How to get to the distributor hold down bolt?
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 10-24-2009, 11:04 PM   #1
Well I finally got the trans and engine back in. With the brown wire disconnected I'm at 0 degrees and I should be at 10btc. I cannot seem to get to the hold down bolt. What combination of tools and from what angle are you all getting to that bolt? Thanks Anthony
Old 10-24-2009, 11:47 PM   #2
4x4 v6 blazer
neo71665's Avatar
Re: How to get to the distributor hold down bolt?
15 mm wrench and stick my hand back there
Old 10-25-2009, 12:00 AM   #3
So a wrench, not a socket? I've been trying for an hour with a socket, swivel, and extensions without luck. I feel stupid even asking the question but I just cannot seem to get at it. Tony
Old 10-25-2009, 11:17 AM   #4
I actually got to mine with a socket and a couple of short extensions stuck together... Took me about 40 minutes to find the sweet spot to get to the bolt, but once I did I was able to get to it pretty quickly. I was completely unable to actually get my hand back there with a wrench on my truck, there just wasn't the room, but you might have more luck with yours depending on how it's laid out back there.
Old 10-25-2009, 11:45 AM   #5
banned
bobditts's Avatar
I have very little problem getting to mine. Then again, I removed the heat and A/C box under the hood.
Old 10-25-2009, 01:43 PM   #6
well I've been trying for about 40 minutes and still cannot get it. I cannot get my hand and a wrench back there from the pass or drivers side. This is really ruining this project and fast. By the way thanks for the replies, I appreciate your help. Tony
Old 10-25-2009, 02:03 PM   #7
Lifts are for 4wds!
andysutt's Avatar
IIRC they do make a "special" tool for this at the parts store, but its really not all that special. lol
I've used a wrench and I've also used socket/swivel combination before... No problem really
Old 10-25-2009, 02:48 PM   #8
4x4 v6 blazer
neo71665's Avatar
Hard to find a 15mm dizzy wrench tho
Old 10-25-2009, 02:49 PM   #9
Lifts are for 4wds!
andysutt's Avatar
Wouldn't know. lol I just know I have seen dizzy wrenchs at stores, but never picked one up, as I dont need them. lol
Old 10-25-2009, 04:05 PM   #10
4X4
Neil2591's Avatar
Mines a 10mm lol, i use a 10mm stubby wrench.
Old 10-25-2009, 09:37 PM   #11
Thanks to everone who replied. I finally got it using a 1/4" drive 15mm wobble. Sure appreciate the responses. Tony
Old 10-25-2009, 09:48 PM   #12
whore turned lurker
dimerunner88's Avatar
i use a 15mm on a 3/8 swivel and 6 inch extension
Old 10-26-2009, 11:43 PM   #13
Yea, that is what worked for me too...
Old 11-02-2009, 05:22 AM   #14
I used a 13mm socket,3" ext., 3/8 swivel, and a 6" ext. I had to go in slightly from the passenger side while standing on the drivers side and guiding it with my right hand. It drew blood but, I got it done.
Old 11-05-2009, 12:53 PM   #15
King Turd Polisher
89Chubby's Avatar
Had to deal with this, too, a few weeks ago. After farting around with a variety of extensions and whatnot, I wound up just sticking a 15mm socket on the end of my 3/8" flex-head ratchet and flexing the head back 90* (right-angle) and applying it directly without any extensions from the driver's side. You don't have to make the thing God-awful tight, btw, so unless the thing is really stuck on there hardcore, you don't need a lot of leverage.
For me, the only thing that prevented me from using extensions was the fact that the wires coming out of the ignition module were totally in the way. Couldn't get a straight shot at it, but using the flex-head ratchet kind of made it an L-shaped wrench that had enough room to clear it. I friggin' love that tool - best $10 or so I've ever spent.
Old 11-06-2009, 03:57 PM   #16
Honor, Grace, and Dignity
Rustdaway's Avatar
I have the snap on 15mm wrench you need to fix that. Let me know your address and whatever shipping is plus a deposit on the wrench so I can get it back is all that's needed. Used it once to adjust my timing and its been in the tool box since.
Or, you can go to ebay and do a search on "15mm Distributor wrench" and spend about $20 to $40 to get one.
Old 11-10-2009, 08:47 PM   #17
get urself a 15mm 1/4 inch drive swivel socket, 6 inch 1/4 drive extension and a 1/4 drive ratchet, works perfect
dont use a 15mm socket and swivel get one of the sockets that has the swivel built into it
Old 11-20-2009, 04:19 PM   #18
mine was a 13MM socket, I used a JOINT conneted to the socket & 10" extension to the join; Go from passenger side through the back next to the ignition coil...
Page generated in 0.59158 seconds with 31 queries
[Output: 96.21 Kb. compressed to 88.94 Kb. by saving 7.27 Kb. (7.55%)]
