Gas Milage issues
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 10-11-2009, 05:44 PM   #1
Gas Milage issues
While I'm saving for another vehicle to use as my daily driver, so I can do a swap on my '88 S-10 4x4 2.8L 700r4 w/ 124,400 miles... I've a few issues with milage and still smelling gas in the cab.
Since purchasing, I've...
gapped and replaced plugs
replaced wires
replaced cap and rotor
replaced module in dizzy
replaced IAC
replaced fuel pump
replaced air filter
I have a gut feelling that part of my gas milage issues is related to my dying transmission. I avoid steep hills and bridges as much as possible because I'd have to have the gas pedal to the floor, just to hit 30mph!
Things I'm concidering on replacing in the near future...
02 sensor
Map sensor
Clean and/or replace egr valve
replace serpentine and/or tensionor as nessary
This coming week I'm already set to replace my oil sending unit while doing that I'm going to replace the gas vapor filter. Both are within this weeks budget.
Once I have these things done, recheck timming...
There are two other things I may try as well, wish to hold off on for a bit longer. That is...
Rebuilding the TBI. I haven't decided whether I'm going to use keep the current 2.8L tbi until I do engine swap or upgrade to a 4.3L tbi. Why rebuild the smaller one only to upgrade to the lager one later?
It's quite possible, concidering how badly this truck was maintained, that the cat is bad. I know from visually inspecting and seeing holes in the muffler system... the whole thing needs to be replaced. This will be done the same time I swap the trans out.
Is there anything I'm missing? I surely would like to get more then 9-10mpg's that I am now. And then there's that issue of actually smelling gas in the cab that concerns me. I've checked and rechecked...no leaks anywhere from tank to filter to tbi... Suggestions?
Thanks
Jax
Old 10-11-2009, 11:52 PM   #2
first car and proud
93v6banger's Avatar
Re: Gas Milage issues
02 sensor was the best maintenance i did to my truck when i first got it.
Old 10-12-2009, 12:38 AM   #3
Revolt's Avatar
After all those replacement items, I'd go simple and check compression.
Double check for leaks, leaking gas isn't visible long before it evaporates.
Old 10-12-2009, 03:26 PM   #4
Whats this for?
mr spree's Avatar
yea 02 sensor for me too
Old 10-18-2009, 01:24 AM   #5
If your smelling gas in the cab, then it might just be a fuel leak. You should really check it when the tuck is on. When it is on, there is fuel pressure which would make it easier to detect the fuel leak. Also do a compression test, gas fumes can build up in your crankcase due to bad rings.
Old 10-20-2009, 01:31 PM   #6
King Turd Polisher
89Chubby's Avatar
Have you checked for vacuum leaks already?
Pulled the EGR valve to inspect/clean it?
Checked your ignition timing?
Page generated in 0.56830 seconds with 31 queries
[Output: 57.23 Kb. compressed to 54.20 Kb. by saving 3.03 Kb. (5.29%)]
