Help! No Heat!! - S-10 Forum
post #1 of 33 Old 10-23-2007, 09:39 AM Thread Starter
drewbad's Avatar
User is: drewbad is offline
Help! No Heat!!
Its getting cold out and my truck isnt making warm air! I changed the thermostat. When I turn the fan to the off position and wait, then turn it on, I get a small blast of warmth, but then turns cold again.
What gives??
drewbad is offline
post #2 of 33 Old 10-23-2007, 10:33 PM
i pitty the fool!
swamp_rat's Avatar
User is: swamp_rat is offline
Send a message via AIM to swamp_rat Send a message via Yahoo to swamp_rat
Re: Help! No Heat!!
love your avy. my trucks ac/heater doesnt work all that well either, only the bottom vents blow. odd? and this morning on heat and tep all the way up there was cold air comming out the vents? sorry if it seems like im jacking your thread, im having a similar problem.
post #3 of 33 Old 10-23-2007, 11:02 PM
Call me Mario, Princess
AceHaag's Avatar
User is: AceHaag is offline
Re: Help! No Heat!!
check your coolant level
Mike
my truck
New direction --->Time to get High
2001 s10 ext cab 6.0 243 heads, ls2 cam, nnbs truck intake, 87mm tb, 4l60e, 241c, dana 44's front and rear, 4.30 gears 35" m/t Baja claws.
AceHaag is offline
post #4 of 33 Old 10-23-2007, 11:09 PM
34blazer's Avatar
User is: 34blazer is offline
Re: Help! No Heat!!
X2. and if you dont get heat but only thru the floorvent check the actuator that opens the vent. its hooked to the floorvent
34blazer is offline
post #5 of 33 Old 10-23-2007, 11:17 PM
Supa
Gushers's Avatar
User is: Gushers is offline
Re: Help! No Heat!!
after I changed my water pump my car blew warm air... What is your temp gauge at? If your level is low and it was just up check those leaking places on your water pump. *yes I'm stupid and forgot what they are called
Gushers is offline
post #6 of 33 Old 10-24-2007, 05:19 AM
User is: bikeralan is offline
Re: Help! No Heat!!
Probably your heater core, my son's 88 s-blazer was same. wouldnt hardly give heat, new thermostat, flushed no good, changed heater core now roasts him out.
Alan
post #7 of 33 Old 10-24-2007, 07:35 PM
HappyBuddaBelly's Avatar
User is: HappyBuddaBelly is offline
Re: Help! No Heat!!
If the previous owner, at some point and for some idiotic reason, decided that using hard tap water as a substitute for clean water, like my previous owner... I wouldn't be surprised if your entire heating/cooling system is covered in calcium deposits. It's a general rule of thumb that when you but a new dime, you buy a huge list of parts that, whether you think it needs it or not, MUST be replaced....
When you do the job, buy new hoses, both heater and rad hoses, check the radiator for deposits but avoid using stop leak if you find drips..
LMCtruck.com has most of the parts you need for electronics/vacuum control of the entire hvac system, as well as vents, but I'm not sure about the ducts and diverters..
If all else fails, JC Whitneys sells those little 12v cab heaters, though I'm sure the ladies will LOVE that idea:-p
'91 Sonoma ST
Rust Bucket
3.42 rear end
so many plans
If you live in the Indianapolis Metro area, I'm available for helping with all sorts of projects, especially heavy parts lifting, like transmission jobs without the jack.
post #8 of 33 Old 10-24-2007, 08:00 PM
I SHIT BRICKS
OneLowSdime's Avatar
User is: OneLowSdime is offline
Send a message via AIM to OneLowSdime Send a message via Yahoo to OneLowSdime
Re: Help! No Heat!!
