doin a 3.4
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 06-25-2009, 05:01 PM   #1
long91's Avatar
doin a 3.4
i have a 88 blazer 2sr 2wd lowered a lil 5speed...i got the bad 2.8 out and i pulled a 3.4 out of a 95 camaro my friends lil brother wrecked. i got the 3.4 pretty much stripped. i found a pretty detailed explanation on how to do it...
http://members.shaw.ca/betterthanyou...ine%20swap.htm
what im gettin at is id like some opinions from guys thats done the swap on what i should do and or dont do. like is using the camaro water pump a good idea even tho it turns in the opposite direction. any tips and pointers would be greatly appreciated
Old 06-25-2009, 05:42 PM   #2
34blazer's Avatar
Re: doin a 3.4
no dont use the f body water pump, use all the accessories off the 2.8
Old 06-25-2009, 07:05 PM   #3
Re: doin a 3.4
Why?
The only issue I remember from doing it was the A/C compressor. If you don't have air, I don't think it will be a problem. By the way big differance in how the 2 motors run
Old 06-26-2009, 03:37 PM   #4
long91's Avatar
Re: doin a 3.4
yea i was thinkin should use the 2.8 water pump and im not planning on using the air. i have the 2 motors both with all the accessories...what parts and gaskets am i going to have to buy to do the basic swap of parts? do you guys just use 4.3 injectors in the tbi?
Page generated in 0.56363 seconds with 31 queries
[Output: 50.15 Kb. compressed to 47.82 Kb. by saving 2.33 Kb. (4.64%)]
