2.8L starting issues
Go Back   S-10 Forum > Engine and Drivetrain Tech > 60v6 Forum (2.8/3.4)
Old 02-02-2010, 05:57 PM   #1
hey my 2.8L backfires out of the throttlebody when i crank it over could it be the O-ring under my distributer? plz help
Old 02-02-2010, 07:53 PM   #2
4x4 v6 blazer
neo71665's Avatar
Re: 2.8L starting issues
I would check the timing first, sounds like the distributor isn't in right. A bad o-ring under the dizzy will only make it leak oil like crazy and has no effect on the engine running (unless you run it out of oil).
Old 02-02-2010, 08:26 PM   #3
i have fresh oil in it i had to pull my motor almost comletely to change my oilpan gasket ive put #1 cylender at dead top making my dizzy pointing at #1 but it still does the same thing
Old 02-02-2010, 09:34 PM   #4
1989redneks10's Avatar
does it ever start and run? or does it just backfire?
Old 02-02-2010, 10:23 PM   #5
4x4 v6 blazer
neo71665's Avatar
Are you sure your calling the correct cylinder #1? Did you pull the dizzy? Are you sure its not pointing at #4 when it should be at #1 (sounds like the case to me)
Old 02-03-2010, 12:28 AM   #6
well i was wron the gasket is inder the cap and i think its letting air in.. could that be the problem?
Old 02-03-2010, 05:22 AM   #7
no that shouldn't hurt anything. I agree with neo71665 either you got in on # 4 or a plug wire is crossed somewhere.
Old 02-03-2010, 09:02 PM   #8
well ive hooked everything up according to chiltons and the cables are correctly hooked up i just need a 4.3L
Old 02-03-2010, 09:04 PM   #9
4x4 v6 blazer
neo71665's Avatar
Did you take the timing chain off for any reason?
Same problems can happen with a 4.3. Hell I worked on a 350 the other day that somebody had plug wires crossed.
Old 02-04-2010, 12:54 AM   #10
yea i know but my truck has 170k miles on it she need it
Old 02-04-2010, 06:02 AM   #11
man that 2.8 will go way past 170k easy...
Old 02-04-2010, 06:25 PM   #12
no i didnt touch the timing chain
Old 02-04-2010, 10:17 PM   #13
Rebel_US's Avatar
Their pushing on TIMING as an issue due to the backfire.
The things supposed to fire when the valves are both closed and the cylinder is up. Backfiring thru the TBI means a valve is open (intake) and you get a plug firing.
What did you touch prior to this or did it just start doing it?
I'm with everyone else: plug wires or dizzy.
Old 02-05-2010, 01:17 AM   #14
alright guys ill have to get someone over here to time it then ill let you know whats up hit me up kasynehls@yahoo.com
Old 02-08-2010, 08:39 PM   #15
hey thanks for all your help i dicovered it was my dizzy i was 180 out in it thanks again for all your help
