Help with removing A/C
Ive searched on here and cant find exactly what im wantin to know. So here it goes, my air dont work so im wanting to pull it out so can i just remove the air pulley and use a belt for a non a/c truck? Or do i need another pulley to go there? also what about the box?
4x4 v6 blazer
Re: Help with removing A/C
Some have claimed to run a shorter belt and been fine. I like to use the AC delete pulley that the ones without air came with.
Yeah i wanna do it the right way and that seems to be to get the a/c delete pulley. Can i buy that at a parts store or will i have to go to the junkyard?
GET LAYED!!
my truck came with a non AC routing sticker....so you can run a shorter belt
4x4 v6 blazer
The non ac pulley can be found anywhere. It had bearings so it wears out so parts stores carry it. I know they normally all over ebay.
life begins @ 20 psi
![]() After you bolt it up in place of the compressor, run the belt the exactly the same way that it was when you had AC. Getting the compressor out can be "fun" since one of the bolts can be a royal PITA to remove. Just line up the flat side of the head against the compressor and tap it out with a hammer and a punch from the back. |
Alright thanks alot guys. ONe more thing though can i just cut the A/c lines at the heater box and leave them there until i find a non a/c box?
4x4 v6 blazer
Yeah all the lines unbolt. I know this for a fact as I replaced mine last Tuesday and fixed the AC.
They want $30 at Advance Auto for the pulley so ill get it in a few days
Thanks again guys |
stens rule
they wouldnt put that rerouting diagram on it if u had to have that bullshit pully
what?
i dton think it really matters..usually u can get a non a/c belt and it should work without the pulley..but i guess its just what u would feel comfortable getting...id rather have the shorter belt.......
No you need that pulley, I tried like hell to find a way to route it with out it. Turns out you need an 84" belt..which they do not make with the 6 grooves. The A/C belt is 95.5" and the non A/C is 94". This is all true for my 95 s-10 at least.
stens rule
i have a 92 2.8l sten. i took the a/c compressor off and went to advanced got a non a/c belt, been running like this for almost a year with no problems what so ever
I'm running a shorter belt on mine right now. Works fine. Haven't even removed everything, they just gave me the wrong belt at autozone and I needed the truck immediately....and haven't given two shits since. I'll replace it sooner or later.
