distributor question
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 09-06-2009, 03:45 PM   #1
recently replaced dist. cap rotor now i notice that i can grab top of cap and the shaft i guess it is wiggles back and forth possible cant be tight or dist shot anyone help thanks
Old 09-07-2009, 10:31 AM   #2
Re: distributor question
anyone know why can move dist back and forth possible it could just be loose?
Old 09-07-2009, 12:19 PM   #3
Registered Neanderthal
SH-60B's Avatar
You need to tighten the hold-down clamp. The timing is probably altered now, so you'll need a light to re-set it.
Old 09-07-2009, 12:46 PM   #4
how do i access the hold down clamp like a can of sardines back in there
Old 09-08-2009, 02:01 AM   #5
4x4 v6 blazer
neo71665's Avatar
um suck it up and squeeze back there
Old 09-08-2009, 08:09 AM   #6
where is the hold down clamp what i meant know back there somewhere but cant see shit
Old 09-08-2009, 11:31 AM   #7
4x4 v6 blazer
neo71665's Avatar
Its the only bolt back there at the base of the dizzy, you won't hardly be able to see anything with your hand back there. One of those things you just got to feel for it.
Old 09-08-2009, 04:37 PM   #8
blown up .....again
Shaggem's Avatar
I use a 6" extension and a swivel to tighten my distributor bolt.
Old 09-12-2009, 01:08 PM   #9
anyone know what size socket it is by any chance
Old 09-12-2009, 01:39 PM   #10
4x4 v6 blazer
neo71665's Avatar
15mm if I remember right
Old 10-03-2009, 12:49 PM   #11
I want to change my computerized distributor that is in the car now but I want the old points type distributor and coil a non-computerized one. I hate the computer system, with all of the wiring I thought I wasnt going to find the end of all of that wiring. and I am changing to a carb setup can anyone help me find a non electronic computerized distributor and what vehicle and year that I can find it.
Old 10-05-2009, 10:44 AM   #12
SH-60B's Avatar
GM hasn't used points since '75. Get an HEI for a carbed 2.8 '85 and earlier.
Page generated in 0.58145 seconds with 31 queries
[Output: 74.05 Kb. compressed to 68.94 Kb. by saving 5.11 Kb. (6.90%)]