HEATER CORE if u would have told me a week ago i would have shipped u my new one for free. i had to shaved your heat for my rims to fit (REGRETIN THAT its gettin cold out lol) so thats why im buying a 96 s10 for $600 not 6000 600......
post #9 of 33 Old 10-28-2007, 10:31 AM
2lowws10's Avatar
User is: 2lowws10 is offline
Re: Help! No Heat!!
mine has the same prop do you no how to fix it
2lowws10 is offline
post #10 of 33 Old 10-29-2007, 11:43 PM
seafarer12's Avatar
User is: seafarer12 is offline
Re: Help! No Heat!!
Sounds like vacuum problems to me. Either bad actuators or bad vacuum lines.
85 S10 Reg Cab, Long Bed, 2.8, 5spd, Runs like a top.
post #11 of 33 Old 10-30-2007, 12:38 AM
User is: RKR10 is offline
Re: Help! No Heat!!
First I would check the heater core, next I would check for blockage in the air routes, (hoses from fans) worked on my wifes car a week ago with a simular problem and found so much debri, in the form of pine needles and leafs, etc. Once I pulled it all out, wow, heat.
RKR10 is offline
post #12 of 33 Old 11-04-2007, 08:50 AM
2500avalanche's Avatar
User is: 2500avalanche is offline
Re: Help! No Heat!!
I tried this on my 2001. I havent had heat for 2.5 years, and I was not going to pay the 1000 to change the heater core! It took me 15 minutes, and I now have heat!
post #13 of 33 Old 11-05-2007, 09:40 PM
User is: Perkman is offline
Re: Help! No Heat!!
I'm having a similar problem with my 2002 S10. Temp gauge goes up, turn on the heat and all I get is cool air through both the floor vents and dash vents. Steady blowing air through the dash vents even when I'm directing it through the floor vents only.
Seems like some sort of actuator or vacuum problem. Unfortunately, I don't know where the actuator and vacuum hoses are at. Can anyone direct me towards those items?
Thanks.
Perkman is offline
post #14 of 33 Old 11-10-2007, 01:21 PM
Re: Help! No Heat!!
What gives??
I found this heater core back flush procedure on one of the posts somewhere. Has pictures and everything. I just finished back flushing the heater core on my 2002 S-10. The heat works great now!
I was getting very little heat in the vents and I couldn't get air to flow through the vents correctly. When I had the defroster or the heat on, the air would still flow through the a/c vents into the cab. I checked the heater core hoses and, sure enough, one was warm/hot and the other was cold.
I followed the procedures on the attached link and it worked great! The only things I did differently: I attached a 1/2 inch garden hose with the end cut off directly to the small firewall hose and attached some clear vinyl tubing (3/4" inside diameter) to the large outlet (on the left). I also soaked it for about 30 minutes with radiator flush.
http://aycu21.webshots.com/image/308...1713342_rs.jpg
Many, many thanks to whomever took the time and trouble to post this procedure and the pics. Unfortunately I can't find the original post to thank them in a reply.
Good luck.
Perkman is offline
post #15 of 33 Old 11-14-2007, 07:31 PM
Mexican in Alaska
91blks10's Avatar
User is: 91blks10 is offline
Re: Help! No Heat!!
I had this same problem in my wifes 2000 silverado. Come to find out I had an air bubble in it. I got the truck up to running temp and slowly pulled the out line off the heater core. Dont pull it off all the way you'll get antifreeze everywhere. You can hear the air coming out when doing it. After that the truck started blowing hot to where you only need it on low.
Luis
18' Kruz K-08 Snowdowns
Dual 380's Dual 5 Gal Tanks
Cando Specialties 6 Link
http://www.cardomain.com/ride/2600254
http://www.myspace.com/weez_25
91blks10 is offline
post #16 of 33 Old 11-17-2007, 05:14 PM
Yes, those are my feet
Web-Foot Freak's Avatar
User is: Web-Foot Freak is offline
Re: Help! No Heat!!
In a nutshell.
Make sure your cooling system is working (not overheating), and make sure the coolant is topped off.
