hows my heads look?
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 01-02-2008, 07:24 PM   #51
34blazer's Avatar
34blazer is on a distinguished road
Re: hows my heads look?
Quote: Originally Posted by HappyBuddaBelly
No, I'm having fun annoying you. Regardless of the pointed and rather intrusive emails you send me, I find a 60 year old who spends his days stalking my posts to be quite amusing!
he might be 60 but you 2 are acting like 5 year olds this kid is asking legit questions and wanting to learn something. take your fukin attitudes somewhere else.
now....back on topic
Old 01-02-2008, 07:30 PM   #52
HappyBuddaBelly's Avatar
HappyBuddaBelly is on a distinguished road
Somebody pick a cornfield and we'll move the pissing contest there..
Old 01-03-2008, 08:41 PM   #53
paxter is on a distinguished road
Quote: Originally Posted by SH-60B
Yeah but... TDC of which stroke? If the intake is off turn the crank til the #1 cylinder lifters aren't moving anymore AND the timing marks on the damper and pointer are lined up. It's a four stroke engine, you want it at the top of the compression stroke b/4 beginning valve lash.
HBB - the man made a good point. With the timing mark on "0" without the distributor in you can't tell where the rotor is pointing so therefore you could be on TDC for #1 or #4. The way to tell in this case is that the exhaust valve for #1 should not be closing as you reach TDC. If it is, you're on the exhaust stroke and need to make one more full revolution with the crank. pearl91 - Please read your manual for this. Look up "valve lash" in the index. If after reading it you have any more questions, by all means ask.
Later
Old 01-04-2008, 02:46 AM   #54
pearl91chevy's Avatar
pearl91chevy is on a distinguished road
thanks guys again for all your help.. and i've read the haynes manual on valve lash many many times.. but like i said i do better seeing if done, then reading it and trying to go from that.. i havent had a chance to work on the motor anymore but i should this comin weekend..
Old 01-04-2008, 02:47 AM   #55
Later
in the picture i posted of the valves.. is that the exhaust stoke partially open? or is that the intake?
Old 01-04-2008, 05:36 PM   #56
alright, i had a buddy come over and explain to me what to do. he's the person i bought the motor from. he explained and showed me what to do, by the looks of it there all real loose.. he talked me into pulling the motor not for just paint but to do some mods also.. i think were pullin it next weekend, maybe this weekend if i get time..
Old 01-04-2008, 08:51 PM   #57
34blazer's Avatar
what kind of mods? headwork, cam?
Old 01-06-2008, 11:04 AM   #58
he's tryin to get me to do headwork, and im not sure on it.. but a cam im really considering.. what would u guys prefer..
Old 01-06-2008, 11:41 AM   #59
34blazer's Avatar
you'd see more gains doing some bowl blending and minor polishing on the runners. i have a set 4 sale already ported and polished, 5 angle valve job, the works.
Old 01-07-2008, 02:11 AM   #60
how much more power would i get outta that? more torque?
Old 01-07-2008, 08:53 PM   #61
34blazer's Avatar
definitely more torque. it depends how much $$$ you want to spend and how much the heads flow.
Old 01-11-2008, 02:50 AM   #62
just spent bout 3 hours pulling the trans out, and wasted 30min becasue i couldnt figure out why it wouldnt come off.. then i realized i had to take that dust sheild off.. i did the same thing last time i pulled the trans out..
this will be out tomorow afternoon finally!!
Old 01-11-2008, 09:38 PM   #63
well i spent around 30min pulling the motor out, everything was already disconneted so i just needed to pull it out..
my friend said we should port/polish.. will it make a noticable difference?
Old 01-12-2008, 05:28 PM   #64
just got back from the junkyard.. i got some 4.3L injectors, i shoulda grabbed the throttle body but o well i can always go back..
Old 01-12-2008, 05:44 PM   #65
34blazer's Avatar
id get the larger bore 4.3 tb
Old 01-16-2008, 02:16 PM   #66
blackknight54 is on a distinguished road
im friends with pearl91chevy.. i think were gonna make a trip to the junk yard today and grab that throttle body..
Old 01-31-2008, 01:42 AM   #67
well i been working alot on that motor.. painted it and all. started to do individual peices now.. i got a question though.. i got the 4.3l injectors.. but i think i needed the 4.3tb instead right? and then stick the 2.8 injectors in it?
Old 02-01-2008, 12:32 PM   #68
Z28Camaro's Avatar
Z28Camaro is on a distinguished road
If it's the 3.1L then yeah, use the 2.8 injectors on the 4.3TB since the TB has a larger bore than the 2.8's. I gotta say that motor looks excellent how'd you clean it up? What did you use?
