Check Engine Light
Question for you guys, my CEL comes on sometimes, but goes back off after a few seconds. Does this computer "store" codes so I can pull them? Or do I have to pull them while the light is on?
Oh yeah, 1992, 2.8, 5sp, 209k on the ticker, runs like a swiss watch, burns no oil, but leaks it EVERYWHERE! *lol* |
4x4 v6 blazer
Re: Check Engine Light
It'll store them until the battery is unhooked or the ecm fuse is pulled.
2in da pink 1in da stink
Location: Levittown, PA-☆-NE Philly-☆-Trenton, NJ-☆Tha 19057 Bitches☆ User is: OffLine |
just put some black tape over it and be done with it.
4x4 v6 blazer
Or just fix it, have it run correct, get the correct gas mileage, and have it pass emissions (if you have them). |
No emissions here, but I wanna get it fixed, because that CEL means something ain't right somewhere. |
I had an '84 auto/2.8 that would flash the CEL occasionally. The problem was some missing insulation on the oxy sensor line near the frame. At a certain speed, the slipstream in that area would push the wire against the frame and ground out.
4x4 v6 blazer
lol |
i basically had the same issue if i was getting on the freeway or something accelerating sometimes my check engine light would come on flash a cpl times then go away
i took it in to the dealership and my truck was misfiring so that maybe a issue im not sure if u can have a general read cause when they read mine they were able to tell me how many miles ago and what speed i was going when it happened |