Make sure your tstat is working (not running too cool). An inop tstat, or even one rated to open cooler can affect the heating system.
Backflush the heater core. Pull both hoses (NOT @ THE BULKHEAD) and use you hose sprayer to push water through both ways. If there's crap in there, this can help.
After that I'd go for a new core.
NOW... about airflow.
Heat selection runs off a cable (to the blend door). Make sure this works. There is an adjustment too.
Vent selection runs off vacuum. Make sure it is hooked up. You can take a mightyvac and pull a vacuum on just that part of the system to test it. You can also pull the cover off, and test each tube seperately.
If there's any more ?'s, just post em up
14 Town & Country
10 Town & Country
95 s10 (needs motor)
13 Felt Z100 (w/aerobars)
post #17 of 33 Old 01-11-2009, 09:30 PM
User is: wrenchn2 is offline
Red face Re: Help! No Heat!!
What gives??
Just fixed 2001 blazer low heat problem. I bought (2) 5/8 to 3/4 hose adapters and carefully removed and reversed hoses at heater core. I drove the truck 20 minutes and had to turn the heat down it was so hot. Then I removed the adapters and hooked up hoses the way they were. All is good now.
Note: I used a small meat hook to carefully break the hoses loose from the bulkhead I didn't want to cause leaks and have remove the dash to replace heater core.
wrenchn2 is offline
post #18 of 33 Old 01-11-2009, 11:43 PM
4x4 v6 blazer
neo71665's Avatar
User is: neo71665 is offline
Re: Help! No Heat!!
11-17-2007, 03:14 PM
Really? Ever heard of a dead thread. At least you used the search feature but if you done it on a 2001 it wasn't a 60 degree v6 so your in the wrong section to boot.
87 blazer tahoe 2 door, 5.7, auto, sfa 4x4
91 noma reg cab, 3.4, 5speed, lowered
President of the Arkansas chapter Anti-bag Coalition
"Bags are for groceries"
Originally Posted by alarm_the_alarm View Post
Lift That Sh*t, Fat Girls Can't Jump
i just made love to your bowels......and then reported them.
neo71665 is offline
post #19 of 33 Old 01-12-2009, 02:44 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Re: Help! No Heat!!
I can't argue with this!
Teamsters Local 1150
SH-60B is offline
post #20 of 33 Old 01-12-2009, 04:39 PM
4x4 v6 blazer
neo71665's Avatar
Re: Help! No Heat!!
Thats a first
neo71665 is offline
post #21 of 33 Old 12-11-2009, 01:16 PM
User is: Miekk is offline
Re: Help! No Heat!!
Miekk is offline
post #22 of 33 Old 12-11-2009, 01:16 PM
Re: Help! No Heat!!
What gives??
For anyone with this exact problem.. i.e. it blows hot for a second or two then goes and stays cold, it's NOT the heater core. Key phrase: "blows hot for a bit". It's a broken gear in the blend door actuator that's behind the glove box.
Dealer wants 6 hrs. Start to finish was 20min with the right tools. If you don't have time and want heat, make sure key is off and temp set to heat, while watching and listening to the actuator, turn key back on. The actuator will actuate to the hot side and back to cold because it's confused... repeat steps and when the actuator is at full hot position, unplug it. You can plug it in when the weather gets warm again...
Miekk is offline
post #23 of 33 Old 03-26-2010, 05:13 PM Thread Starter
drewbad's Avatar
Re: Help! No Heat!!
I won't let this thread die.
A flush ended up fixing this. I must of had a clog or maybe even air in the system, but now it's a couple years later and another heat problem.
I'm back searching threads because I'm getting glycol in the airvent so I prolly need to tear the dash out and check out the core. Good thing it's getting warm..
Funny that i came across my own thread! Lots of good info in it.
drewbad is offline
post #24 of 33 Old 10-05-2010, 12:43 PM
User is: ericakabob is offline
Re: Help! No Heat!!
almost three years old and still alive. After reading what yall have wrote im going in and checking out my truck.
