2.8 oil pressure - S-10 Forum
post #1 of 15 Old 01-01-2004, 11:58 PM Thread Starter
User is: Paintballer is offline
2.8 oil pressure
my 1987 blazer has got some oil pressure issues. whenever i amm idling my check gages lite comes on. but sometimes when i'm idling it doesn't. couold it just be my gage or my sending unit. does this happen to anyone else. i only got like 120,000 miles on the engine. but my blazer has been rolled. so lots of things could still be messed up. thanks for the feedback.
Jake
post #2 of 15 Old 01-02-2004, 10:46 AM
What's in a name?....
User is: doc_rage is offline
Maybe the connector at the sending unit has become loose. That would account for the now and again check light. I would check the connection first, then move on to gauges or sending unit.
1985 2.8L 4WD 5-spd Extended Cab (aka "Misery"): 48Kvolt Accel Coil, Accel 8mm spark plug wires, Taurus Electric Fan Conversion, 2.5" straight pipe from y-pipe into Flowmaster 40 series, 3" Body lift, Black spray paint paint-job....TOTALLED-March 17, 2004 by a 2000 F-150....but it totalled his too
1995 GMC Jimmy 4.3L (W) 4WD 2dr....(aka "Misery II", b/c Misery loves company)
doc_rage is offline
post #3 of 15 Old 01-03-2004, 09:18 AM
Dr.Fiero's Avatar
User is: Dr.Fiero is offline
But know that sending units are really common to go out of whack...
Replace it with a true GM unit for best results.
'91 S-Blazer w/'90 roller cam 5.7, Holley carb, MSD distro, Crane ignition, Vortec heads & Edelbrock intake - 2whl drv - 700R4 - Flat Black on black - B&M Mega shifter - Hedman headers - Flowmasters - Granite Alloy GA8 mags - 225&255/50-17's - 4/3 drop - leather interior - Altezza tails - AirLift air bags.
Visit my YouTube channel! www.youtube.com/user/drfiero
Dr.Fiero is offline
post #4 of 15 Old 01-03-2004, 04:40 PM Thread Starter
yeh i'll probly check all the connection and then replace sending unit if necessary. but what are common oil pressures for those 2.8 at idle?
Jake
post #5 of 15 Old 01-03-2004, 07:39 PM
User is: ssloggy is offline
yes,my 87 did this too. I upgraded to a 3.4 and now things are great. my oil pump was worn out in the 2.8 and i had alot of crud/sludge in the heads that may have been restricting the flow of oil back through the return passages. take a look through oil cap into the valve covers to see if yours is sludged up too.
ssloggy is offline
post #6 of 15 Old 01-04-2004, 06:54 PM
Senior Member
User is: Blaze86lo is offline
Send a message via AIM to Blaze86lo
the normal are about 40, but i had on my 86 project i have, i had it bored to a 3.1, and a racing oil system and now it gets over 60, go that route, its better to have more oil
1986 S10 Blazer, 3.2L FI, Auto, Flowmaster 40 Series Muffler, K&N, flipped lid, racing oil system, 2 Pioneer 10" subs, Pioneer 600w amp, Sony Xplod Head Unit (looking for Pioneer), Aftermarket 6x9s, American Racing Rims, under construction...
1998 Honda Civic EX, 1.6L VTEC, 5 speed, Tenzo R Exhaust, DC Headers, intake, APC Wires/Plugs, short throw shifter, shift knob, pedals, AutoMeter Gauge Pod, Kenwood head unit
post #7 of 15 Old 01-04-2004, 08:16 PM
The Chiltons Manual states the oil pressure should be at 45psi at 2000rpm, but does not have anything listed for idle.
The Haynes manual shows oil pressure should be at 10psi at 500rpm and 50-55psi at 2000rpm. I have an '85 2.8, and mine gets to 45psi at 2000rpm, though shows around 10 or 20psi at idle, which is around 700-750rpm.
doc_rage is offline
post #8 of 15 Old 01-05-2004, 09:52 PM
User is: bobgolding is offline
You might want to get a mechanical gauge and double check the pressure readings...my 87 had the same problem with the check engine light flickering, and the gauge bouncing around. I swapped in a junkyard sending unit, for no improvements, then rigged up a mechanical gauge to 6 feet of hose so I could even check running pressure. (duct taped it to the hood, drove around with it for an afternoon). Anyway, despite all of the gauge /light wierdness, I had 25 lbs at idle, and 55 at 60mph.
post #9 of 15 Old 01-05-2004, 09:59 PM
CenTex's Avatar
User is: CenTex is offline
Very low oil pressure at idle is usually an indication that the main & crank bearings need to be replaced, with 120,000 miles, it might be time to consider that possibility. But check your pressure with a mechanical gauge first - it's the cheapest...
