'87 S10 Blazer ?'s - S-10 Forum
'87 S10 Blazer ?'s
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 04-07-2004, 10:19 PM   #1
'87 S10 Blazer ?'s
I just got a k&n filter for my 87 S-10 Blazer with stock 2.8 and was wondering about some rumors i have been hearing, some people have been saying to flip my air cleaner lid over? does this get more air or is this just another stupid rumor? also i was thinking about gettin a tbi spacer with a helix spiral cut into it. would this do anything also before i go spend money? thanks for the feedback.
Old 04-07-2004, 11:05 PM   #2
Sticks's Avatar
Re: '87 S10 Blazer ?'s
Check out 'flipping the lid' thread in this forum. Maybe that will help
Old 04-08-2004, 12:47 AM   #3
Ahh...flipping the lid may make your engine sound louder...but since you'll be sucking in hot engine compartment air you probably won't see any power.
Some TBI engines pick up a little from the spacer...don't expect too much and you probably won't be disappointed. I never put one on my 2.8 so I can give you specifics there.
Personally, since the 2.8 already has a massive air filter area (same as a 4.3) I don't see that you're going to pick up much there anyway. The pre-88 2.8 has the small diameter exhaust, so if there is a breathing bottleneck, its there.
I personally avoid K&N's on non-race cars...they aren't always a problem, but they often cause high silcon levels (sand) in the oil and higher wear metal levels. The HP/mileage gains over a good paper filter are trivial in most applications(read undetectable on the dyno half a percent of an engine's horsepower on a camaro). (Note I'm talking drop in filters here, the cold air intakes are a whole different matter).
Espicially without oil analysis (man, i sound like a broken record about that) I'd have a profoundly bad feeling about running K&N in most applications. Crude Test: If you want to scare yourself, take a new K&N and pour fine dust or flour on it...at least with mine, pleny fell through onto the black paper underneath.
Old 04-09-2004, 07:12 PM   #4
so what yur saying is that i basically waisted money on my k&n filter and it was a bad way to go? well i hope that it ain't the case for mine. i am definatly gonna try the dust test though. i think i might also avoid the spacer. well alright then thanks for the feedback.
