I bought my 84 S10, ext cab, 4X4, 2.8 ltr. and it has a few issues, all related to some idiot not knowing what he was doing.
The air pump is missing. Bracket is there, pump is not. Should I replace it or remove the bracket and forget about it? I do not have emissions where I live.
Vacuum issues. No vacuum lines going to air filter assembly. Only tube from pass valve cover.
Air tubes from exhaust manifolds are plugged. The entire tubes are missing and their ports on the manifolds are plugged.
The motor runs strong. The sticker showing where all vacuum line run to is missing. Should I put all back to factory or remove it all?
If it will not harm anything I would rather remove all unneeded vacuum /air related crap.
What is the bare min. needed to still run/perform right?
