2.8 valve adjustment woes. - S-10 Forum
post #1 of 9 Old 08-23-2007, 11:16 PM Thread Starter
User is: cams is offline
So I havent been on here in a while but I have some questions. I pulled the valve covers and did a valve adjustment on the 2.8 and after installing a new return fuel line in the process I am trying to get it back on the road. Everything went as planned however... The truck did not want to start at first and when it did it ran funny. (sounded diffrent) After the warm up high idle settled, the idle dropped way below what it should be stock. The truck sounds like it has a nasty stall out cam in it. It is very cool and all but is not the way it is supposed to be and wont get out of its own way during a short test drive. After running like crap I filled the tank with fresh gas (it sat for a while) and put sta-bil and fuel injector cleaner in it. It runs better but still not the same. the battery cables were off for about 2 months. Is there a learning process the engine must do. Or something I must do to help it. Or any ideas on something a messed up. I am confident in my work but have retraced my steps several times and cant find the problem. help please.
Also if you read this far I dont think you need an apology for a long post. thanks in advance.
P.S. It's tbi and a 5-speed 93' s-10
cams is offline
post #2 of 9 Old 08-24-2007, 11:26 AM
User is: nmz787 is offline
Re: 2.8 valve adjustment woes.
are you sure you adjusted the valves right? after there is no lash, the common census around here is 3/4 of a full turn past. yeah the tbi does have a learning process
1985 S-10 Blazer 4x4, 5 speed, new 2.8L ATK crate motor, 93 TBI intake, 2.8 injectors, all emissions equipment. Born and raised in Cali, NO RUST!
nmz787 is offline
post #3 of 9 Old 08-24-2007, 01:06 PM
2lowws10's Avatar
User is: 2lowws10 is offline
are you sure u didnt acadently disconnect a vacum line thats what my truck did when i hada vacum line leak
2lowws10 is offline
post #4 of 9 Old 08-24-2007, 04:25 PM
User is: MadMikeZ28 is offline
Your lucky we read that far into your post. You should give us cookies!
Are you sure you adjusted the right valves on the correct TDC for them? And it is a 1 1/2 turns after lash if removed on 2.8's.
The computer may also need to relearn. Its like a crap shoot with that. I have seen some that need it and others that do not.
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #5 of 9 Old 08-25-2007, 03:48 AM Thread Starter
As I said before I am confident in my work, and believe I did everything right. I am a marine mechanic but specialize in outboards and hard parts. I have done many valve adjustments before but have never worked on a 2.8 before. The adjustment is right, manual says 3/4 after lash is taken out. I also did a comp. test to back it up and it all checks out. I just want to know if there is a secret I am missing (learning process) thanks for the info guys, i'll keep working at it.
cams is offline
post #6 of 9 Old 08-25-2007, 12:56 PM
It's All Good
User is: -10below is offline
Wink Re: 2.8 valve adjustment woes.
I've got a few years experience on Cat diesel truck engines, and small block chevys, but not alot with the 2.8s. Maybe I can help you out though. Every chevy I've ever adjusted valves on (not running) came out just "ok" at best. it seems like it's hard to get a good adjustment on the lifters without the engine running.. (at least on SB chevys) When I to an engine build, I adjust the valves on the engine stand to get them close, then when I get the engine running and warmed up, I pull off one valve cover at a time and adjust each valve individually... this way you're SURE you've got the exact amount of lifter preload... if the reccomended preload value for the 2.8 is 3/4 turn, than that's what I'd stick with. 1 1/2 turns sounds like ALOT. the last think you want to do is have you lifters with to much pre-load and wipe out your camshaft lobe(s).
Get your engine up to operating temp. remove valve cover. with engine idling, back off a lifter adjusting nut until you just start to hear an audable tick, tick, tick, then VERY VERY slowly turn the nut back down till the tick is gone. you are now at zero valve lash. now give it your 3/4 lifter pre-load. remember... VERY slowly. if you run the nuts down to quick, you'll for sure bend a pushrod and and probably kill the engine at the same time.
Do this proceedure for every lifter. yes, it'll be messy, but it's well worth it. and with a little practice you'll get to where you'll be able to do one bank of cylinders in under 5 min.
I have done more than 20 chevys this way and it works every time.
Good luck!
Horsepower Sells Engines, Torque Wins Races
-84 S10 4wd ex. cab work truck-
- 2.8L powerplant- headman headers w/duals- edelbrock torquer 2 intake- holley 390 4bbl carb- MSD coil-
-manual 4wd actuator override- custom engine and transfer case skid plates- custom grill gaurd tough enough to kill a cow-
-10below is offline
post #7 of 9 Old 08-25-2007, 07:27 PM
If you are confident in your work why are you having a problem and in here posting a question about it? That is not showing confidence. My manual, a true Chiltons, not a haynes or a chilton published by haynes says 1 1/2 turn. 3/4 turn on a fine threaded stud does not put much preload on a lifters plunger.
post #8 of 9 Old 04-21-2011, 09:09 PM
User is: crazy_driver_78 is offline
This thread is almost 4 years old. Can I hijack this thread? I have a similar problem to the original post.
You guys have already been a big help for me before (refer to this thread, post #19). It also goes without saying that your information is just as invaluable as it is appreciated.
It all started a few weeks ago when I spun a bearing. Refer to this, post #23, for details. My sig will give current vehicle details. I replaced the bottom end with a crankshaft and bearings from an '85 Blazer 2.8. I never cracked open the top end of the engine. I also used and primed the oil pump with a drill before dropping the distributor. New oil, new filter. I fired it up last night and have alot of valve clatter from both cylinder banks. I asked my mechanic about it. He said to pop the valve covers and look for broken springs, oil squirting out of the rocker arms, etc. I peeled the 2-4-6 valve cover off and fired it up. I still have oil pressure of 40lbs at cold idle, but only a trickle of oil seeping out cylinder 4 exhaust rocker. I think it is only fair to ass-u-me popping the 1-3-5 valve cover will yield the same results so I left the other side of the engine alone for now. I asked my mechanic about the lack of oil in the top end. He suggested two possible scenarios: shrapnel from the grenaded rod bearing stuck in the oil passage feeding the top end or a misaligned main bearing starving oil flow.
Are there any opinions as to the plausibility of these scenarios? Any body else have any ideas?
Thanks again guys,
Alan
1986 S10 Durango Trim Extended Cab, 2WD, 2.8L TBI, 5 Speed Borg-Warner T5, cats & Y-pipe cut 4 dual-in/dual-out muffler + pair of 30" glass packs, Stewart Warner Gauge Ultra Shift tach (blue shift light), contoured bug deflector, external sun visor, fog lights, 15" full size light truck tires, and Alpine head unit, 200K+ miles as of June 2010. 210K miles feb. 2011
My s10 never dies, it just rusts away, kicking and screaming the whole time. -Me
post #9 of 9 Old 04-22-2011, 11:40 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Thanks again guys,
Alan
Yeah, you might have shrapnel floating around. Pull your oil stick and see if it has any metalic chips. I would also suggest that you change the oil again with the filter. Cut the filter open and see if it has metal in it. You may get lucky and the lower end will hang on, but extra metal in an enigne is not too good...
Since you have already run the engine, you may be at the point of no return. After you change the oil and filter, run it again and let it warm up. You may get lucky and the clatter will clear up. One other point, the oil pressure will drop once the engine is warm. If it survives, you may want to instll a new high volume oil pump. And Mr. Lucas may help you also...
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best)
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
