best carb?
what is the best carb to run on a 2.8?
any info will help have not found much on it |
Re: best carb?
I like the Holley 390 with the Edelbrock intake that I have on my 84. Big performance upgrade from stock, and not much more $ than a stock replacement.
-james |
^ Im With Stupid ^
Location: Levittown, PA-☆-NE Philly-☆-Trenton, NJ-☆Tha 19057 Bitches☆ User is: OffLine ![]() |
Re: best carb?
this one could could on for awhile...
Re: best carb?
No, no reason it should "go on" - the best carb is the one that fits, works, and is tuned and built properly.
I prefer the orig, rebuilt Rochester 2se/e2se. Not a power choice but they run well for daily driving/some hauling and can be rebuilt and tuned for maximum economy (and it bolts right on without work). i'm personally not a fan of the Holley options for these trucks, nor much for the webers but they will provide some more beef. check out guaranteedcarbs.com for some good pricing. |
4x4 v6 blazer
Re: best carb?
Best carb depends on the mods done to the motor first. Not a big fan of holleys myself on anything but race motors. Never tried the webers so I have no clue. Even still why do you think you need to upgrade the carb?
Re: best carb?
I have two webers, one's on an edelbrock set-up the other on stock motor. Love them, they are a little tricky to set up (read directions carefully) - thats because even thought its a two barrel carb it's really two one barrel (two mixture screws). The weber 38 DGES would be my choice for power and gas mileage.Also you retain stock air cleaner.
Re: best carb?
i want to get rid of the EGR and all the vacuum hoses and junk all over this thing.
is this a good idea or what should i do? this carb sputters at 60 and thats as fast as i can go. everything else check out fine but i never really have messed with one of these carbs befor. and it idles fine but has no power at all. do you guys now of any print outs of a break down of these carbs? i dont have a book on the s10 |
4x4 v6 blazer
Re: best carb?
www.autozone.com
sign up, enter in your trucks info, get free online haynes manual. Its not as good as a chiltons book but its better than nothing. |
Re: best carb?
Joed and I will never agree on carbs, but I totally respect his opinion! I still like the Holley on the truck. It certainly raises eyebrows whenever somebody looks at it that knows anything about S-10s. I really got frustrated with the factory carb, but my truck had other issues besides the carb at the time.
Joed probably has a good point though. His truck is a daily driver, and mine sits around the house a lot. (Mainly cause the mains knock a little when you first start it and I don't have time to rebuild it....now 260K)! Simplicity wise, the factory is probably best for reliability. However, if you want some juice.?.?...? -jk |
Sucking dick while being Banned
Re: best carb?
