.::Custom User Title::.
hesitation while driving
Just here recently my 88 s10, with a 2.8, has been having a lot of hesitation while driving. it dont do it till about 10 mins into driving, itll hesitate and have no power, its like its not getting fuel, then itll start to backfire out of the throttle body. i take the air filter off and its barely getting any spray. could it be the fuel pump, or something related to that? thanks
rolling work in progress
Re: hesitation while driving
i know nothing about this, but i would run some seafoam through it then change the fuel filter and do a full tune up
4x4 v6 blazer
when is the last time then fuel filter was changed
the fuel filter is brand new, im going to do a clean up and see what happens
This is gonna sound stupid, but it might be an easy fix. I had once read you can gain a bit of milage/power if you invert the stock air filter cover. After doing this, I had the same problem. I put the cover back on the correct way and my truck hasn't hesitated, stalled again since. I can only figure by doing this it messed with the readings being sent by the map to the ecm because air is getting into system that isn't being monitored by the map.
whore turned lurker
more than likely the extra air from the inverted lid caused the truck to run lean,probably caused by low fuel pressure. OP,did it do it after you worked on it or just one it started hesitating? u should check your timing,fuel pressure and see if theres any codes in the computer for faulty sensors. my truck hesitates too but only cause i have a bad o2 sensor and its running lean with the engine light on. |
Prob more wrong then just that. I'm still looking at replacing the 02 sensor and muffler system, particularly the cat, which may be clogged. No codes stuck in system. But as soon as I flipped the air cover back over, all my bogging and dying issues went away. Never do THAT again!