CenTex is offline
post #10 of 15 Old 01-05-2004, 11:46 PM
life begins @ 20 psi
SY2932's Avatar
User is: SY2932 is offline
Smile
I "moved on up" to a 3.4 in my 1988 S10 and I have 37 psi at idle and 62 psi at cruise as veiwed by my electrical Auto Meter oil pressure gauge:
http://huryde.station180.com/gallery...aSY2932&id=ahe
HTH's
Mike Campbell
Mike Campbell
1991 4.3 TURBO V6 SYCLONE
Administrator on syty.net
My Gallery
SY2932 is offline
post #11 of 15 Old 01-06-2004, 05:37 PM Thread Starter
yeh my light is starting to flicker i dunno it just bothers me that the light keeps coming on. but i mean do the manufacturers set the oil light to come on before it even should to keep u heads up on it or what? i mean my light flickers at idle and thats at about 20 psi. maybe lil under but if u guys say 10 psi -15 psi at idle i should be alright. when goin bout 35 i get 40 psi. 65 its bout 50 psi. i dunno much bout pressures but are these good?
Jake
post #12 of 15 Old 01-07-2004, 03:00 AM
User is: jif06 is offline
i have a 86 with the same problem the gauge bounces around at idle and then goes up to 45-60 when i throttle it. i havent had any problems with mine and i have seen other ones that do this too. i think it just a common thing with these 2.8s i do know that the sending unit is a weak spot for these
Rather push a Chevy than drive a Ford
jif06 is offline
post #13 of 15 Old 01-22-2004, 07:37 PM
YAY for Primer!
ShortyzKustomz's Avatar
User is: ShortyzKustomz is offline
Re: 2.8 oil pressure
I know on older smallblocks the light came on @ around 7 lbs. In my Camaro I had that problem with my guage dropping to around 8-10 @ idle in gear, Anyway, I had trash in one of the ports that go into the filter, It was wires from a wire wheel on my rebuild, Cleaned it out, Changed the oil and she holds 20 now!
-1994 Toyota Bagged, Suicides, 3.8 T5 Swap in the Works
-2006 Silverado 5/8 Drop on KMC 20s
-1992 S10 Longbed 4.3 3/4 drop (Beater)
post #14 of 15 Old 02-11-2004, 11:14 PM
User is: Hou88S10 is offline
You were asking if anyone had a similar experience and I have, and still do. I have an 88 S-10, 2.8L with 115,000 miles that started doing this one year ago. I have done all the things mentioned including putting 50W oil, and the light still come on. A mechanic told me that either the oil pump is worn out or the engine is worn out. The behavior is consistent with this. the light barely came on at first, and now it comes on any time the engine is below 2,000 rpm and warm. In addition for the first time in its life, the engine is now missing consistently and does not seem to have any power. I guess I wait until a rod comes through the hood, then decide what to do. Because of this, I am seriously considering dropping in a 3.4L engine, however, I am worried about running a "rich" mixture at low speeds and not passing inspection.
Hou88S10 is offline
post #15 of 15 Old 02-12-2004, 01:36 AM
[QUOTE=Hou88S10]You were asking if anyone had a similar experience and I have, and still do. I have an 88 S-10, 2.8L with 115,000 miles that started doing this one year ago. I have
As I said above, mine did that breifly...oh, about 75,000 or 80,000 miles ago, and it turned out to be a totally electrical problem. SInce the sending units and wiring are notoriously bad, check it with a mechanical gauge! You can built your own mecahnical testing gage from hardware store parts if necessary.
Frankly, after my experence, I wouldn't consider the gauge to be much better than an idiot light, certainly there is little hope that 40psi on the guage actually equals 40 psi, etc.
