4x4 v6 blazer
How to pull your SES or check engine light codes
This seems to keep popping up so I'll make a whole post on this. I know its found all over the net but still we get asked this all the time.
To enter the diagnostics, either connect a scan tool to the ALDL/DLC (thats the plug under the dash on the drivers side) connector or use a jumper wire to connect terminals A and B and begin flash diagnosis. On carbureted vehicles, the jumper should be connected with the ignition switch turned ON to begin code display. For fuel injected vehicles, the jumper should be connected with the ignition OFF, then with the jumpers in place, the switch should be turned ON to begin code read out. In both cases, the engine should NOT BE RUNNING. Once the jumper is properly connected, the control module will enter the diagnostic program and report trouble codes on the scan too or by flashing the SES/check engine light. All codes are 2 digits between 12 and 82. Codes are displayed on the CHECK ENGINE or SERVICE ENGINE SOON light by flashing the MIL with short and long pauses to distinguish digits of 1 from digits of another.The short pause is used between digits of the same code, long pauses are between codes. For Code 12, the sequence will be: flash, pause, flash-flash, long pause 1. When the diagnostic mode is entered, Code 12 is displayed 3 times. This indicates that the internal diagnostic is operating. If Code 12 is not displayed, the self-diagnostic program is not functioning properly. If no systems malfunctions have been stored, Code 12 will continue to repeat. On many applications, entering dignostic mode will cause solenoids and relays to activate. Pulse-width modulated solenoids may be rapidly energized and de-engergized, causing a clicking noise. Do not be startled by or concerned with this underhood noise during self-diagnosis code display. 2. After code 12 flashes to indicate diagnostic display, any existing system fault codes are displayed in order from lowest to highest code number. Each code is displayed 3 times, followed by the next code if any. 3. When all codes have been displayed, Code 12 will flash again. <<<<pics coming in a few minutes as soon as I get off the phone with my wife, if ya'll want this a sticky request it>>>> Last edited by neo71665 : 03-14-2008 at 10:42 PM. |
4x4 v6 blazer
Re: How to pull your SES or check engine light codes
Look here for the codes and what they meanhttp://www.autozone.com/az/cds/en_us...rInfoPages.htm
4x4 v6 blazer
This is a pic of the cheap-o scan tool I have (Had it for years but it was around 20 bucks), a chiltons book which I highly suggest getting if your gonna work on your own truck (also around $20), and I'm using a piece of 14 gauge copper wire to show you how to jump the diagnostic port out (I'm an electrician so I have it laying around but a paper clip is what is normally suggested).
![]() Here are 2 pics of where you need to put the jumper wire if you don't have a scan tool. ![]() ![]() |
Mr. Clean
Nice article. I'm sure by the end of the weekend though, we'll still have two or three new threads about how to pull an SES code.
Moderator
done, if there's anything else, PM me for make more sticky, threads into one, etc, anything else relating the topic
4x4 v6 blazer
Thanks
Does this work for OBD-II? I was under the impression this method only worked on OBD-I.
4x4 v6 blazer
OBD1 was all the first gens had and since this is in the 60 degree v6 section, which was only offered in first gens.
For obd 2 first I suggest asking in the right section but you have to have a code reader. |
the crush velvet man
you can also use a paper clip and bend it to go into those same spaces. done this many times and works great
4x4 v6 blazer
Do these trucks store the fault codes (ie will past fault codes that have not been cleared show up)? or do you have to check them when the light is on?
fwiw the vehicle i'm working on is a 2.8 fuel injected model. |
4x4 v6 blazer
Might wanna search next time.
http://www.s10forum.com/forum/f106/c...-light-379245/ |
Thanks. Just thought it'd be some good info to have in this post anyways.
I tried reading the codes but my check engine and ses lights don't work, which fuse is responsible for those lights? My cig-lighter and horn don't work also-is it the same fuse?
Thanks |
4x4 v6 blazer
don't trash up a sticky with questions, search then start a thread.
is rockin' out to
autozone link no worky anymore.
