Backfire, missing, rough idle 2.8L - S-10 Forum
post #1 of 13 Old 10-02-2010, 04:26 PM Thread Starter
User is: heavies is offline
86 s-10 Blazer 2.8L TBI
lost power going home one day, very rough idle, dies when placed under load if you are lucky enough to get it to run long enough....
have replaced;
ECM (mechanic shop placed 30A fuse in the 10A ECM panel)
TPS (was coding)
EST Control Module (42 code, however that stupid f'ing capacitor thing is not in there it came unsoldered and didn't have enough wire to solder back)
currently no codes however the damn thing will not run past a few seconds w/o constantly pumping acclerator pedal, when revving higher you can here misses, and backfires thru TB, runs like absolute dog crap..... if I unplug EST in pigtail inside main harness to set timing, the closer to 10 deg TDC the sh!tter it runs..... I am at a loss here...... this thing makes no sense..... what else could it be????
...would that stupid capacitor not being there cause this?
heavies is offline
post #2 of 13 Old 10-02-2010, 04:40 PM Thread Starter
Re: Backfire, missing, rough idle 2.8L
I guess the only thing left to replace is the ESC??? would it no throw a code though? perhaps it won't throw the code because it won't run long enough, i.e. go to closed loop mode?
heavies is offline
post #3 of 13 Old 10-02-2010, 07:31 PM
McBride73's Avatar
User is: McBride73 is offline
have you tried doing the timing?
1987 2dr jimmy 4x4 recovery in progress, new fuel filter, starter, alternator, shocks, EGR valve & solenoid, drivers half-shaft, BJ, fuel pump(shop bill of $321)wrote off, new DD; 1993 Dodge dakota sport 4x4
post #4 of 13 Old 10-03-2010, 09:08 PM
Mr. SQ
bobditts's Avatar
User is: bobditts is offline
that capacitor is a ground. IT NEEDS TO BE GROUNDED
bobditts is offline
post #5 of 13 Old 02-19-2011, 04:19 PM Thread Starter
Bro's.... SOS....I am still f*cking with this truck...... I have replaced capacitor in dizzy, TPS, ECM, EST, set the timing to manuf. recommendations on under hood sticker, by manually finding TDC on #1, then back off 10 deg. BTDC...... run terrible, smells rich, stumbles, bogs, sounds like it is mising, fuel pump appears ok.... I am at a loss, what could this be..... no codes..... but runs like shit!! when you push it to the floor stumbles sounds like missing then catches, let off dies at idle.... very wierd any help would be MUCH APPRECIATED!!!
heavies is offline
post #6 of 13 Old 02-19-2011, 04:52 PM
S 10 NOOB
User is: ghost87 is offline
Send a message via AIM to ghost87 Send a message via MSN to ghost87 Send a message via Yahoo to ghost87 Send a message via Skype™ to ghost87
Okay so all of you are going with the computers. You need to start thinking mechanical.
Do a valve job. I am sure that your valves are starting to become over adjusted.
Its seriously the simple things to fix that you need to do first that is under talked about on these forums.
ghost87 is offline
post #7 of 13 Old 02-22-2011, 02:15 PM
Awww..you ain't got shit!
jimmykicker's Avatar
Check for huge vac leaks with a spray bottle. Compression test is definitely in order too.
1984 xcab s-10 3.4L GM crate engine 87 S10 TBI swap w bored intake, Edelbrock headers. 3.42 locker rear end swap. Flowmaster, shift kit, e-fan.
EFI swap http://www.s10forum.com/forum/f106/c...e-help-513616/
My build thread (3.4L)http://www.s10forum.com/forum/f106/b...stions-427168/
I had to cut my nut in half .
post #8 of 13 Old 02-23-2011, 07:57 PM
roofless's Avatar
User is: roofless is offline
my truck was doing the same thing when the ICM was bad.its under the dizzy. 30 bucks. in my case it was still throwing spark but apparently not enough to keep it running..
roofless is offline
post #9 of 13 Old 02-24-2011, 01:35 AM
86' S-10
User is: GEARS is offline
Here is what I can think of...
After cheking for the basics... such as vaccum leaks with a spray bottle, TBI bolts torque, and intake manifold bolts torque, a compression test, coil test, spark test, valve adjustment... I'd look into the following:
1) I worked on my school secretary's car. It was a 3100 motor and it bogged, sputtered, stumbled stalled, no power, could barely run... and I ended up replacing the in-tank fuel pump and ran perfectly fine (... that 3100 had like no bottom end pull the way my 3.4 iron head does...).
2) It could be the TPS wiring to the ECM... and a clue would maybe be the fact that you were getting a code. I took off the TPS plug on the old 2.8 just to see what would happen, and similar results happened to what you described. Make sure the TPS is et to about 0.48V in idle position... do you know what I'm talking about??
3) ICM under the dizzy... these modules create a whole wack-load of problems when they get old!!!
4) I have gotten a TPS code for a MAP sensor before... and when the MAP goes the motor runs like a bag of....umm....poop...
5) See if you have a toast injector or 2... a injector died on my old 2.8 and again, similar engine problems to what you describe. Look for a nice even spraying cone coming out of both injectors... make sure you don't see any skipped beats (pulses).
6) If your fuel filter is clogged (which I highly doubt... but you never know...) you may be getting a really lean mixture causing it to run rough and sometimes even miss.
1986 S10 PU "SCLB" 2WD 5speed
HT3.4 TBI powered. Holley, Edelbrock, Heddman, MSD, Mallory, Araura, Crane, Comp, Cloyes, Flowmaster Equiped, and a bunch of custom head work and other fabrication... Supercharger build underway!
GEARS is offline
post #10 of 13 Old 02-25-2011, 09:41 AM
roofless's Avatar
well what was the scoop? did you fix it? sell it ? set it on fire and make smores?
roofless is offline
post #11 of 13 Old 02-25-2011, 03:52 PM
playawolf's Avatar
User is: playawolf is offline
What jimmykicker said... check your vacuum lines and compression. The problems aren't always electronic. I don't have *any* electronics in my '83 to mess with so I went straight to mechanical issues, and I found the rings were shot. Now it's fixed and it runs like I just drove it off the dealer lot...
1983 S15 Jimmy 2.8L V6 5-Speed 2BBL 4x4
post #12 of 13 Old 02-25-2011, 09:03 PM
chevy<ford's Avatar
User is: chevy<ford is offline
it might have jumped time just 1 tooth will do this. it happened on my 2.8 when it skips a tooth and you go to retime it the mark will be on the degree but still be shitty you might wanna spend the whole hour or so it takes to yank the front apart and check your chain. if it's stretched that will also cause it to run like shit. but it sounds like it might be that it skipped a tooth though. did you hit any bumps or anything in that nature?
post #13 of 13 Old 02-28-2011, 06:52 PM
Even though I can't agree Chevy is less than Ford, I can agree with this. ↑
I think it's worth pulling the cover and looking. If you haven't done a compression test yet, I'd highly reccommend you do that before anything else.
