85 2.8l firing order? and what is #1 on dis cap - S-10 Forum
post #1 of 11 Old 03-28-2013, 09:57 PM Thread Starter
Red Dog's Blazer
Chris's_96Blazer's Avatar
User is: Chris's_96Blazer is offline
Send a message via Yahoo to Chris's_96Blazer
ok so i changed the plugs and dis cap today I thought i keep the wires stright but guess was wrong. What is #1 on the cap? is it the one even with the pass side hold down bolt, or is it the one before that?
I have gotten all sorts of answers on the numbers and firing order.
right now I have it 6 4 2 driver side.
5 3 1 pass side. 6 and 5 being the front, it almost cranks like this.
on the dis. cap i have it 123456 going clock wise.
Please help I am going crazy I realy wish i could buy a manual for it but im broke. trying get it running good enough to drive daily
thanks
"If its too loud,your too old"
1998 Blazer 4d 2wd.Stock.
Chris.
post #2 of 11 Old 03-28-2013, 10:12 PM
User is: The_Raven is offline
Re: 85 2.8l firing order? and what is #1 on dis cap
1 is the passenger front.
Firing order is 1,2,3,4,5,6.
Rear of engine
5 6
3 4
1 2
Front of Engine
Terminal #1 could be any of them.
Best is to get the #1 cylinder on TDC and see where the rotor is pointing.
'Bu: The daily driver
post #3 of 11 Old 03-28-2013, 11:46 PM Thread Starter
Red Dog's Blazer
I had it hooked like that and got nothing out of it, guess I had the #1 in the wrong spot. How can it be anywhere? I only pulled cap off and put new one back on, well now i have the stock one back on cause thought something screwed up on new one.
Chris.
post #4 of 11 Old 03-28-2013, 11:52 PM
It depends on what position the dizzy was installed in, relative to #1 TDC. Since we can not verify that the dizzy has never been removed or replaced, it's impossible to say that a specific terminal is the #1 terminal. This is why I suggested bringing the #1 cylinder to TDC on the compression stroke and seeing where the rotor is at that point.
post #5 of 11 Old 03-29-2013, 12:31 AM Thread Starter
Red Dog's Blazer
OH..... I understand what your saying, Oh crap... I really should had made 100% where #1 was if no other.
Its been way to long, how do i check that? when I took the cap off I noticed the rotor button was pointing to about 7 o clock, if the front of the cap (toward front of motor ) was 12 o clock
so does that mean that is #1 back there? so start there?
Chris.
post #6 of 11 Old 03-29-2013, 10:22 AM
Gary Sauer
User is: Rusty Dime is offline
Here I will walk you through the steps:
1. take distributor cap off
2. remove cylinder #1 spark plug
3. put a socket and ratchet on crank pulley bolt
4. rotate engine until cylinder #1 is at Top Dead Center You can do this by placing a long screwdriver in the spark plug hole or your finger over the hole
5. then look at the ignition rotor to see where it is
6. mark it on the dist. cap
7. put cap on
8. put plug back in
9. then proceed with placement of the wires per firing order
Gary
1998 S10 LS 2.2 - "GS Motorsports" air intake, Thrush turbo muffler and rusty, very rusty
post #7 of 11 Old 03-29-2013, 11:17 AM Thread Starter
Red Dog's Blazer
Thanks, Sorry about what i said, I was wore out lastnight and wasn't thinking straight. so while the pistion is up on #1 witch is the passenger side front piston. wherever the rotor button points is #1 for the cap. then you just wire it up for 123456
This should be right then, I think Im going to mark my wires today
135 pass side
246 driver side
Chris.
post #8 of 11 Old 03-29-2013, 12:04 PM
Gary Sauer
yes but make sure you wire it in the direction the rotor turns.
Gary
post #9 of 11 Old 03-29-2013, 01:33 PM
Make sure when the #1 piston is at TDC, it's on the compression stroke. The piston will be at TDC twice for a complete cycle, once on the compression stroke and once at the end of the exhaust stroke.
There are a couple ways to check for compression stroke.
One way is to remove the rocker cover and observe that the rockers are both up when the piston is at TDC. This is the best way IMO.
Another way is to bump the engine over using the starter, with the #1 spark plug removed and your finger over the spark plug hole. When the pressure builds, and pushes your finger off the hole, or at least tries to, that is the compression stroke, then you can use a socket and ratchet on the crank bolt to bring it the rest of the way to TDC, aligning the the timing marks between the balancer and the timing tab. This way saves needing to remove any additional parts.
Another and the least accurate way, is to turn the engine until #1 piston is at TDC, and observe where the rotor is. In many cases the #1 post on the distributor will be placed in a direction that will be pointing towards the #1 cylinder, or that general direction anyway. This isn't always true, but it's a generality that seems to be followed by many engine assemblers.
post #10 of 11 Old 03-30-2013, 01:49 AM Thread Starter
Red Dog's Blazer
Thanks, I got it going today, I didn't have a way to turn over by hand so just took plug out turned by key and found tdc. it was at 7 oclock on dis, pluged everything up and it running great
thanks for the help
Dont do things when your tired as crap
Chris.
post #11 of 11 Old 03-31-2013, 01:03 AM
Awww..you ain't got shit!
jimmykicker's Avatar
Agreed. Bad idea. I cooked my dash wiring doing just that. When you're tired? STOP!!
1984 xcab s-10 3.4L GM crate engine 87 S10 TBI swap w bored intake, Edelbrock headers. 3.42 locker rear end swap. Flowmaster, shift kit, e-fan.
EFI swap http://www.s10forum.com/forum/f106/c...e-help-513616/
My build thread (3.4L)http://www.s10forum.com/forum/f106/b...stions-427168/
I had to cut my nut in half .