88 4x4 4.3 with 3 inch lift sitting on 31/10.5's extended cab with A/C (had to aid that)
post #25 of 33 Old 08-15-2012, 12:58 AM
User is: triggerman357 is offline
Re: Help! No Heat!!
I'll bring it back now because I'm having this problem. I'll be changing my t-stat in the morning hopefully to fix it. It'll be cold soon.
post #26 of 33 Old 08-15-2012, 10:07 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Re: Help! No Heat!!
Holy batcrap Batman... it won't die!
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best)
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
post #27 of 33 Old 09-27-2012, 02:48 AM
User is: Atomkinder is offline
Re: Help! No Heat!!
Still not letting it die. New member here, found because I recently purchased my S10 ZR2 (used, of course) and am also having this problem. However, I seem to be in a strange bind. I'm getting hot lines both in and out (as best as I can tell) with absolutely no heat. I can hear the servo move when I turn the heat all the way up, and my thermostat is acting perfectly normal. I don't know enough about the truck to diagnose this myself, and so far the only recommendation I've gotten is to have the heater core replaced, which is either expensive, or a HUGE PITA. While I'm betting I could do it in a weekend, I don't want to if I don't have to. Any suggestions beyond those offered already would be most appreciated.
post #28 of 33 Old 09-30-2012, 10:09 PM
User is: bonestock is offline
Re: Help! No Heat!!
I f you are getting hot hoses both in and out of the core then the core is open and not needing a flush. If not getting cooland in the passenger floor or smellilng coolant from your vents, then the core is fine and not needing changed. I am thinking of the blend door operation. open the heater control panel and check that the cable is attached to the body with a screw-- seen several unhooked and the door does not change.
good luck
Bonestock
post #29 of 33 Old 12-22-2013, 11:58 AM
User is: Riff Lapin is offline
Re: Help! No Heat!!
I am having a similar problem with my 2001 S-10. Sometimes I get a brief blast of heat, then it goes cold.
I just flushed out the heater core, and installed a new thermostat. That didn't help. Additional info: both hoses to heater core remain cold. I'm at a loss as to where to proceed.
post #30 of 33 Old 12-22-2013, 03:47 PM
Re: Help! No Heat!!
update: I noticed that if I now raise the engine speed, I will get heat from the vent. But it will get cold again when I return to idle.
I also noted that so far the lower radiator hose is not hot while the upper one is.
post #31 of 33 Old 11-16-2014, 05:43 PM
User is: Biggyhuslaz is offline
Question Re: Help! No Heat!!
Just went to Auto Zone and bought the two under the hood hoses that run from my heater core and flushed my heater core out with a garden hose,got the water running clear on both openings,connected my hoses back ( the new ones ) bingo,I have heat again,for how long I dont know.... I put a new Thermostat in about a month ago with no luck...I,m looking at my vacuum lines and replaced a couple of those but now see more that I need to replace because inside the radiator the water is not flowing like it should,Im not sure if this whole heating ,cooling system is controlled by vacuum or not ?????? Anyone happen to know....
post #32 of 33 Old 11-16-2014, 05:57 PM
post #33 of 33 Old 11-17-2014, 03:21 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Re: Help! No Heat!!
Jesus this thread may never die.
I had this happen on my ex-wife's 2000 Blazer. It had that Dexcool crap in it, and it clogged up everything. I backflushed the system with the little cheap Peak kit and what do you know! Heat. Drained the rest of that garbage out of the system. GM should be sued over Dexcool.
1984 xcab s-10 3.4L GM crate engine 87 S10 TBI swap w bored intake, Edelbrock headers. 3.42 locker rear end swap. Flowmaster, shift kit, e-fan.
EFI swap http://www.s10forum.com/forum/f106/c...e-help-513616/
My build thread (3.4L)http://www.s10forum.com/forum/f106/b...stions-427168/
I had to cut my nut in half .
