Computer friendly camshafts - S-10 Forum
post #1 of 7 Old 04-19-2017, 02:54 AM Thread Starter
Rotbox's Avatar
User is: Rotbox is offline
Ok. I've had a slight change in plans for the overhaul of my 2.8. Desided to look for a cam that will keep the ecm happy, but not sure which is better for a work truck. The believe the a.r.i pro-builder phase 1 OR Crane CompuCam 2020 would be ideal because of the plow, but want opinions. Cant find any reviews of either cam. I guess I should note it has 3.73 gears and is automatic. Will probably add headers later on, but currently just want to get my truck back on the road.
Rotbox is offline
post #2 of 7 Old 04-19-2017, 08:57 AM
oldeerslayer's Avatar
User is: oldeerslayer is online now
Re: Computer friendly camshafts
This is probably a dumb question, but why would you go to the expense of an aftermarket cam for a 2.8 that you plow with? What is wrong with a quality stock replacement if you think the cam is in need of replacing? I also think headers is a BAD idea for a plow truck. You do not need an increase in engine compartment temps and the moisture will destroy them quickly.
post #3 of 7 Old 04-19-2017, 05:03 PM Thread Starter
Rotbox's Avatar
The original cam is just starting to show signs of failure(one lifter is slightly dished). Also everyone says the stock cam as well as the exhaust manifold is worthless. Haven't seen anyone say anything good about the factory parts. All say there restrictive. If I stayed with a stock cam(and felt brave enough) I could reuse the cam out the blown original motor. It's the only part that wasn't damaged. The issue of moisture was one of the reasons I decided to hold off getting headers. I never plowed before, so I probably wouldn't use it much. Just a few times a year to clear my street.
Rotbox is offline
post #4 of 7 Old 04-20-2017, 01:18 AM
I'm not a big fan of re-using camshafts. They are pretty much matched for life to their lifters. It's the reason you do a break in sequence on a rebuilt or new engine. The newer engines with roller lifters don't require the extended break in procedure because the cam and lifters don't need to be worn in.
Regarding the restrictiveness of the cam and manifolds on a stock 2.8, I don't think you'll gain 10 hp. After all it is the smallest engine GM put in a 4x4. HP is a top end thing, torque is what gets a 4wd vehicle moving. Granted a towing type cam can ad a bit of torque, but cubic inches, especially stroke are where it truly comes from.
I've been plowing for 50 years and heat is a major problem because the truck never gets any air flow. Just working very hard at low speed. Plow trucks used regularly require a lot of maintenance.
JMHO
post #5 of 7 Old 04-20-2017, 04:50 AM Thread Starter
Rotbox's Avatar
JMHO
I agree. I figured mileage may improve slightly as I see a lot of people saying the 2.8 gets horrible mileage. I dont think heat will be a big issue. This truck is equipt with a 3 core radiator, which is apparently a rare option. Should be enough to keep things cool. Once running/driving and trans proves to be working properly, I plan to add a auxiliary trans cooler. Plow will rarely be used. Heck i think the last time I even saw it mounted was 3-4 years ago.
Rotbox is offline
post #6 of 7 Old 04-20-2017, 10:22 PM
User is: Xnke is offline
It's funny, I always got 26-28MPG out of my 2.8L S10's...I don't consider that "horrible" mileage at all...
The stock computer will handle the stock cam. It will not be happy with bigger cams...it may run, but then again it may not. The Compucam solution is pretty much just to satiate the people who just gotta cam that engine...they do not make any appreciable horsepower over the stocker-because doing so would require moving more air, which would require a fueling adjustment that the stock computer does not handle well.
Headers-same kinda thing. Until you're turning 3000-4000RPM, stock manifolds are going to keep up with headers within 5-8HP.
If you need more power in a plow truck (who plows in an S10? Just not enough weight there???) you need more cubic inches.
Xnke is offline
post #7 of 7 Old 04-21-2017, 06:10 AM Thread Starter
Rotbox's Avatar
Yeah, ive read they are capable of high 20s, but also seen a number of people saying there getting 10-12 mpg highway which is kinda sad. I think the phase 1 cam is mild enough that the computer wont notice the difference, but might cave and get a stock replacement. Yep, not many s10 plows. Good enough for fresh powder, but probably worthless in the heavy stuff.
1988 GMC S15 Gypsy 4wd longbed (rotted parts truck)
1987 Chevrolet S10 4wd longbed (work in progress)
Rotbox is offline
