Mr. Clean
2.8 Won't Start - Fuel or Wiring?
The truck has been running flawlessly over the past year. However, I wen my buddy went out to start the truck today, it wouldn't start. It will turn over, but will not crank. Every once in awhile, it will start and run very rough, you have to keep the revs up for it to stay running. Apparently, the frontmost fuel injector doesn't seem to be spraying right. He unplugged the wire clip from that injector and plugged it back in. After that, it ran perfect for about 20sec, began to run rough and quit. The check engine light is not on and there aren't any stored codes. Any ideas? Last year, I replaced all the following:
-Fuel Pump -Fuel Tank -Fuel Injectors -Fuel Filter -Rebuilt The TB -IAC Thanks in advance!! |
Certified Auto HVAC Tech
Re: 2.8 Won't Start - Fuel or Wiring?
what about the back injector?? any way you access to a fuel pressure gauge??
Mr. Clean
I was letting a buddy borrow the truck so I haven;t had a chance to put my eyes on it yet. This is all he knew after him and his dad had a look at it. The back injector appeared to be spraying correctly from his description. I'll know tomorrow though for sure.
No, I don;t have an FP guage. Are they that expensive? I could just go buy one. |
Maybe he put diesel in it
I've seen that happen more times than I'd like to think people are capable of. ![]() |
Mr. Clean
I suppose thats possible, but I doubt it. I guess I can tell from the smell. He said they put some seafoam in the tank and it felt like it ran better, but still not good by any means. I'm about to go over there now and take a look at it.
a rapid-test to figure out what is the problem (fire or fuel)- give it a shot of starter fluid...
- if it starts briefly: it's a fuel problem. -if it doesn't: it's a fire problem (electrical) I assume you've already put the 'Mk I eyeballs' on it, and since you did all that work, you know what is 'normal'. Any vacume lines disconnected - such as that mega-hose going to the brake booster? I picked up a FP/vacume gauge at Harbor Tools this past week - 8 bucks. |
Mr. Clean
Seems like it is running WAY lean. The reason I think it;s running lean is there is no smoke from the exhaust. It starts quick, but the only way to keep it running is to heavily feather the throttle. It will stay running, but it runs very rough and dies as soon as I take my foot off the pedal.
Also, there is zero throttle response. Yes, keeping the throttle down keeps it running, but thats it. The engine response is very very delayed if at all. |
Mr. Clean
The fuel pump and all theo ther new parts have less than 4000 miles on them, but I've heard that aftermarket pumps sometimes aren't worth crap.
I had that happen one time. I took it to a shop, they said fuel pump and quoted $400. Not having $400, I replaced the pump myself and still had the same proplem. Took it back to the shop, and then they came back with bad computer. I replaced the comp and it ran fine. Vibration damage to the mother board or something.
Mr. Clean
Hmm, I was wondering about the ECM. I might ought to try one from a junkyard before I drop the cash on a new one. Thanks for the input.
needs a job
careful. you have a good chance of getting a bad one from the junkyard.
Mr. Clean
True, but you can pay an extra $2 for "insurance". If it doesn't work, you can exchange it until you find one that works. The pull-apart by my house is filled with S-10, blazers, jimmy, bravadas etc.
I tested out the TPS this weekend and it was in spec. I also tried starting fluid and the truck ran perfect off of that stuff. That leads me to belived that my problem is strictly related to fuel delivery. |
yeap - attack the fuel side of the house.
This sounds exactly like my problem.
http://www.s10forum.com/forum/f106/n...engine-403051/ I would make sure your fuel filter is good to go! Then i would be looking into the fuel pump and that short little hose that comes off the fuel pump inside the tank. My problem was that little small hose off the discharge of the pump inside the tank.I was only getting half the fuel so it would only run for a couple of seconds then quit.The fuel was just circulating inside of the tank. Last edited by typhoon92 : 07-02-2009 at 05:31 PM. |
