better way to go though.
Old 10-10-2008, 04:36 PM   #229
prodan's Avatar
its not like its gonna hurt my belt or anthing.
im waiting to se what it takes to tune this so please go into detal and stuff when it comes to that, when ur done with yours im prolly going to start doing mine
Old 10-10-2008, 05:44 PM   #230
ill make sure i put up all info on here... still got a long road ahead of me though
Old 11-04-2008, 07:19 PM   #231
prodan's Avatar
any updates
Old 11-04-2008, 11:59 PM   #232
none as of now. i bought a new truck so i gotta get some more money saved up
Old 11-05-2008, 01:36 AM   #233
34blazer's Avatar
you better hurry up, im almost done
Old 11-13-2008, 11:16 AM   #234
paint color? ... Mud =D
83blazer28's Avatar
83blazer28 is on a distinguished road
And the race is on!!!
I wanna see this thing done it looks good!!!!!!