Old 02-01-2008, 07:46 PM   #69
all i did was wire wheel it up.. then sprayed the high temp gloss black paint.. i was debating on either black or orange, but decided to do black since it would match more.. thanks man
Old 02-06-2008, 04:22 AM   #70
been workin my ass off on this motor.. plans are to have it running again by the end of this month.. i really hope this happens.. got the clutch assembly hooked back up, and starter is bolted up to..
then pulled the intake back off and put some sealer down on it, layed it down and tightened up the bolts.. hopefully no leaks!! then for shits and giggles threw the carb and intake on and checked out it looks so far.. i like it!
Old 02-08-2008, 01:55 PM   #71
Z28Camaro's Avatar
Looks pretty nice indeed. Is that the 3.1 or the 3100 and what car did it come out of? Is that all of the original pulley assembly off the 3.1 or the 2.8?
Old 02-08-2008, 02:47 PM   #72
its a 3.1L out of a 91 camaro rs.. i think i mix matched the pulley assembly , only thing i hate is the way i have the belt ran.. it run straight across the top of alt. and ac compressor.. so the radiator hose hits it, so i have to tie the hose down so they dont..
Old 02-08-2008, 07:25 PM   #73
1CLEAN92
1CLEAN92 is on a distinguished road
well i was gonna chew someone a new ass, then i realized what was wrong...
i did the valve clearances and put it all back together and it wouldnt fire, it would just turn over like theres no plugs in the motor cuz the valves were open. so i figured aww shit i have to take this thing all back apart again. so i went into the house all pissed off, then it hit... dur dur durrrrr, theres a hydraulic cam and lifters in that motor (3.4) i need to wait a while for the lifters to bleed down.
so im apologizing for something i almost did, which in turn would have made me look like a dumbass
but thanx for the info on how to do this!
Old 02-09-2008, 10:52 PM   #74
Z28Camaro's Avatar
Think you were in the wrong thread there 1clean92. Anyways, so its a first gen 3.1 then. I want to put a second gen in my S-10 and there are plenty around to throw in I just need to get back to indiana first. Where did you get your motor mounts? What all did you have to do to swap them? Well then again its out of a RWD so I'm guessing the motor mounts are regular ones..
Old 02-10-2008, 01:08 PM   #75
1CLEAN92
oops! sorry about that guys
clean lookin 3.1 tho
Old 02-10-2008, 01:13 PM   #76
1CLEAN92
actually this is the right thread, im goin off of page 1 when he was askin about how to adjust valve lash
Old 02-10-2008, 02:46 PM   #77
The_Raven is an unknown quantity at this point
All RWD blocks have the mount bolt bosses in the same location.
Forget the genII, get a genIII. The slight increase from a genI to genII is not worth the effort IMO. But going to a full out genIII is. getting into a stock small port 3100 is rated at 155 HP SAE, which means that a bit more could be pulled out of it without opening it up, next up would be the large port 3100, which IIRC was rated at 175 HP, then comes the best option IMO, the 3400, rated at only 185 HP, but many people have swapped these into other cars, tuned them using MPFI (batch fire) instead of the SFI, and have netted over 190 HP at the wheels.
BTW, once I get my mounts figured out, I will likely sell copies to open up the newer FWD engines to be swapped into the RWD vehciles easily. I'm installing a 3500 in my Jimmy, which has a lot of similarities to the 3400, but the mount bosses are a bit longer, meaning that some spacers will be needed for the 3400. The 3500 also requires an external crank trigger to fire the older DIS set-up (used from 1987 to 2004).
Old 02-25-2008, 02:28 PM   #78
when i did the motor mounts, i had a problem using the stock mounts from the block on the 3.1L, i had to use the 2.8L mounts on the 3.1L to make it fit correctly.. also now after i got the engine back together, i was toppin off the anitfreeze and noticed a leak, turns out waterpumps got a leaky seal.. so back off that comes havent even got to start it yet
Old 02-26-2008, 01:41 PM   #79
ap72 is on a distinguished road
Why someone would go through all the trouble to pull an engine just to spray on a can of $5 paint I will never understand.... but to each their own. I like the polished intake.
Old 02-28-2008, 06:51 PM   #80
because its what i wanted to do, its not like this motor is gonna be put through hell or anything, and the truck hardly gets driven anyways.. the motor looks 100X better in my opinion then it did, but ur opinion...
Old 02-29-2008, 09:13 PM   #81
Z28Camaro's Avatar
Well I think it looks great. It's not really that big of a deal to pull a motor anyway so I think if the truck is nice why shouldn't it's most important component look nice as well? And I might have to talk to you about getting some of those mounts Raven, my father has pretty much seen fit to finally end the life of my 300,000 mile 2.8L, would've lasted forever had I not let him drive it...
Old 03-01-2008, 10:26 AM   #82
thanks Z28Camaro!! i got the new waterpump in last night and everything back together, hopefully gonna try to start the motor tonight when im off of work
Old 03-01-2008, 12:32 PM   #83
